Big Dan
Logitech Harmony 525 Using 2 Pvrs
I'm about to lay down some dosh on a Logitech Harmony 525 remote control, and I was wondering if it will be able to support 2 PVRs with the same remote without getting each other confused. I have a DGTEC DG-HD160PVR and a Centrex CTPVR160TT SD PVR and would like to be able to control them both with this new remote. I've checked with the Logitech website, and both are supported, as well as my TV, DVD-R/VHS and SDTV/DVD (hooked up to a 5.1 channel sound system). Thanks in advance!
I have mine controlling two games consoles in two separate activities and it works a charm. The kids can put bothe the PS2 and Wii on with no imtervention from dad B)
I have my Harmony One controlling a dvd recorder, tivo, xbox/dvd player, bluray player, wii, av reciever/radio, ipod and tv
no problems in fact, its fantastic :)
How does it control the ipod?
I'd be interested in that too! :huh:
I guess it controls the Hi-Fi that the iPod is connected to??
No.
You need to get the Universal iPod Dock from Apple which has an infrared port.
http://store.apple.com/au/product/MB125G/B...;mco=MjE0NTAzNw
The Harmony can then be told to control an "Apple iPod" and it will work. Alternatively you can use the Apple Remote to teach the harmony, and it will then match up to the iPod preset.
The Harmony will control your hifi for volume/muting and the ipod for next track, previous track, pause/play and off/on
Edited by Stux
My 525 said it couldn't do the Wii about a year ago, has there been a change ?
The other problem I have is changing AV inputs. My TV is a Philips plasma which changes inputs like the Samsung on option 3. I tried changing the delays like it says in the help but resorted to a work-around in the end. I also thought of setting up a sequence if I can't get it to work the way it should.
Andy
The Wii uses Bluetooth. You will not be able to control a Wii with an infrared remote control.
What you can do is control the volume on your hifi, and handle all the video/audio switching, modes etc.
You will need to use the Wiimote to turn on/off the wii and use the wii...
But that's not so bad, since you have to use the wiimote to use a wii ;)
Andy
I have the Harmony 785 and a Philips LCD and gave up trying to get the TV to start on the correct input for the DVD player by cycling through the inputs like you do with the Philips remote for my TV.
Then I discovered that there are commands in the Harmony Database associated with going directly to each of the inputs (e.g. InputVideo1, Inputvideo2, Inputvideo3 and Inputside) even though there aren't the equivalent buttons on the TV's remote.
I added these as "Additional Buttons" on the Harmony and gave them meaningful names such as "DVD" for "Inputvideo1" (which is really Component 1) and then you added these as commands within an Activity (e.g. watch DVD).
My Logitech Harmony 525 controls:
5 x DVD Recorders & Players
1 x CD Recorder
1 x Plasma TV
1 x amplifer
You'll need to setup which to turn on viz:
Pioneer DVDR (choose the main)
Plasma TV
amplifer
etc.,
One catch:
If you turn the above equipment with the Harmony, you need to turn off all with the Harmony.
I turn on all the above with Harmony and use my original remote to do other functions or turn off etc., this upset the Harmony next time when you use it.
Edited by Leeroy07
You can also add new commands, and then when you go to teach it the command you can select "i don't have the original remote, but I know the command" and then select the InputVideo1 and name it DVD, for example
I tried those before very early on but they didn't seem to work. I'll give them another go and see what happens.
Profiles in the database for pieces of equipment that don't work usually get replaced by working ones after a while. Some people upload some rediculous configuration for new equipment, check out the profile for the pana bd-30, around 100 commands that dont work and the ones that do are labelled wrong, or maybe thats been fixed by now.
Hakka.
Thank's Guys. Starting to get somewhere at last.
The direct commands wouldn't work at Device level as I had found before, wouldn't work when added as additional buttons at Activity level, but work well in a sequence at Activity level. I tried them both ways in a sequence, as direct commands(inputAV1 etc) and also longhand(Inputnext,Down,Down,Right etc) and both worked.
It makes me wonder what is wrong when trying to use input select option 3 which is exactly the way the Philips selector works. The best I could get it to do as an additional button at Activity level was to move from the first selection to the second but no further. When trying to select the TV alone it would come up at TV at the top of the list, then change to the next one down. I tried changing the timings but why would it work in a sequence and not within option 3.
I think I'll ask Logitech to add a fifth option to the input selection options: Use a sequence!!!
Andy
I got the correct input issue sorted on my Philips Plasma following a tip I picked up in the Reviews forum. Try setting the Power On delay around 12000ms or greater and see if that resolves the issue with your LCD. I'll bet it's the same as mine and the Samsung. See the post in the other forum and the explanations.
Now to delete all the sequence I created.
Hakka, not always.
Everytime I go into my profile to adjust settings for my TV, I get a message saying that an updated version is available. i downloaded it as another TV, and guess what?
It has less than half the commands of my setup! WTF!!! :wacko:
Obviously I just deleted it and ignore any further messages about it.
I'm wondering if they update them from our setups after we hit the "my remote is working fine" after making changes. I started using it when I was offline and had to do my setup around at the kids and couldn't check it out until later, figuring saying no would take me somewhere I didn't want to go.
I hope they don't take any notice of my AWA DR711 DVD Recorder setup. It's based on an alternative they offered that had as many commands I don't have as were missing from mine. After that experience I'm going to reprogram it from scratch now I've got the hang of it just to set the record straight.
