Projector Screens : Lp Morgan Galleria Deluxe Vs Majestic Evo Hd
23 replies to this topic
#1 jch
jch
  • 9 posts
Posted 23 January 2012 - 10:29 AM
Thinking to get a 100" 16:9 fixed screen.
What are your opinions on LP Morgan Galleria Deluxe and Majestic Evo HD screen?
Any other suggestions?
Thanks!
JM
#2 bbar
bbar
  • 6,809 posts
Posted 23 January 2012 - 02:15 PM
Thanks!
JM
Both are excellent and Screen Technics are also good in that price range.
If you want to double your price range then Stewart Filmscreen make a great screen.
#3 Magicland
Magicland
  • 29 posts
Posted 26 January 2012 - 10:48 AM
Thanks!
JM
I'm debating this very decision too. I've not seen the LP Morgan up close yet. Does anyone know if this screen has a brand logo or similar anywhere on the frame? Every picture I've seen of these online appear to show a silver LP Morgan badge in the bottom right of the frame. A minor thing but I'm not into that as it may present a distraction.
Thanks.
#4 jch
jch
  • 9 posts
Posted 14 February 2012 - 12:19 PM
Received my ordered 106" Majestic Evo HD screen yesterday.
What surprised me is the "screen" wasn't come in 1 assembled piece.  It came in "Parts" : a roll of screen fabric, 4 frame strips, 4 fabric tightening plastic strips etc..
When I bought my 70" Screentechnics screen 10yr ago, it came in 1 piece.  I didn't expect I have to assemble the screen myself this time.  I browsed http://www.projectorscreens.com.au/ quite a number of times, but didn't pick up any "footnote" indicating that user assemble is required.  I haven't asked whether user assemble is required when I ordered the screen.  I just assumed it is.
My worry is I am not too sure I have the skill to mount the screen fabric flat onto the frame without crease and any potential damages on the fabric during the mounting process. I am a bit nervous for undertaking such a task.
Are big screens (>100") from other major suppliers also require user assemble?
Edited by jch, 14 February 2012 - 12:28 PM.
#5 SDL
SDL
  • 10,540 posts
Posted 14 February 2012 - 12:41 PM
My Stewart screen needed to be assembled (doubt they could have shipped from the US any other way) and I think most actually do need assembly, rare to find one that doesn't I would think as it is a bit hard to transport.
#6 oztheatre
oztheatre
  • 3,190 posts
Posted 14 February 2012 - 02:16 PM
Sorry for any confusion mate. The install manual is on the main screen website www.ozts.com.au not on the projector screens site, that is the online store.
If you're not comfortable installing the screen then I suggest getting an installer to do it for you, though most people will put their own screen together.
If you get a crease in the material, don't worry. the bottom end of the strips are rounded so you can simply pull it up and re insert. It has been carefully designed around kit form for the end user so you should be able to do it.
They cannot be shipped already made up, freight would cost a fortune and we already pay very steep prices for everyones freight as it is. Couriers would also destroy them in transit. Keep in touch and let me know how it goes ok.
#7 davep
davep
  • 3,417 posts
Posted 14 February 2012 - 02:25 PM
Yup, they're reasonably easy to assemble.  Just take your time and follow the instructions.  If not already in teh instructions (been so long since I assembled mine), i'd recommend having a rubber mallet to tap in the strips, and also assemble on a soft surface e.g. carpet or on blankets, to prevent scuffing the front.
I still use the little box-cutter knife that came with the assembly kit :P
#8 mr 32
mr 32
  • 28 posts
Posted 14 February 2012 - 02:50 PM
im also looking at these screens but remote control electric, ive have just come across the cinescope ones from carson any input on these?
#9 jch
jch
  • 9 posts
Posted 19 February 2012 - 12:18 PM
I got my 2 sons to help me put together the screen yesterday.  It turned out that mounting the screen wasn't as skill demanding as I thought.  I managed to have a perfect mount in the first trial.  No need to pullout the fabric fixers and remounting.  However, pushing the fabric fixers into the frame was a rather labour "demanding" - my right arm is still a bit sore today.
The only nuisances are (1) 2 of the corner keepers couldn't stay onto the frames.  The kept popping out. (2) The manual says there are 2 types of corner plates (silver grub screws and black grub screws).  Mine are all with black grub screws.  Don't know why.
#10 oztheatre
oztheatre
  • 3,190 posts
Posted 19 February 2012 - 04:29 PM
Good to hear it went together well. Yes it looks a little daunting but once you start you get the hang of it pretty quickly. Sore thumbs is a bi product of my screen attachment method. I am actually looking to change it completely and will start testing out a new method soon.
Manual must need an update, all black screws now, sorry for any confusion.
If the corner keepers were popping out, I would assume you were pulling it too tight, but this is ok, it's vinyl afterall.
Hope it serves you well!
#11 Vieira4
Vieira4
  • 1,311 posts
Posted 22 February 2012 - 04:25 PM
Depending on the size yes the OZTS screen is a 2 person job to put together.  You will definitely need help to wall mount it and get it level also.  I had 2 screen technics screens prior to this and both needed assembly.  I assume for a size as small as 70% they come pre-assembled as that is still shippable.
#12 mmu16
mmu16
  • 331 posts
Posted 01 March 2012 - 11:34 AM
Hey all,
I just assembled a 140" evo 3D scope screen last weekend.  had my 10 Yr old brother help me! Similar experience to JCH. Few comments -
1) Yes, I never expected the screen required assembly.  I bought mine from Selby and no one even mentioned it.  Maybe its standard practice for HT professionals but a noob like myself would not expect this.  Would be beneficial to inform the customer at point of sale that the screen requires assembly.
