Alfred Smee
Lg 52sz8r Dlp Rptv - Owner's Report 12 Months On
208 posts in this topic
Hi Guys,
Very impressive thread, I would like to thank everyone who posted constructivly to this thread over last 3 years, geat info!!!
My globe warning started popping up only this week, had set a good 4-5 years or so , great picture through playstation 3 running on 1080i
never used analog tuner, always run through component 1 with Topfield pvr.
Total globe hours: 7931 and still going... ( touch wood ) although have noticed that picture not as bright lately.
I too found it hard to access globe hour menu, ok on tv and mute on remote for 'exactly' 5 secs seems to be the trick.
thanks for recommending drtv in towoomba, still the best quote for bulb, have ordered, but will wait till bulb dies before replacing.
Keep up the good work
Addyhash.
Whoops i spoke to soon.It won't turn on now.
The power light just flashes yellow then turns off.
Any ideas?Off to the repair shop we go.
Paul.
I have the same problem last week and had my set for more than 4 years now. Still have extended warranty but they said globe not cover under warranty and need to transport to service centre before they can look at it. Can anyone tell me when globe completely blown will the "globe indicator light" still will lit up red when turn tv on? Mine just same as describe by Paul the power light flashes yellow and turn off to standby mode. without any other indicator light come on but I notice a few day prior to that, the image is a bit darker than normal but without any message come up and said anything about the globe on screen. Any help will be great help since if its not cover by warranty I will need to pay for the transport fees to service centre.
Paul.
Sorry! I'm a newbie to this forum and I can't find the right place to ask my question - so I'm asking it here.
I bought an Avatec LCD TV about 2 years ago, and have just busted the remote.
I checked on the net to find where I could get another remote, and all I found was Avatec's non functioning website. I can find no retail outlets or comment forums on Avatec, nor any news about the company, either.
Please: does anyone know what happened to Avatec? Have they gone bust? Will I never be able to buy a new remote for my Avatec LCDAC-TD320F8? :huh:
I've had my LG 52SZ8R-TB since 1 Sep 2005.
Since then I have got over 20,000 hours from two lamps.
Replaced original lamp in Aug 2007, cost AU$230 from SEQ Electronics in QLD.
Second one is just about to go (TV switching off and lamp light flashing).
What a fantastic run from a very resonably priced TV at the time (paid $2497 in 2005).
Hi Everyone :)
I need your help people!!! lol
I scored one of the TVs last week for free( Lg 52sz8r-TB)
The lamp has been replaced and i'm pretty sure Ive reset the lamp hour counter(Grey box top r-hand side of screen with clock?)
Searched the net and found the (menu/menu) (menu/mute) instructions, did what that said , etc,
It now shows 00:00
The problem is, when I turn the TV on, it still shows the Lamp Life Over MSG at start up for around 1 min, every time.
The service menu says nothing about the lamp or resetting the timer etc,, (Menu/Menu on remote)
When I press the OK/Mute on remote, the grey box shows on the top right hand side with a clock showing 00:00 but still the Lamp Life Over Msg appears on start up still???
What am i doing wrong?? I dont have a manual for this TV, never owned any LG stuff before either etc..
Do i need to purchase the LG service remote that has more access to the TV to fix this problem>>(LG MKJ40653801)
Any help is appreciated !!!!!!!!!!!!!!!!!!!!!!!!!!
Finally, after 4 weeks of scratching my head, I worked it out lol.
You have to hold the OK on the TV, and the Mute on the remote for a fairly long time.
Mine takes an average of 13 seconds or longer before the lamp timer comes up for reset.
I was giving up after about 7 secs,,, etc...
Thats all it was.
Well my 52sz8r-tb appears to have called it a day. It has about 28,000 hours on it & has developed a temperature problem that I've not been able to resolve. The current lamp has 5400 hours and still works well.
TheTV will be working fine & at any time from 10 minutes to about 5 hours after turning on, the temp lamp will flash 3 - 5 times & the set will turn itself off. There is very little mention of this issue anywhere & most of what I did find was rubbish. There were two helpful threads that discussed the problem & discussed cleaning & replacing fans.
What a great idea ..... checking & cleaning the fan behind the lamp box is easy - very accessible, not much cleaning required & it's working well.
The second fan is another story. It's completely inaccessible, mounted on the connector side of a bundle of components which includes the SUB ENGINE ASSY, AL C/W SUPPORTER(WITH HEAT SINK & some sort of power transformer, it can be seen (sort of) by removing the access panel in the rear center of the set. But to reach it you'd need the forearm of a 9 year old boy (or a very petite female ), I don't have the assistance of either one.
