Sc10 And One Reception
2 replies to this topic
#1 rubaisport
rubaisport
  • 238 posts
Posted 06 March 2010 - 07:44 AM
For the last week or so I have not been able to receive SC10 or One HD on my Sony TV but have been able to receive it on my set top box. Is there anyone else having similar problems? or have they changed some settings for their channel?
#2 mtv
Posted 06 March 2010 - 09:42 AM
Networks are constantly 'fiddling' with encoding, so it's quite likely this is what has happened.
Some tuners adapt to changes automatically, others need to be manually re-scanned.
The most efficient method of re-scanning is to perform a factory default reset of the tuner, turn power off at the wall for a few seconds, power back on and perform a channel scan.
Let's know if that fixes it.
#3 gadget
gadget
  • 945 posts
Posted 08 March 2010 - 10:49 AM
In short no they have not changed any settings.
Depending on your location you may have the wrong channels tuned, please advise your suburb.
If your reception on SC10 is something that comes and goes it could be signal related. antenna may not be tuned correctly, wrong antenna, wrong cable, poor signal, too much signal, poor flylead, faulty wallplate. all of which could be causing your drama.
You need to look at your system to make sure all is ok with it, then we can eliminate all factors to get to the source of the trouble.
Gadget
