SqEyez12
Multiple Wisi Antenna Array Possible?
34 posts in this topic
I recently tried in staking 2 of the matchmaster 02MM-EE06A wisi antenna's on the central cost of NSW in the suburb if Springfield dual to low signal. The antenna is pointed towards gosford. The antenna is already elevated up 10m using a  telescopic mast mounted on the ridge cap. I used a match master Stacking Combiner (09MM-SK02) https://www.matchmaster.com.au/filters/09mm-sk02/
I alighted the antenna's using a matchmaster H60 Field Strength Meter (12MM-H60) https://www.matchmaster.com.au/test-equipment/12mm-h60/
For some reason the signal has dropped when having two WISI antennas compared to 1. The BER is also far worse. The two WISI antennas are stacked side by side with a 100mm gap between them on horizontal bar which is center mounted to the top of the telescopic mast.
The next thing I was looking at trying was yagi style antenna 02MM-DG91 from matchmaster https://www.matchmaster.com.au/digital-tv-antennas/02mm-dg91/
Interesting results!
Adrian
Adrian,
You only get the 3 dB increase when the signals are inphase with each other. http://www.grantronics.com.au/docs/StkYagis.pdf. A wavelength is 300/signal frequency in MHz.
The combiner cannot compensate for the phasing. You need to make small adjustments in the length of one cable to the combiner.
Gosford is horizontally polarised making the phased array the best choice for blocked paths.
Adrian
Hi Adrian
You are certainly in a difficult location.
Can I suggest don't make small adjustments to one cable as suggested above.
All you need to do is ensure both cables from antennas to combiner are long enough to easily reach the combiner, ensure they are cut to exactly the same length and ensure both antennas are oriented the same way up and you'll get your gain. See attached pix.
James
Obviously the pair of signal are not in phase due to the reduced level of signal increase and the reflections causing the increase in errors. Whilst the ideal is to have equal lengths, the reality is that not all cables have the same delay characteristics.
Adrian
Where in Springfield are you located? Did you try getting a signal from Sydney?
Dear Reader
For the purposes of phase matching at UHF television frequencies, you can trust that two equal lengths of RG-6 will have the same delay. This is not some ideal world goal that the poster above is suggesting, just proven practical advice.
James
Hello CMatten
I don't know where Adrian is however when I checked the path profile from a central Springfield location to the three local transmitters and Sydney they are all woefully terrain obstructed.
Adrian really has a challenge.
James
He might be worth listening too if he was clearly talking about PE vs foam. VF 0.66 v 0.83 is enough to be a problem. But he hasnt said that and yeah for equal lengths of the same basic type youre right.
Hell I've bench tested 9290 9913 9292 & 300 ohm twin against each other. All have close to the same VF. You could use equal lengths of foam core RG6 on one leg and ribbon cable on the other wirh no probs due to VF.
Edited by Pesto Lovin' Man
stupid calculation
3 hours ago, James T Kirk said:
Hello CMatten
James
Hi James
Check these plots out I did back in 2009.  You'll be able to see why it all depends on the location in Springfield as to what is the best option.
Bouddi (West part of Springfield is in the shadow of Mt Kincumber)
http://www.dtvforum.info/uploads/monthly_10_2009/post-88880-1256426165.jpeg
Forresters (May be possible on the eastern side and the higher western parts.
http://www.dtvforum.info/uploads/monthly_10_2009/post-88880-1256426206.jpeg
Rumbalara (Most of Springfield is in a shadow)
http://www.dtvforum.info/uploads/monthly_10_2009/post-88880-1256426265.jpeg
Colin
Edited by CMatten
21 hours ago, CMatten said:
Hi James
Colin
Hi Colin
Yes indeed.
One of the things we use is coverage overlap map showing the combination of the three local transmitters plus Sydney. It clearly shows residences in the same street can have field strength differences more than 24dB, Waratah St being a fine example, I think your attachments will certainly help Adrian sort his options.
James
4 hours ago, James T Kirk said:
Hi Colin
Yes indeed.
James
I wouldn't rely on the level in these maps as it was a hack I did. Also, they are based on omni directional pattern which isn't the pattern at each transmitter.
Since i last looked, the ABC have updated their reception maps. http://reception.abc.net.au/Reception.aspx
Hi Colin
Genuinely I understand however I would not be too concerned about your "hacks" the HRP's for these sites on the Springfield bearing.
Although they certainly are not omni-directional, in the direction of Springfield are:
Bouddi (V) is -3dB ERPmax (640W)
Rumbalara (H) is on ERPmax (300W)
Forresters  (V) is -8dB ERPmax (200W)
James
Installed my last 9 metre mast over 15 years ago. Couldn't do it by myself now as my shoulders are shot.
I wouldn't even bother now that VAST is here, I'm thinking the cost of labour, masting, antennas, amplifiers, planning approval etc. would outweigh a dish & a couple of decoders.
I've tried stacking phased arrays(or using pre-built arrays) in areas of diffuse horizontally polarised signal before & found the performance is not necessarily better than a single unit, or a long yagi, even though horizontal stacking of the phased array should sharpen the directivity in the horizontal plane, & reduce some of the garbage that can be captured.
Edited by I am not a duck
Reason: Just curious.
Agree, sometimes using VAST is the cheaper / more reliable solution. Only problem is the ads are for sheep dip in Mt Isa ;-)
  • Similar Content
    • By BelindaMaree
      Please help?