It appears that the only way to check, clean & if necessary replace this fan, is to disassemble the whole set. I hear some of you saying 'Have a go you got nothing to lose'. Well pulling it apart & reassembly doesn't phase me but the prospect of realigning mirrors, light tunnel etc .... I have the service manual - it's not particularly helpful.
The Fans are available from the LG parts distributor in South Australia for $35 each plus postage. It seems there are two variants of the 52SZ8R-TB, AMILLA and AAULLSK-LGEAP. In the 52SZ8R-TB.AMILLA the two fans are identical - LG part number: 5900V09008F. The 52SZ8R-TB.AAULLSK-LGEAP uses the 5900V09008F behind the lamp box but the inaccessible one is 5900V09008E.
Any info or advice is most welcome. Mean time I hope this is helpful to someone else with the temperature light problem.
John
Forgot to mention, needing a TV while the old one is indisposed, I turned to eBay & picked up another 52SZ8R-TB (needing a lamp replacement) & used the lamp from my old set.
WhaHoo! Bargain
Look what I just found on eBay . Since that item will expire, the seller is lamps-4-less here's the link to his listings. With the Aussie dollar doing so well against the pound It comes out at about $120 inc free postage.
I checked out his website where he has over 300 rear projection lamps listed. Then I rang him (voip of-course). These are the Belgium globes, manufactured under licence from Philips by Osram Belgium. I've read raves about the high quality of these lamps compared to the 'made in China' ones we get here.
The cheapest I could find a bulb locally was $187. I'm a tight fisted character at the best of times so I clicked the button & bought the Belgium Osram for $120.
It's coming from Glasgow & the guy reckons about 2 weeks for delivery - I'll let you know how it goes.
J.
John well done.
I bit the bullet and got a globe from the last place i bought one $187 plus postage from Qld.
After being told the colour wheel is dying and it wouldn't be as bright as it should be.
It's now in the bedroom.
When it dies to the tip in a million bits it goes :(
It has been a good tv.
Paul.
WhaHoo! Bargain
Thanks for the link John, Just replaced mine from there, quick postage from Scotland, got here in 10days.
Just a note, the globe on the site says model 52SZ8R-ZA but they will work on 52SZ8R-TB models...
Wrapt my colours are bright again, just in time for the Grand Final.
I dont know the excact hours this last globe did as the set went back for repairs about 6 times, so Im unsure if its the same globe as they tried everything to get it working again. But since the last time it was reset it had 5500 total hrs on it which is rubbish as my first globe did over 10k hrs...Ive reset it and see how this one goes...
Not a bad price also, $102aud delivered ....
GBP 59.00
AU $97.97
Buy it Now
Edited by firthy69
Globe update. Beginning of November I bought another globe from the same ebay guy in Scotland - cost $81 inc. postage
My second set is running well & with the old one in the garage for spares it will be quite a while before I pension it off. So I thought I'd best get another globe to be ready for the inevitable.
I keep seeing the new sets getting cheaper with more features & the prices still get even cheaper. And while my old 52SZ8R is still performing well, I'm saving buckets as the new prices continue to fall even further.
Hi Guys,
I was sitting watching my unit on the weekend (52SZ8R-TB) when I heard a loud bang from inside the box, instantly the screen lost its colour. No image quality was lost, its just black and white, actually more like sepia.
Would this be the colour wheel retiring? It sounded like a spinning item self destructing, I've noticed they are about $160, seems reasonable. Its removing and installing that particular component thats got me worried, is it worth it? It appears to have some level of complexity regarding filters, mirrors and calibration etc.. Has anyone changed one over before, or got any tips (other than taking it there :)
Still has the original lamp from 2006. The red lamp light has also just come up. Although the image is still very bright, I will replace, but only if the colour wheel is the other problem and viable to replace.
regards, Juzzo.
John well done.
Paul.
Boy is this TV one great buy.Still running.
It must be at least eight years old now.
Paul
Paul
Yeah gotta agree. 4000 hours on third lamp and PQ is exactly the same as when bought mid 2005.
Still working like a treat.
I dragged it outside last Saturday night to watch the Hawks and for a BBQ(we cooked the meat on the BBQ,not the TV) :hyper: and my 52nd birthday.
We played some music BD's and had the sound flat out up to 100.(just the TV speakers)
Not one bit of distortion.
:queen: Paul.
Edited by Mr craptastic
Put third lamp in my TV today. It has done nearly 25000 hours and is over 7 years old. It still works just like new but I wouldn't say no to a new LED TV ;-)
Edited by Alfred Smee
