Iq2 And Multi Roon Installation Query
Posted 08 February 2012 - 08:23 AM
Getting a new installation today with a HD Iq and multi room. We have your standard living room set up with a 42" SD plasma and middle of the road surround set up. We also have a dedicated HT room with a projector and scope screen which I want to watch the HD footy and occasional movie or doco in.
My question is this. Which room should I put the Iq in and which should get the multi-room box? I assume the multi room box will pass through what ever definition is native to the channel being watched? Can you "stream" recorded HD files from the Iq to the multi room box? If so I would get the Iq in the family room. If not the Iq goes in the HT room.
Posted 08 February 2012 - 10:21 AM
Your decription suggests you are getting one iQHD box and a standard box. Is that what you are calling the 'multiroom' box... just a standard Foxtel decoder... not iQ?
PQ definition is dependent on your subscription and equipment capabilities. Eg: you won't get any HD channels on a standard box and a standard box doesn't have PVR functions.
I don't think you can stream from an iQ to a standard box.
Posted 08 February 2012 - 10:36 AM
I've signed up for HD and was hoping a HD set top box for the secondary room would work much like my Beyonwiz Dp-H1 does to receive files from the P1 in my HT room.
As per usual the people signing you up obviously don't know their own products well enough to explain what it can and can't do. I signed up making it more than clear that if possible I'd like a HD channels ONLY subscription and that I was paying for the basic and sports packages through gritted teeth as I won't put up with non HD to my projector. I had foxtel years ago and SD foxtel used to look awful on my old 28" 4:3 CRT, can't imagine how bad it would look on a 42" plasma. I only used a handful of channels back in the day and can't see that changing now
Multi room is a $15 a month fee to use a second "box" but I'm getting free installation. I assumed it would at least be a HD set top box as that is part of my subscription and streaming would also seem to be a capability they would incorporate if possible. Hopefully I get a friendly installer and we can get it to best of the capabilities of their equipment.
Edited by blybo, 08 February 2012 - 10:38 AM.
Posted 08 February 2012 - 12:18 PM
I wouldn't 'assume' anything with Foxtel.
Unless your 'deal' specifically states your second box is iQHD, it's likely to be a standard box, not even iQ.
Don't leave it until the installer arrives, as he'll only install what is on his order.
And yes... SD looks horrible on a big screen.
I'd recommend contacting Foxtel prior to the installation to confirm exactly what your equipment and your subscription includes.
Posted 08 February 2012 - 01:22 PM
I'm also going to have to source and install a conduit/skirting board to hold about 2.5 of cable.
Edited by lizclinton, 08 February 2012 - 01:26 PM.
Posted 08 February 2012 - 05:30 PM
lizclinton, on 08 February 2012 - 01:22 PM, said:
It varies, some people are still getting SD boxes installed and others, as you said, get the 'nobbled' iQ box.
Posted 08 February 2012 - 07:12 PM
cheers laurie
Posted 08 February 2012 - 10:26 PM
laurie, on 08 February 2012 - 07:12 PM, said:
cheers laurie
And only paying the $15 fee? HD IQ? I got a set top box but will be ordering something with hdmi out, why put up with inferior picture if I don't have to...
Posted 09 February 2012 - 01:19 AM
blybo, on 08 February 2012 - 10:26 PM, said:
There's often published deals.... and then ones you 'negotiate' with Foxtel.
If you don't haggle.... you get the standard offer at the time of signing up.
If you ask to cancel, they usually try and entice you to stay with something 'extra'..... but that depends if you're locked into a contact or not.
