Iq2 Freezing
15 replies to this topic
#1 blacklikesunday
blacklikesunday
  • 681 posts
Posted 04 February 2012 - 01:10 AM
everything i record nowadays ends up freezing in various points in the programme and then jumping ahead a little.
is it time to ring for a new one, or is there something i can do here at home?
#2 BamBBBam
BamBBBam
  • 1,004 posts
Posted 04 February 2012 - 01:32 AM
Are you running the latest software? This was a problem in the last release.
Current is sat 116.2.8.2.4.28
#3 mtv
  • 6,042 posts
Posted 04 February 2012 - 09:19 AM
That's the most-likely culprit.
Lots of similar issues happening to iQ/2's everywhere after the last firmware update.
Report the fault to Foxtel (they'll probably be expecting your call)  :)
#4 blacklikesunday
blacklikesunday
  • 681 posts
Posted 04 February 2012 - 12:56 PM
its 104.2.8.1.6.26.
how do i get the latest?
#5 chewygumby
chewygumby
  • 67 posts
Posted 04 February 2012 - 02:25 PM
View Postbrent ford, on 04 February 2012 - 12:56 PM, said:
its 104.2.8.1.6.26.
Press and hold select + back buttons until all lights light up.
Release and wait until all lights light up a second time and then press the power button, up arrow, down arrow and power button again on the box.
#6 blacklikesunday
blacklikesunday
  • 681 posts
Posted 06 February 2012 - 03:53 PM
i thought you were joking!
so exactly which buttons?
#7 stak
stak
  • 5 posts
Posted 09 February 2012 - 03:53 PM
I had my iQHD box doing the same freezing thing.  I noticed that various parts of the box were getting extreemly hot (quite ironic, really).  I attached a quiet PC fan to the side of the box and now it runs a lot cooler and I seldom get the freezing (seen it once since).  I don't like what extreem heat does to electronics over time.  Other than that, love the 1TB box.
#8 miata
miata
  • 1,553 posts
Posted 09 February 2012 - 07:04 PM
Look a couple of posts up, he told you exactly which buttons. Print it out and keep it, it works every time.
#9 blacklikesunday
blacklikesunday
  • 681 posts
Posted 11 February 2012 - 11:24 PM
well i pressed the buttons and the set made a bit of a whirring sound but nothing came up on the screen. i've checked the version again and its still 104.2.8.1.6.26.
#10 Daran Murphy
Daran Murphy
Posted 12 February 2012 - 12:23 PM
It took me a few goes but the above actions actually work.
#11 redhenry
redhenry
  • 245 posts
Posted 13 February 2012 - 03:16 PM
They certainly do work but make sure all the button presses are on the box itself, not the remote!
#12 blacklikesunday
blacklikesunday
  • 681 posts
Posted 19 February 2012 - 11:57 PM
sometimes in the early hours of the morning the iq starts making noise and turns off and on. i always presumed that was when the software was being updated?
#13 redhenry
redhenry
  • 245 posts
Posted 21 February 2012 - 03:50 PM
This is pretty much when most upgrades are carried out.
#14 blacklikesunday
blacklikesunday
  • 681 posts
Posted 21 February 2012 - 07:29 PM
so does that mean there is no need to manually upgrade and push all those buttons?
#15 BamBBBam
BamBBBam
  • 1,004 posts
Posted 21 February 2012 - 11:39 PM
Or the default power saving settings kicking in.
#16 redhenry
redhenry
  • 245 posts
Posted 23 February 2012 - 12:10 PM
No. Unless you haven't got the latest software version and are in some sort of hurry. They will get to you eventually. I only got the latest version less than a week ago whereas my work colleagues have had it for weeks.
Edited by redhenry, 23 February 2012 - 12:11 PM.
