Digital Community Television Adelaide
Posted 31 October 2010 - 12:05 AM
Community TV Adelaide does not have the same coverage area as SBS.
Both CTS signals and SBS are radiated from Broadcast Australia Tower Summit Road CRAFERS.(Mt Lofty)
Effective radiated power from Mt Lofty. All transmissions are Horizontally polarised.
SBS28 analog 795 kW SBS33 digital 200 kW. Most digital transmitters are 1/4 of the analog power vor the same coverage area.
CTV31 analog 30 kW CTS30 7.5 kW.
To have the same coverage area as SBS, CTS needs to radiate 200 kW which will cost a lot more.
SBS61 Horizontal repeats their programs from 25 Grenfell St Adelaide to cover the foothills.
SBS61 Vertical repeats their programs from the Water Tower, Kettering Rd, Elizabeth South for Elizabeth South
SBS34 Vertical repeats their programs from Lot 100 Uley Road ELIZABETH DOWNS for Craigmore/Hillbank.
When the viewer asks the receiver to scan for channels and they have adequate signals from Mt Lofty, they should see channel 30. The receiver will then decode the Logical channel number 44 which is what the viewer uses to select your program.
For comparison SBS uses channels 33, 34, and 61 to transmit their programs. All of their transmitters sends out Logical Channel Numbers 3, 30, 32, 38 and 39 to identify the programs they transmit.
The advice to viewers should be if you can receive a good analog picture they should be able to receive your digital signal.
For more information: Get the best reception - Adelaide.
Channel 31 website
Posted 31 October 2010 - 03:48 PM
alanh, on Oct 31 2010, 01:05 AM, said:
Posted 31 October 2010 - 07:39 PM
Just did a channel scan and cannot see channel 44 or any new channels at all.
Will try again tomorrow.
Posted 05 November 2010 - 07:45 PM
Regards,
Will
Posted 27 November 2010 - 07:40 PM
Will Plumridge, on Nov 5 2010, 08:15 PM, said:
Help ! My TVs see it but TV Scheduler Pro doesn't (same antenna) ... Greenwith SA.
I think the frequency for channel 30 is 541250 Khz. I could add custom channel if I knew these things -
"Add Custom Channel"
Name
Frequency Khz
BandWidth 7 ?
Program ID
Video ID
Audio xxx and type (AC3, MPG)
A manual scan in that tool of 541250 does not find anything. Info and ideas appreciated.
Edited by halsboss, 27 November 2010 - 07:41 PM.
Posted 27 November 2010 - 08:19 PM
Channel 30 is 543500 kHz
All Australian channels are 7 MHz wide.
Sound MPG.
You don't need anything else.
If you still can't get a signal either there is a fault, or there is not enough signal.
The frequency you are trying to quote is for analog.
Posted 01 January 2011 - 07:23 PM
Posted 01 January 2011 - 10:55 PM
Ladybug2, on Jan 1 2011, 08:23 PM, said:
As far as I am aware, C31 is only transmitted from the main Mt Lofty transmitter.
Posted 02 January 2011 - 08:54 AM
mtv, on Jan 1 2011, 11:25 PM, said:
Thankyou. I had a feeling maybe that might be the case which is why I emailed C31 but nobody replied. So basically anyone who switched to the Elizabeth Downs tower has no hope of getting C31 unless somebody decides to transmit it from towers other than Mt Lofty?
Posted 02 January 2011 - 12:53 PM
Ladybug2, on Jan 2 2011, 09:54 AM, said:
Unfortunately, it's usually a matter of cost, funding additional transmitters for multiple translator sites that prohibits community broadcasters from doing so.
This is a common problem for community broadcasters in other cities too.
Posted 02 January 2011 - 03:34 PM
Hi
I don't think it is just cost but also a legal/licensing issue. I don't think the ACMA has been keen to license metro CTV analog (or digital) translators. The South Yarra CTV service from the Como building in Melbourne is the only CTV translator (installed quite a long time ago).
Posted 02 January 2011 - 09:53 PM
Posted 10 January 2011 - 10:57 PM
Posted 10 January 2011 - 11:00 PM
Line of Sight OK to Mt Lofty and other channels are all OK apart from SBS where the same thing happens occasionally - the picture goes all blocky everywhere with bright colours and the blocks travel all over the place, once that starts forget watching it for a while.
Anyone else get that too ?
Posted 11 January 2011 - 12:20 AM
We had that problem with a few channels, mainly HD ones but it didn't last a long time but it was recurring so it was pretty difficult to record anything without having it happen. There was also a screeching sound when it would start like a lightning flash. We switched to the Craigmore tower as it's not far from where we live and don't get it anymore. But in doing so we've lost C31.
Posted 11 January 2011 - 09:12 AM
Ladybug2, on Jan 11 2011, 12:50 AM, said:
Given we're on a hill with direct line of sight, one wonders how the populace fares and indeed whether C31 does sampling of areas and is even aware of the issue.
