First Full Hd 3d Projector Under $1500 Optoma Hd33
Posted 21 August 2011 - 10:11 PM
Posted 21 August 2011 - 10:22 PM
Posted 23 August 2011 - 05:18 PM
jeffpr, on Aug 23 2011, 04:51 PM, said:
Resolution Native 1080p (1920x1080) 2D/3D
http://www.optomausa...cts/detail/HD33
Posted 24 August 2011 - 02:17 PM
hirdylloydy, on Aug 24 2011, 02:02 PM, said:
Edited by MarkTecher, 24 August 2011 - 02:18 PM.
Posted 24 August 2011 - 02:24 PM
MSRP (USD) : $2,999
Brightness (Lumens) : 1800 ANSI
Contrast (Full On/Off) : 4000:1
Variable Iris: **
Audible Noise: 30.0 dB
Eco-Mode: 28.0 dB
Weight: 3.5 kg
Size (cm) (HxWxD) : 11 x 36 x 31
Std. Lens: Focus:
Manual
Zoom: Manual, 1.20:1
Throw Dist (m) : 1.5 - 10.0
Image Size (cm) : 96 - 765
Optional Lenses: No
Digital Zoom: **
Digital Keystone: Vertical
Lens Shift: No
Warranty: 1 Year
Performance:
H-Sync Range: 15.3 - 91.1kHz
V-Sync Range: 25 - 85Hz
3D Projector: 3D Ready
3D Glasses Type: Shutter
Compatibility:
HDTV: 720p, 1080i, 1080p/60
EDTV/480p: Yes
SDTV/480i: Yes
Component Video: Yes
Video: Yes
Digital Input: HDMI 1.4a
Computers: Yes
Display: Type:
2 cm DLP (1)
Color Wheel Segs: 6
Color Wheel Speed: **
Native: 1920x1080 Pixels
Maximum: 1920x1080 Pixels
Aspect Ratio: 16:9 (HD)
Light Source: Type:
230W Osram
Life: 3000 hours
Eco-Mode Life: 4000 hours
Quantity: 1
Speakers: No
Max Power: 330W
Voltage: 100V - 240V
FCC Class: **
Special: 3D Projection
RS232 Port
Status: Shipping
First Ship: Aug 2011
Posted 24 August 2011 - 06:10 PM
Posted 24 August 2011 - 10:02 PM
I note that 120Hz falls short of the 144Hz (72Hz per eye) of RealD commercial cinema projectors. Not only is the RealD rate faster, but it is a multiple of 24fps, permitting original Left and Right images of a 24fps source to be projected without pull down or other manipulation.
This budget Optoma 3D projector will be competing against Panasonic's rather more expensive 3D projector offerings, the PT-AT5000 [Europe] and PT-AE7000 [USA] models, which operate at 480Hz. The PT-AT5000 ships to Europe in September 2011, for a sub-£3k RRP. [These first Pansonic 3D projector models use LCD technology. Whether Panasonic have really succeeded in keeping cross-talk low, while maintaining good brightness and at a higher than usual shutter glasses alternation rate, remains to be carefully scrutinised by professional reviewers prepared to conduct careful testing. I for one will will be very interested in the results of such testing. I find 120 Hz too low for my eyesight as a 3D alternation rate.]
Posted 24 August 2011 - 10:27 PM
bumassager, on Aug 24 2011, 06:10 PM, said:
Posted 25 August 2011 - 11:59 AM
Posted 26 August 2011 - 03:34 AM
http://www.avsforum....29#post20833329
The colourwheel may be/seems compatible with 120hz if it is in fact rgb/rgb ?? Would help explain the much better 'cinema 2d' calibrated 3d light compared to 1st gen 3d projectors[not to mention the new panny 3d when calibrated]. The dearer ones look nice too
Posted 26 August 2011 - 11:40 AM
AVS Forum post of 17AUG2011 said:
"It can take 720p at 120Hz signal and internally upconvert to 1080p 120hz but it cannot take 1080p at 120Hz signal from external source –not part of HDMI 1,4a 3D format
– current Bu-ray 3D format is frame packing 1080p at 24 Hz – as according to HDMI 1.4a – user has the choice to keep it at 24 Hz or add frame interpolation."
Some LCD panels operate at 480HZ but the method of operation can be complicated. Although 480Hz might appear to imply a 3D alternation rate of 240Hz this is not necessarily so. In order to reduce ghosting to an acceptable level, such a panel could alternate L and R frames for 3D purposes at only 120Hz and use some of the extra frame rate capacity to insert blank frames.
I discuss my own lack of comfort with watching 3D at a 100Hz (Australian 50fps material) or a 120Hz rate (e.g. movies at 24p) in the thread: 3d Shutter Glasses And Their Effect On Perception Of Motion.
Posted 26 August 2011 - 05:57 PM
MLXXX, on Aug 26 2011, 11:40 AM, said:
I wonder why more projectors dont use polarised glasses ; nothings hardly compatible until the new standards are introduced it seems
#19
Posted 26 August 2011 - 09:07 PM
cwt, on Aug 26 2011, 05:57 PM, said:
1. Requires addition of polariser at the light output of the projector that can rapidly change state in time with the alternation of Left and Right frame images produced by the light engine of the projector.
2. Requires slivered screen to maintain polarisation of the light when reflected back to the audience.
1. Requires infra red or other emitter to send synchronising pulses to shutter glasses in time with the alternation of Left and Right frame images produced by the light engine of the projector.
If the viewing audience is small, shutter glasses may provide the cheaper solution.An alternative approach with polarised glasses is using dual projectors with a fixed polarisation for each projector, e.g. the LG CF3D which involves two projectors in the one housing sharing a common lens.
Posted 27 August 2011 - 05:06 AM
Infitec stands for interference filter technology. Special interference filters in the glasses and in the projector form the main item of technology and have given it this name. The filters divide the visible color spectrum into six narrow bands - two in the red region, two in the green region, and two in the blue region (called R1, R2, G1, G2, B1 and B2 for the purposes of this description). The R1, G1 and B1 bands are used for one eye image, and R2, G2, B2 for the other eye. The human eye is largely insensitive to such fine spectral differences so this technique is able to generate full-color 3D images with only slight color differences between the two eyes. No special type of projection screen required.
#21
Posted 27 August 2011 - 10:07 AM
cwt, on Aug 27 2011, 05:06 AM, said:
As for the Dolby 3D infitec method, with its narrow band filters, this doesn't seem to be available cheaply for home cinemas although it allows use of a standard screen. I'd need to be persuaded it didn't affect colour too much.
#23
Posted 28 August 2011 - 07:04 PM
#24
Posted 28 August 2011 - 07:59 PM
That is why it is removable for 2D. There is a colour change, but it is so slight I doubt you could tell from video on screen alone. You will see it when looking at light from another source though.
#25
Posted 16 October 2011 - 08:39 PM
pheggie, on Aug 25 2011, 04:17 PM, said:
Anyone seen any good deals for a locally sold HD33?
Any interest in a group buy?
At time of writing the dollar is back up to $1.03 yet Aus retailers are still asking $2300ish.
Anyone got any leads on a cracking deal?