2) Packaging was rock solid! Never seen a better packaged product! Took me ages to take it out!
3) Build quality of the screen is extremely impressive.  At first I thought the fidelio velvet thing was a marketing gimmick but now I see what the fuss is all about.  Its awesome and I cant stop touching it :phone:
4) Few suggestions about the instructions....the instructions come in softcopy format in a cd rom.  However it would be much preferable if it came in hardcopy format since you would want to have the instructions nearby when you assemble the screen!! Running between rooms where the pc is and where the install occurs is a pain.  luckily i downloaded it onto my tablet so it was a non-issue.  A video installation guide would be awesome!!  Oh yeah, faced the same conundrum re: silver and black grommets as per instruction manual....
5) The corner stops do jump out. either they need to be thicker at the locking end or it requires a change in design.
6) Actual installation was easy as pie! for such a huge screen I thought I bit more than i could chew but it was surprisingly easy to get a nice, flat, taut surface.  But you do need to follow the instructions down to the letter (especially the tapping directions - start and end points) to get it perfect.  I mucked it up once where I did not follow the exact directions but a quick reset was all it required.
7) wall mounting was easy too, however a more secure method would be preferable.  I made 2 small L brackets for the bottom of the screen, one end screwed to the wall and a small screw drilling into the underside of the screen.  The screw under the screen, when tightened, pulls the top frame onto the supplied brackets. Now its rock solid.
All in all the process was not hard at all and the screen is of excellent quality.  cannot be happier!!!!
#13 Vieira4
Vieira4
  • 1,311 posts
Posted 02 March 2012 - 04:26 PM
Pre-assembled screens would obviously cost more as the manufacturer/seller would have to pass on this cost, and then postage costs would go through the roof as an assembled 140" scope screen is over 3m long.  Thats alot of packaging also.  Then of course it would be prone to damage.  Once that cardboard is pierced there goes your expensive screen material.
#14 MRCRIST
MRCRIST
  • 3,512 posts
Posted 02 March 2012 - 05:33 PM
The logistics let alone costs of transporting a fully assembled screen would create a nightmare for not only the receiver but also the seller.
The amount of returns due to damage would skyrocket hence such cost would have to be passed on to the buyer.
The current status quo is the only way these screens can be transported without sending people into a second mortgage.
#15 mmu16
mmu16
  • 331 posts
Posted 02 March 2012 - 05:42 PM
Completely agree re: comments about packaging costs if the screenwas pre assembled, however it would be good to inform the customer about assembly at point of sale.
#16 dan76n
dan76n
  • 403 posts
Posted 03 March 2012 - 04:28 PM
You should be able to expect it clearly stated that assembly is required for any product that requires assembly regardless.
But in saying that, would you of still purchased the screen if you had known this?
I would say its just more of an inconveinience due to being unaware than an actual deal breaker in most cases.
#17 MRCRIST
MRCRIST
  • 3,512 posts
Posted 03 March 2012 - 05:32 PM
With most things  you purchase these days  assembly is a prerequisite. It is more the norm than exception. Big bulky items add significantly to the freight costs.It is becoming an IKEA world.
Edited by Crist, 03 March 2012 - 05:34 PM.
#18 mmu16
mmu16
  • 331 posts
Posted 05 March 2012 - 10:13 AM
Requiring assembly would not put me off the purchase, but it would have certainly helped in making preparations or conducting a bit more research into the matter.  It would have made an impact in the decision making process regarding hiring an installer or doing it alone etc. Its just good to know what you are getting into and I don't think its a big deal to let your customers know beforehand what the requirements are.
#19 MRCRIST
MRCRIST
  • 3,512 posts
Posted 05 March 2012 - 10:40 AM
Yes I agree. Assembly required should be on the website.
#20 Tweedledum
Tweedledum
  • 88 posts
Posted 07 March 2012 - 11:35 PM
Hi all, back in June 2010 I bought a brand new 120" motorised matt screen from a dealer in Sydney on Ebay., cost $182.0 plus $87.0 delivery by courier.....screen made in China of course.
The seller was called Blue_Tec.
The screen came completely assembled and has been hanging from the ceiling in my lounge for the last 2 years.
Nothing to report on the screen, apart from The Pirates Of The Carribean series is an awesome set of DVD's viewed on the big screen with surround sound.
Ian.
Edited by Tweedledum, 07 March 2012 - 11:38 PM.
#21 oztheatre
oztheatre
  • 3,190 posts
Posted 08 March 2012 - 01:19 AM
Ian.
They are talking about fixed screens that require assembly. I'm glad your motorised screen came assembled though, might have been a tough job putting that together!
#22 Tweedledum
Tweedledum
  • 88 posts
Posted 12 March 2012 - 11:48 PM
Oops, sorry for that, didn't read the first post properly.
wow I can quite see the need to assemble the fixed screen on site.....the 120" motorised one I have would need a truck to deliver it if it was reeled out to full depth.
Ian.
#23 SDL
SDL
  • 10,540 posts
Posted 13 March 2012 - 11:21 AM
mmu16 how would you have gotten the 140" screen into your house if it was assembled? Did you expect a flat bed truck to roll up also? Just some questions. I understand where you are coming from and perhaps dealers should say to buyers price with and without installation and explain what that means.
#24 mmu16
mmu16
  • 331 posts
Posted 13 March 2012 - 01:16 PM
Absolutely!!!! Fully expected a prime mover to roll up at my gates!
