Mystar Hd To 2 Tv's
2 replies to this topic
#1 toothy
toothy
  • 75 posts
Posted 29 October 2010 - 02:33 PM
Hi - is it possible to send the mystar hd box to another television in another room (I know i can only watch the same channel) via the av out (composite/rca) leads???
The back of the box uses the hdmi lead to my pioneer receiver.  But would it be possible to take advantage of the composite leads and run them to the av in of another tv?  I know i can get a picture through using an av sender through these leads - but it is pretty snowy and crackly....
thoughts?
#2 minty
minty
  • 738 posts
Posted 29 October 2010 - 07:11 PM
thoughts?
Toothy, you can no problem. My HDMystar is connected to my plasma via hdmi and optical to the AV receiver. I then run component and coax to the AV receiver in the cinema room next door. HD picture to both and 5.1 sound (when avaliable) to both systems with the option to just use the plasma speakers if i dont want to fire up the sound system in that room.
#3 toothy
toothy
  • 75 posts
Posted 01 November 2010 - 09:43 AM
thanks mate.
