Running Costs Plasma,led,lcd
Posted 28 March 2010 - 05:37 PM
I have found some old data but it is 2010 now. Old data has plasmas costs bout $50 a year more to run than LCD
Posted 28 March 2010 - 06:35 PM
I can’t see how $50 per year would be significant, even to someone on social security. Hell, you can run a 65” Plasma for about $130 a year or $2.50 a week so why be concerned about TV running costs?
Posted 28 March 2010 - 07:26 PM
Posted 28 March 2010 - 07:40 PM
Posted 28 March 2010 - 07:58 PM
There are plenty of ways to save MUCH more cash than a more “efficient” TV, its false economy. You can run that Plasma for 2 months for the price of a kebab.
Edited by Owen, 28 March 2010 - 08:04 PM.
Posted 28 March 2010 - 08:03 PM
Owen, on Mar 28 2010, 08:40 PM, said:
Posted 28 March 2010 - 08:07 PM
Posted 28 March 2010 - 08:12 PM
A saving is a saving, if it was a one dollar difference a day over the term of a full year guess what! $360.00 odd dollar saving.
pgdownload, on Mar 28 2010, 09:03 PM, said:
well we know what it means incase its an LG product dont we
yeah I cant beleive its around a dollar a week thats been quibbled about.
in reality it relates probably more to how much TV you actually watch. So perhaps best not to watch any TV at all and save another dollar a week !
Posted 28 March 2010 - 08:26 PM
Owen, on Mar 28 2010, 09:07 PM, said:
All i know is plasma on general day to day viewing will use up to twice the power of an LCD, the star ratings reflect that.
Evan a saving of $90.00 per year carried over 5 years is a saving of $ 450.00.
Edited by SHO, 28 March 2010 - 08:32 PM.
Posted 28 March 2010 - 08:30 PM
Since the running cost difference between a “LED” LCD and a Plasma of the same size is around 5 cents per day how do you expect to save $1 per day dude?
Posted 28 March 2010 - 08:40 PM
The 4 star rated air conditioner used 5000 watts (90 cents) per hour compared to the 4 star rated TV which used more like 170 watts (0.3 cents) per hour. Obviously the “star” rating gives no indication of actual running cost.
The “star” rating is an indication of relative efficiency compared to other similar products not an indication of actual running cost.
A 1 star difference in a high power consuption device like an air conditioner is worth much more in dollar terms than a 4 star difference in a low power consumption device like a TV.
Edited by Owen, 28 March 2010 - 08:49 PM.
Posted 28 March 2010 - 08:43 PM
Any savings you may make from say LCD over Plasma is more then offset with the price diff. So just buy something with good PQ and enjoy it, that is what TVs are for.
Posted 28 March 2010 - 10:01 PM
dlpnut, on Mar 28 2010, 09:43 PM, said:
I am just interested that is all.
Snyway when we are talking about plasma are we talking the new neo plasma or just plasma.
I was looking at neo plasma by Panasonic and the LED by SONY . IN a shop full of TV's the sony had far better quality but for a 46 inch I am looking at new neo plasma's. The energy rating for these guys was really poor.
Posted 28 March 2010 - 10:32 PM
Posted 28 March 2010 - 11:45 PM
Posted 29 March 2010 - 05:31 AM
If you base your purchase on power consumption rather than quality, you'll regret it within months!
On the other hand, how much power is whatever you are currently using consuming? You may actually SAVE money if you go to a 50" plasma as opposed to a 76cm CRT (Don't know, just a hypothetical).
I wouldn't base any purchase EVER on how much power it consumes, just buy 5 less BRs a year, smoke less, drink less, walk to the shop instead of drive, whatever you do, there's your saving
#19
Posted 29 March 2010 - 07:58 AM
Noted, the Panasonic website has quite a neat calculator that gives running costs of various models. Although I'd suspect it errs on the conservative side its likely representative.
Four hours viewing a day:
- a 37" LCD (4 stars) costs about $30 a year to run. A five star version would save another $7 a year.
- a 42" Plasma (2 stars) G10 costs about $55 a year to run. A three star version would save another $13 a year.
So yes, I wouldn't be factoring in running costs in making a purchase, I'd be finding the TV type and size (and PQ) that suited me - after that you're pretty much stuck with whatever star rating it has. If you turned off two 100W light bulbs while watching TV you'd cover your running costs.
That said, if you have a 65" plasma you like to leave on in the background half the day, that'll cost about $400 a year...
Edited by pgdownload, 29 March 2010 - 08:00 AM.
Posted 29 March 2010 - 08:30 AM
I'm all for green based energy but until it is supplied in a green way, we need to think about how much we use.
JSmith
edit: spelling
Edited by jsmith, 29 March 2010 - 09:19 AM.
#21
Posted 29 March 2010 - 08:39 AM
Having a lower bill is a good thing I guess, however the initial cost of the TV is kindda high. And depending on how long the TV last, and how much electricity costs in your state, the savings in power may not be enough to offset the "starting cost".
We use the TV alot.. ~5-6 hrs on weekdays and around 12-14hrs weekends
That said, there are other advantages, lower heat output, if you sit near the TV, and don't have A/C, this is really a really good thing to have..
#22
Posted 29 March 2010 - 08:40 AM
JSmith
#23
Posted 29 March 2010 - 08:46 AM
#24
Posted 29 March 2010 - 09:56 AM
jsmith, on Mar 29 2010, 09:40 AM, said:
JSmith
Over summer, actually even yesterday, our plasma was on, and the fans in it were working a bit to keep itself cool, I put my hands above the plasma and can understand why - they throw some heat!!
#25
Posted 29 March 2010 - 10:20 AM
