BelindaMaree
Antenna adaptor help ... please?
4 posts in this topic
Your existing wall socket could just be loose, it could be replaced with a wall plate using an insert like this:
If you look closely at the socket, compared to the image you posted of what is presumably your socket, you can see a circlip around the outer edge of the socket, which helps to grip the plug more firmly.
A view of the wall inserts I use shows this more clearly:
Another method, which may be the one you are after, is to use a F wall plate, such as this:
Which then requires the following flylead:
Hope this helps. I am presuming if a change of wallplate is anticipated, the correct connector & or tool is to hand to reconnect the cable at the rear of the existing wall plate to the new one, if there is not already a F connector on the coaxial cable in the wall cavity.
Duck (he is a duck) gave some good options.
I'm guessing you want a plug in solution and not have to unscrew the wall plate and perhaps attached wares from behind?
If that's the case there's no 100% solution as anything that uses the slide in connectors (like you have) could just slide out again with the cat.
As duck says, it seems your plate connector is loose (but it might just be the cable end is a bit small and another cable (same type) might fit more securely.
If you want to replace the wall plate then its actually very easy to do. You'll find the antenna cable all trimmed correctly and a single screw should enable you to slide it out and slide it into a new plate with say "F connectors" (the screw type)
Have a watch of this video. The first minute details how to cut the antenna cable yourself (which you probably won't have to do.). Ignore the bit in the middle and At the 2:45 minute mark he shows you how to attach the cable to the back of the new plate.
Good Luck
  • Similar Content
    • By vanderblitz
      Hello,
      I'm looking for a reputable TV antenna installer for a new single story house, with colorbond roof in Williams Landing suburb (west of Melbourne)
      Any recommendations?
    • By SqEyez12
      Is it possible to have two WISI antennas at different locations on one's roof, connected, so that they act as a single array for TV reception?
      The reason I ask is that I am in a fringe area (country NSW) and a signal survey across my roof could find no one location where all 5 channel groups (2,3,5,6,8) are good, there is always one or more channels that fail.
      So i was thinking that if you had two locations were, say, 2,3 6 were good and a second location where 5 and 8 were good, if you could have a WISI antenna at each location and connect them in some way so they formed a single array (i.e. one antenna would not interfere with the other) then one should get good reception on all channels.
      An antenna tech who did the survey today said it is not possible, but I thought I would ask here anyway.
      TIA
    • By prashant75
      Hi there,
      I am not very expert in TV technology and i really need your advice. I have a Samsung Smart TV 7 series (bought in Dubai) and i am not able to get Free-to-Air Channels. I dont have any STB and no pay tv like Foxtel etc. I am not a big TV buff but want to watch free channels. I tried to setup using auto-tune and manual tune, but no luck. Also, there is something called "Area/Region" for setting channel in TV and i dont have "Australia" option in the list. I live in an apartment and each unit has a point to connect. Most of the people in my building are receving good signal and able to watch free channels.
      I called Samsung support and they said my tv doesn't has/support Australia frequency. They advised me to check with local retail shops or buy new TV.
      I dont want to buy new tv. does it work if i buy a Set up box such as Dick Smith HD Digital Set Top Box with USB PVR.
      I really need your advice.
      Thanks in advance.
      Pras
    • By Dexx
      I have a TV in a room where an external antenna connection isnt possible. Can you recommend a cheap indoor antenna which works ok in a medium signal area? VHF primarily.
    • By calichin
      recently moved to a new house in the eastern suburbs of melbourne. The house has an external antenna and I assume it was working for the previous owner. When I plug the TV directly to the wall socket, I get ~8-9% of signal strength on the TV (did I mentioned the antenna is on the roof?). When I plug the PVR to the wall socket (and then the TV through HDMI) I get no signal at all. The "passthrough" of the PVR also gives no signal to the TV. With the 8-9% I can watch some TV, but I get a lot of freezing. Interestingly, I plug an old "rabbit" antenna to the TV or the PVR and I get ~50% of signal strength.
      I'm trying to sort out where the issue could be. I have:
      confirmed that the wall socket is connected (behind the plate)
      the cable runs to the roof
      the cables in the roof are connected to the antenna.
      I should give a bit more info:
      there's one cable coming down from the antenna and then there's a splitter (a simple small one maybe 2cm x2cm): 1 in, 2 out.
      one of those "out" goes into a room but I don't have a spare tv to test, and moving the large tv is not an option.
      the other out goes to another splitter, but this has some sort of circuit board. there's no splitting happening as there's only one in and one out (but more out could be used). Then after this second splitter, there's a third one similar to the previous, a small box where one comes in and 2 comes out, also with some sort of electronics in there.
      There's only 1 tv in all the house, if there are other TV sockets, they aren't used.
      I've gone as far as I can understand, so I came here for help. Should I eliminate all the extra splitters? replace them with new ones (looks a bit old and dusty)? is it worth buying one of those antenna meters to test the signal strength?
      (like this: http://www.jaycar.com.au/productView.asp?ID=LT3332)
      I haven't climbed to the roof yet. Is there some sort of connector at the roof that might be loose? I'm trying to figure out if the issue could be somewhere else before adventuring to the roof.
      Any help or suggestion would be greatly appreciated.
    • By uanmi
      I have a TV antenna and above it is an old antenna that has broken and part is hanging down onto the other antenna. On a windy day they bang together and this causes dropouts.
      I would like to also get two more tv points in two rooms that don't currently have TV points.
      I have been using an indoor antenna in one room and it does not get channel 1, 10, etc. This is quite frustrating as I enjoy some of the shows on that channel.
      I would apppreciate an indication of what the cost would be.
      regards, Mark
    • By Matthew Bongiolatti
      Hey guys,
      After cancelling foxtel due to not really watching the channels apart from free to air, i found that i was missing having the ability to record tv, so being new to HDTV recorders i did alot of research into which system suited me best. I settled on a Topfield TRF7160 and bought one for a great price at JB HiFi.
      Went to install the new PVR and this is when the strange issues occured. This is what i did:
      Unplugged the coax from the tv and plugged into the antenna in port of the pvr.
      Plugged in HDMI, TOSLINK, ethernet & power in. All Ok
      Turned on tv & pvr, went through the setup scan of channels to which the unit found none. Puzzled, as my HD TV with in builtin HD tuner works perfectly fine, i started to fiddle with the cable. After no more luck, i came to the conclusion that somehow my existing cheap coax cable was faulty and bought a new $40 one from Jb HiFi. No luck.
      I then plugged in a portable powered rabbits ears that i use in the spare room (which works ok), and ran the scan again. The toppy picked up SBS stations but nothing else, tested the channels to which were working. I then plugged the wall coax back in and found that is lost signal straight away. Plugged it directly back into the TV which worked fine on all channels.
      Thinking that there may be something strange going on with the coax port on the toppy, i loosely plugged it back into the toppy and i started to get a picture.. I then ran the toppy through a channel scan again and it found all channels with 90+ reception.
      At this point i settled on there must be something wrong with the unit and returned it to JB. Brought new one home today and same problem exists.. I have found that as long as the coax cable is loosely touching (or even not touching by around 2-3mm) the signal is perfect.
      I have no idea why this is happening but was wondering whether anyone had any ideas, as the way it is set up now is not ideal?
      Cheers in advance and apologies for the essay, but i thought as much info that i can give will help.
