Toshiba Multi Region Blu Ray Player - Great Price
77 replies to this topic
#1 manphibian
manphibian
  • 144 posts
Posted 06 July 2011 - 11:09 PM
Just bought Toshiba BDX3100KY
There are instructions in the box showing how to change region on both DVD and Blu Ray
RRP $249
Enjoy gents
#2 yorac
yorac
  • 22,553 posts
Posted 07 July 2011 - 08:50 AM
RRP $249
Enjoy gents
Would be great if you could give a review of this sometime down the line for everyone............. B)
#3 Trigg
Trigg
  • 2,893 posts
Posted 07 July 2011 - 10:11 AM
RRP $249
Enjoy gents
What are the instructions to change regions?
I'd be interested to know.
cheers
#4 manphibian
manphibian
  • 144 posts
Posted 11 July 2011 - 11:03 PM
cheers
While Player is on
press setup then enter 8250
new menu will appear
set bd zone 1=A 2=B 4=C
#5 neuty
neuty
  • 650 posts
Posted 12 July 2011 - 03:12 AM
Is the region hack permanent for dvd and bd?
is there a region free selection for dvd and bd?
thanks
neuty
#6 pietro
pietro
  • 2,572 posts
Posted 12 July 2011 - 08:05 AM
If Tosh has done this, surely the others will follow.
#7 yorac
yorac
  • 22,553 posts
Posted 12 July 2011 - 08:41 AM
Think you'll find it's a bit of Tosh gamesmanship and payback going on but hopeful that it may occur with others at some stage..........
#8 DenonCi
DenonCi
  • 779 posts
Posted 12 July 2011 - 03:06 PM
Is it like the Soniq Blu-ray player????
#9 Anden
Anden
  • 891 posts
Posted 12 July 2011 - 03:58 PM
View Postmanphibian, on Jul 11 2011, 11:03 PM, said:
While Player is on
Will this hack be retained with inevitable firm ware updates.
#10 Polarbear08
Polarbear08
  • 60 posts
Posted 12 July 2011 - 07:45 PM
Has anyone tested if it works? I'm especially interested in the blu-ray part.
#11 Trigg
Trigg
  • 2,893 posts
Posted 12 July 2011 - 09:24 PM
Be a handy player for the bedroom!
Edited by Trigg, 12 July 2011 - 09:24 PM.
#12 tonyjg
tonyjg
  • 3,012 posts
Posted 05 August 2011 - 08:53 AM
RRP $249
Enjoy gents
TOSHIBA BDX1200KY
$249 ??  the RRP on their site is $159 !!   bit of a price change from the original 6 July 2011 post to 5 August 2011 :)
By the way - any test results on this player - with regards to the region - or is it like other players, having to manually change the region each time ?
***  wondering why this is in this thread and not the Blu one ???  makes it a bit 'harder' when looking for deals ********
Edited by tonyjg, 05 August 2011 - 08:56 AM.
#13 victortubeman
victortubeman
  • 395 posts
Posted 07 August 2011 - 09:50 AM
View Posttonyjg, on Aug 5 2011, 08:53 AM, said:
TOSHIBA BDX1200KY
Rrp for the bdx3200ky is $199 , I picked up one last Wk for my 2nd system.
DVD is multi region out of the box( like most players )
Bluray multi region does work (got a friend who uses it with USA blurays)
  Cheers victor.
#14 Polarbear08
Polarbear08
  • 60 posts
Posted 09 August 2011 - 10:47 PM
Cheers victor.
Is there a firmware CD included in the box? I suspect that maybe you need to install Australian firmware on the European units (BDX3200KE) to make them regionfree. I can't find any firmware for this model on the Australian Toshiba website, so I was hoping that there is a CD included with the one you bought and maybe a possibility to get a copy.
Does anyone know if the same regionfree setup applies to TOSHIBA BDX1100KY? Or is it only the BDX3100KY/BDX3200KY that is regionfree?
Edited by Polarbear08, 10 August 2011 - 02:57 AM.
#15 john-andrew
john-andrew
  • 418 posts
Posted 20 August 2011 - 07:55 PM
TOSHIBA BDX1200KY
I got mine for $140 and cheap.
You still need to setup to make it region free on instructions provided.
I can confirm you can make it region switching on instructions provided. Anyway, mine is always set to be region 'A'.
While Player is on
This is the setup and after a firmware update on a disc provided in the box.
Yes, permanent or fixed as long as you like.
Mine is included in the box with instructions to set afterwards.
I am not sure and mine is Toshiba BDX1200KY.
Edited by john-andrew, 20 August 2011 - 08:25 PM.
#16 neuty
neuty
  • 650 posts
Posted 26 August 2011 - 09:39 PM
This is now confirmed that you can flash the Australian firmware onto a European player to make it multi region for dvd and Bluray.
neuty
#17 Polarbear08
Polarbear08
  • 60 posts
Posted 26 August 2011 - 10:19 PM
In the sharing spirit of this forum, could anyone copy the file(s) on the BDX3200 regionfree firmware CD and make it available for download? :)
Edited by Polarbear08, 27 August 2011 - 04:55 PM.
#18 neuty
neuty
  • 650 posts
Posted 29 August 2011 - 04:33 PM
I would also like to ask, if any kind soul would like to make a copy of the files from there region free firmware disc (use IMGBURN is best) and upload to a suitable place.
The BDX3200 and the BDX1100 would be great.
This is Greatly appreciated.
neuty
#19 neuty
neuty
  • 650 posts
Posted 10 September 2011 - 05:51 AM
Anyone feeling in a generous mood and would like to post up the region free firmwares for the above players?
Thanks.
neuty
#20 BenjaminG
BenjaminG
  • 762 posts
Posted 06 October 2011 - 01:53 PM
Hi all, I would be interested in this if I can make it multi-region, can anyone help?
Ben
#21 Polarbear08
Polarbear08
  • 60 posts
Posted 06 October 2011 - 04:23 PM
Ben
Which model are you thinking of?
Edited by Polarbear08, 06 October 2011 - 04:23 PM.
#22 exmobi
exmobi
Posted 20 December 2011 - 08:29 PM
Thanks for the comments. Read all as guest. Purchased bdx1200ky ($88 ) on strength of your info. Not disappointed,  played DVD straight out of box for a while, then hiccuped. Came with firmware CD and instructions. Installed and now have true multiregion DVD and switchable Blueray. Plays as good as any others, wife's happy!!! :P
#23 Vieira4
Vieira4
  • 1,311 posts
Posted 21 December 2011 - 06:59 AM
I picked up a 3200KY can't complain it loads quickly and the bd region change works a treat. 3D playback was superb too.  Waaaaaaaay cheaper than the equivalent Pana or Sony too!
#24 IanD
IanD
  • 2,373 posts
Posted 22 December 2011 - 12:02 AM
The 1200KY has an MC option called AVCHD which says something like: "plays BDMV folder".
Has anyone tried playing a Bluray BDMV folder within an AVCHD folder, as this sounds a lot like the Oppo 93 "AVCHD trick"?
Would be a great bonus if it works: Toshiba 1200KY the poor man's Oppo 93. ;)
#25 Richy Rich
Richy Rich
  • 56 posts
Posted 30 December 2011 - 11:56 PM
Just picked up one of these for $120.  Great price, considering it is multi zone for Blu Ray & plays 3D movies.
