Hi Guys,
Just wondering if anyone has used Control 4 for their Home Audio and Visual.
I plan on having a 7.2.4 Atmos setup in my Home Theatre running from a Marantz SR7010 with a JVC Projector. My loungeroom will have another Marantz SR7010 running a 5 channel in ceiling surround sound and than using the other 2 zones within the amp run my Kitchen/Dining speakers and Alfresco speakers. Planning on running it all through Control 4 and wanting any suggestions or recommendations before I go through with this from people that have first hand experience using this system.
I've used it before in a cinema room i installed at a retirement home. The app is simple enough for the elderly residents to navigate and the staff there love how simple it is to. I personally do not supply Control4 but my programmer does. It's very expandable also so you're not just limited to your cinema room and AV gear. Sonos, lighting etc can also be done via the app
I wouldn't go there....every minor tweak you need to do to the C4 installation will require a tech service call. = expensive.
Any suggestions for something similar? I need the ease of use for the wife and kids when I'm not home to do it for them.
You need to tell us what it is you are trying to achieve.
This is 100% true and can be a real pain if you're not the C4 installer. If you've a cinema room with a set amount of devices you want to use it shouldn't be a major issue
We still don't know what he's trying to achieve because he hasn't spelled it out yet.
To be clear, as an end user you are totally locked out from making any programming changes in C4. Which is why I will never buy it.
To be fair (to Control4), you're not the intended market/customer. Control4 is designed to be setup by a professional for non power-users.
It is set and forget and generally a tech can diagnose and fix most things remotely. With your tech ability @brodricj, you most certainly don't want to be locked out of managing it all yourself so this platform is not for you. Hundreds of thousands of applications around the world though are highly successful and in most cases, once setup correctly, it just works for the end user.
I myself have been contemplating a system for a few years as most of my house is "smart" already.
For the same reasons though, I'm going down the ELAN route now.
End users are not Control 4 customers, Control 4 dealers are their customers.
Sorry gents flat out.
its all about a set and forget type system that is reliable and easy to use interface for the wife. I haven't got the time or skills to set it up myself but yeah. That is why i was looking at control 4. If you have other suggestions than feel free to let me know.
Thanks again
A set and forget type system for doing what? We have no idea what you're trying to achieve.
As i said in the opener i have 2 marantz amps one running 7.2.4 in my theatre room with a jvc projector, foxtel, set top box, 4k bluray player and playstation going through the amp. Than the second amp will run my loungeroom tv with 5.1 surround ceiling speakers and also running 2 seperate zones aswell. This will have foxtel and bluray plugged in.
I want the ability to use a single remote or app to control all audio and visual, single one click that turns on the necessary components. For instance watch foxtel in theatre and it turns the amp on with the necessary output selected, the projector on and foxtel box. I know control 4 can do all of that is there something else with a similar interface with ease of use.
Controlling his Cinema, a few zones with perhaps Sonos I'd say by the sounds of his OG post. Control4 will do that a piece of piss plus you can add more onto it later. Yes...it's not designed for the end user to mess around with which isn't a bad thing because 95% of call outs to open end control systems is from users messing with the settings. If C4 wasn't user friendly or for the customer then why are so many big home cinema suppliers installing it?
3 minutes ago, SUPCIN said:
... If C4 wasn't user friendly or for the customer then why are so many big home cinema suppliers installing it?
In two words. Service calls.
6 minutes ago, Camo1151990 said:
I want the ability to use a single remote or app to control all audio and visual..
And the Marantz remote can't do what you want to do?
Yeah....so you're saying their grand pan is to install a system half arsed so they can then return multiple times to charge the customer more? Sorry mate that's not how it works. If one of my integrators installs push, elan or C4 and it stuffs up they return to fix it out of their own time and pocket. Unless the customer has physically messed with the setup it should not just simply fail...and you can't just charge a customer for your failed programming mistake either bud. Doesn't work like that
Thanks again
If you can afford it, then this exactly what you'll get. Set and forget.
If you're into tweaking - it's not for you.
Sent from my iPhone using Tapatalk
It's the fact of having 2 marantz remotes, 2 foxtel remotes, a tv remote, projector remote, 2 dvd remotes its all abit messy. Than the wife having to remember which input is what. It's more for her than me. Last house had a simple tv with foxtel and dvd player on surround sound and that was a pain in the ass and i was getting calls about which input is what. All about user friendliness I don't want to be investing the money i am and not have my wife use it because she doesn't know what to press.
That's got nothing to do with helping the OP with their question.
Thanks mate.
I have no idea on tweaking and am happy for something that does what i need consistently. All about user friendliness for the wife really. Just open to suggestions on anything that is better than control 4 really.
Please sign in to comment
You will be able to leave a comment after signing in
  • Similar Content
    • By Camo1151990
      Hi Guys,
      Building the new house is coming up very shortly and with the audio and visual I have planned within the house I am looking to a home automation service to control it all. Main reason is to make the wife happy and have everything on the one iPad for her to easily control.
      I assume people have done it before and was wanting some advice on what was best to use and had the easiest interface. I have seen a demo of Control 4 and was very impressed. I have provided a list of what I am planning for the house and what I want to be controlled. I am planning on some cameras around the house that can be added also to see through the app remotely but don't think that is too hard to do. I am not interested in air con control. I would like the home theatre lighting to be controlled via the app also but not a deal breaker.
      Let me know what you guys think and your experiences with it all.
      Home Theatre                                             Lounge room
      1x Amplifier        1x Amplifier
      1x Foxtel Box        1x Foxtel Box
      1x UHD Bluray        1x Blu Ray Player
      1x HD Set Top Box                                                             1x Free to air at TV
       Alfresco                                                Kids Activity Room
      1x Zone 2 Audio & Visual from Lounge Amplifier                1x Foxtel Box
      1x Free to air at TV                                                              1x Blu Ray Player
       Bedroom
      So in the AV Room,
      Amplifier
      Foxtel Box
      Blu Ray Player
      Amplifier
      Foxtel Box
      UHD Blu Ray Player
      HD Set Top Box
      Foxtel Box
      Blu Ray Player