      I have attached the pic so you can see what I'm after
      please help
    • By vanderblitz
      Hello,
      I'm looking for a reputable TV antenna installer for a new single story house, with colorbond roof in Williams Landing suburb (west of Melbourne)
      Any recommendations?
    • By prashant75
      Hi there,
      I am not very expert in TV technology and i really need your advice. I have a Samsung Smart TV 7 series (bought in Dubai) and i am not able to get Free-to-Air Channels. I dont have any STB and no pay tv like Foxtel etc. I am not a big TV buff but want to watch free channels. I tried to setup using auto-tune and manual tune, but no luck. Also, there is something called "Area/Region" for setting channel in TV and i dont have "Australia" option in the list. I live in an apartment and each unit has a point to connect. Most of the people in my building are receving good signal and able to watch free channels.
      I called Samsung support and they said my tv doesn't has/support Australia frequency. They advised me to check with local retail shops or buy new TV.
      I dont want to buy new tv. does it work if i buy a Set up box such as Dick Smith HD Digital Set Top Box with USB PVR.
      I really need your advice.
      Thanks in advance.
      Pras
    • By Dexx
      I have a TV in a room where an external antenna connection isnt possible. Can you recommend a cheap indoor antenna which works ok in a medium signal area? VHF primarily.
    • By calichin
      recently moved to a new house in the eastern suburbs of melbourne. The house has an external antenna and I assume it was working for the previous owner. When I plug the TV directly to the wall socket, I get ~8-9% of signal strength on the TV (did I mentioned the antenna is on the roof?). When I plug the PVR to the wall socket (and then the TV through HDMI) I get no signal at all. The "passthrough" of the PVR also gives no signal to the TV. With the 8-9% I can watch some TV, but I get a lot of freezing. Interestingly, I plug an old "rabbit" antenna to the TV or the PVR and I get ~50% of signal strength.
      I'm trying to sort out where the issue could be. I have:
      confirmed that the wall socket is connected (behind the plate)
      the cable runs to the roof
      the cables in the roof are connected to the antenna.
      I should give a bit more info:
      there's one cable coming down from the antenna and then there's a splitter (a simple small one maybe 2cm x2cm): 1 in, 2 out.
      one of those "out" goes into a room but I don't have a spare tv to test, and moving the large tv is not an option.
      the other out goes to another splitter, but this has some sort of circuit board. there's no splitting happening as there's only one in and one out (but more out could be used). Then after this second splitter, there's a third one similar to the previous, a small box where one comes in and 2 comes out, also with some sort of electronics in there.
      There's only 1 tv in all the house, if there are other TV sockets, they aren't used.
      I've gone as far as I can understand, so I came here for help. Should I eliminate all the extra splitters? replace them with new ones (looks a bit old and dusty)? is it worth buying one of those antenna meters to test the signal strength?
      (like this: http://www.jaycar.com.au/productView.asp?ID=LT3332)
      I haven't climbed to the roof yet. Is there some sort of connector at the roof that might be loose? I'm trying to figure out if the issue could be somewhere else before adventuring to the roof.
      Any help or suggestion would be greatly appreciated.
    • By uanmi
      I have a TV antenna and above it is an old antenna that has broken and part is hanging down onto the other antenna. On a windy day they bang together and this causes dropouts.
      I would like to also get two more tv points in two rooms that don't currently have TV points.
      I have been using an indoor antenna in one room and it does not get channel 1, 10, etc. This is quite frustrating as I enjoy some of the shows on that channel.
      I would apppreciate an indication of what the cost would be.
      regards, Mark
    • By Matthew Bongiolatti
      Hey guys,
      After cancelling foxtel due to not really watching the channels apart from free to air, i found that i was missing having the ability to record tv, so being new to HDTV recorders i did alot of research into which system suited me best. I settled on a Topfield TRF7160 and bought one for a great price at JB HiFi.
      Went to install the new PVR and this is when the strange issues occured. This is what i did:
      Unplugged the coax from the tv and plugged into the antenna in port of the pvr.
      Plugged in HDMI, TOSLINK, ethernet & power in. All Ok
      Turned on tv & pvr, went through the setup scan of channels to which the unit found none. Puzzled, as my HD TV with in builtin HD tuner works perfectly fine, i started to fiddle with the cable. After no more luck, i came to the conclusion that somehow my existing cheap coax cable was faulty and bought a new $40 one from Jb HiFi. No luck.
      I then plugged in a portable powered rabbits ears that i use in the spare room (which works ok), and ran the scan again. The toppy picked up SBS stations but nothing else, tested the channels to which were working. I then plugged the wall coax back in and found that is lost signal straight away. Plugged it directly back into the TV which worked fine on all channels.
      Thinking that there may be something strange going on with the coax port on the toppy, i loosely plugged it back into the toppy and i started to get a picture.. I then ran the toppy through a channel scan again and it found all channels with 90+ reception.
      At this point i settled on there must be something wrong with the unit and returned it to JB. Brought new one home today and same problem exists.. I have found that as long as the coax cable is loosely touching (or even not touching by around 2-3mm) the signal is perfect.
      I have no idea why this is happening but was wondering whether anyone had any ideas, as the way it is set up now is not ideal?
      Cheers in advance and apologies for the essay, but i thought as much info that i can give will help.
