Speakers For Sale Or Swap
3 replies to this topic
#1 petermanaena
petermanaena
  • 40 posts
Posted 12 January 2011 - 02:58 PM
I have a pair of JAMO D6 LCR THX wall speakers($1000 ono) and a JAMO D4CEN centre speaker (black) ($300 ono). Both as new, not used for 12 months, would concider swapping for a Yamaha YSP-4100/5100 digital sound projector (sound bar). Im going for in walls for the main system, room too small for ols speaker setup, the man cave needs a simpler setup ie the Yamaha sound bar, cheers Peter
#2 petermanaena
petermanaena
  • 40 posts
Posted 27 January 2011 - 08:59 AM
wow, cant believe not one person has looked at this thread?
#3 M'bozo
  • 2,673 posts
Posted 27 January 2011 - 09:36 AM
a) It's Tasmania, you expected better?  :D :D :D
B) More than one person has looked, it's just the "Views" part of the forum is broken.
#4 petermanaena
petermanaena
  • 40 posts
Posted 27 January 2011 - 11:37 AM
thanks for the up, yes your right, it is Tassie, a bit worried when you see 0 though,
cheers,Peter
