Hi Helen,
I had a look at the acer website (its globally based and you can switch around countries as you want). Warranty info is found via the MODELS tab when looking at specific series. Travelling the globe it looks like the warranty varies from country to country (in the USA its one year only) but most areas seem to have two years standard. Australia doesn't have a seperate DMD clause in its warranty, but as you notice the Phillipenes does
here.
I was sceptical of a possible Statutory Warranty claim however if it can be shown that a specific five year waranty is offered in other countries for the DMD specifically then I'd say you have a good prima facie case that you'd have a reasonable expectation your's would last that long at least. You could write to Acer and request they replace the part mentioning their statutory resonsibility and see what they say. If not then getting it adjudicated should cost under $50 - just takes a fair while and no guarantee of success.
As an alternative, it appears the model DMD chip you need is the DMD8060-6038b. Cost would be $166 from
eBay to by one yourself (or $150
here). I don't know how easy it is to replace it for a non tech - although the
service manual gives good instructions and makes it look pretty straight forward. FWIW I don'tt imagine a repair store would charge more than $50 and they'd likely do it on the spot.
Disclaimer: All info provided as is. Check anything you're unsure about.
