Price: $1800 ono
Item Condition: As-New
Reason for selling: More Features than I need
Payment Method: Pickup prefered with cash payment or will post/courier at buyers expense
Extra Info:
As-New, purchased new from a Sydney HiFi store in late Feb 2011, comes with balance of Australian 3 year warranty (will provide original receipt with sale). Comes with all original packaging, remote, Audyssey room calibration mic, AM/FM antennas, owners manual and power cable. I'm also including seperately purchased as-new Onkyo UP-A1 Ipod dock and UP-DT1 DAB+ Digital Radio module that integrate seamlessly with the Onkyo PR-SC5507.
Basically considering selling it as it has way more features than I use and alot of the additional features I already have in other devices such as HTPC, Squeezebox for internet radio etc. Will probably go back to an simpler Rotel or Emotivia AV pre-amp. It is currently connected upto a couple of high quality Elektra Power amps (not included), so you are free to select your own brand etc and connect up with either unbalanced or balanced cables.
Below is the general specs from Onkyo and links the user manual, spec sheets, user reviews etc. As far as I can tell it is pretty much fully upto date to the current Onkyo 5509 model recently released except for ARC HDMI 1.4 return but if you have a half decent Blu Ray player such as a Oppo 93/95 etc its probably irrelevant as it will already have dual 1.4 HDMI output for secondary connection to your 3D display. The original RRP in Australia was $4500 + about $500 for the extra Onkyo modules.
Inspection welcome:
Australian Distributors Web Site
http://www.ambertech.com.au/solutions/home-entertainment/home-cinema-hi-fi-personal-audio/onkyo---authorised-internet-dealer/pre--power-amplifier-components/pr-sc5507
http://www.ambertech.com.au/solutions/home-entertainment/home-cinema-hi-fi-personal-audio/onkyo/accessories/up-a1
Onkyo UP-DT! DAB+ Digital Radio module
http://www.ambertech.com.au/solutions/home-entertainment/home-cinema-hi-fi-personal-audio/onkyo/accessories/up-dt1
Other info/links – manuals etc
http://www.hitechreview.com/media-players/blu-ray-players/onkyo-launches-thx-certified-blu-ray-system/21174/
http://www.intl.onkyo.com/products/av_components/av_separates/pr-sc5507/index.html
http://www.intl.onkyo.com/downloads/product_info/pdf/pr-sc5507_ex_leaflet.pdf
http://www.intl.onkyo.com/downloads/manuals/pdf/pr-sc5507_manual_e.pdf
http://www.intl.onkyo.com/support/firmware/pr-sc5507.html
Reviews:
http://www.avsforum.com/avs-vb/showthread.php?t=1199778
http://www.smart-blogs.com/onkyo-prsc5507-home-cinema-amplifier-92-thx-ultra-2-certified.htm
http://forum.blu-ray.com/showthread.php?t=135031
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/home-cinema-systems/onkyo-thx-ultra2-system-685185/review
Manuafactures Specs:
Features
- THX® Ultra2 Plus™ Certified
- DTS-HD Master Audio™, DTS-HD High Resolution Audio™, Dolby® TrueHD, and Dolby® Digital Plus Decoding
- HDMI™ Version 1.3a to Support Deep Color™, x.v.Color™, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
- DSD Direct for Super Audio CD
- HDMI Video Upscaling to 1080p with HQV Reon-VX
- Audio and 1080p Video Processing via HDMI (1 Front/7 Rear Inputs and 2 Outputs [Main/Sub])
- Burr-Brown 192 kHz/32-Bit DACs (PCM1795 x 6) for All Channels
- Ultra-Low-Jitter PLL (Phase Locked Loop) Circuitry to Improve Audio Quality
- Three TI (Aureus™) 32-Bit DSP Chips (DA830 x 1, DA788 x 2) for Advanced Processing
- VLSC™ (Vector Linear Shaping Circuitry) for All Channels
- ISF (Imaging Science Foundation) Video Calibration
- Audyssey DSX™ and Dolby® Pro Logic® IIz for New Surround Channels
- Audyssey MultEQ™ XT to Correct Room Acoustic Problems and to Calibrate Speakers
- Audyssey Dynamic Volume™ to Maintain Optimal Listening Level and Dynamic Range
- Audyssey Dynamic EQ™ for Loudness Correction
- Dolby® Volume for Reference-Quality Listening Experience at Any Volume
- Network Capability for Streaming Audio Files (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, LPCM)
- Internet Radio Connectivity Through vTuner
- Certified with Windows 7 and DLNA Version 1.5
- Bi-Amping Capability
- Zone 2 and Zone 3 for Playback of Separate Sources in Other Rooms
- Zone 2 Monitor Outputs (Component and Composite Video) and Zone 2/3 Subwoofer Pre Outs
- D-sub (15 pin) Input for PC or Analog RGB
- Universal Port for Single-Cable Connection of Optional Onkyo Dock for the iPod
- 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG (Role Playing Game)
- 2 Independent Subwoofer Pre Outs220 W/Ch (6 Ohms, 1 kHz, 1 Channel Driven, IEC)
- WRAT (Wide Range Amplifier Technology)
- Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry to Remove Distortion
- All Discrete Output Stage Circuitry
- Massive Toroidal Transformer
- Two Large, Customized, 22,000 µF Capacitors for Effective Power Supply
- Audio-Tuned Reference Capacitors for Each Channel
- Large, Custom-Designed Power Transistors to Drive High Currents
- Low-Impedance, Copper Bus Plates for Perfect Ground Potential
- High-Current, Low-Impedance Circuit Boards with Thick Copper Foil (70 µm)
- Flat, High-Rigidity, Anti-Resonant Chassis
- Gold-Plated XLR Inputs
- Machined Solid Brass RCA Inputs
- Gold-Plated, Color-Coded, Banana Plug-Compatible, Transparent Speaker Posts
- Multi-Zone Capability (up to Zone 3)*
- Bi-Amping Capability*
- 12 V Trigger Input
- Auto Power Down Function
- Aluminum Front Panel
Edited by JDH, 05 February 2012 - 06:27 PM.
