Deleting Programmes On A Dgtec Dg-hd320pvr
Posted 07 April 2009 - 11:07 AM
Posted 07 April 2009 - 12:55 PM
Edited by mddawson, 07 April 2009 - 10:53 PM.
Posted 03 May 2009 - 11:21 AM
Posted 12 May 2009 - 10:08 PM
Posted 14 May 2009 - 03:32 PM
Posted 14 May 2009 - 05:00 PM
Return it and buy something half decent, ie. anything else.
For example: http://www.aldi.com....s/2827_8312.htm
Edited by goldgxl, 14 May 2009 - 05:17 PM.
Posted 19 May 2009 - 02:15 PM
this should give you a quick progress bar showing you it's actually deleting the file.
I know, I know, logic and every computer known to man likes you to confirm with an ok button but this piece of crap is neither logical or useful.
I brought this piece of junk late last week and will be returning it for a refund or an upgrade to something that works.
In the time I've had it, it only seems to keep about 10% of the shows I've tried to record. Each day I would record 4 random shows at different times and different channels and at the end only have one of the show left to view.
The rest somehow simply just don't get kept, you can see them being recorded but they disappear along the way.
Luke
Posted 19 May 2009 - 09:35 PM
Posted 20 May 2009 - 08:38 AM
Taking it back today so if I don't get any problems doing that and manage to exchange it for say a Topfield then I'll be happy.
Posted 20 May 2009 - 06:57 PM
After using my new DG-HD320PVR for a week now, all seems perfectly normal with all operations, including deleting recorded programs. The EPG is accurate, recording setup is easy, deleting works....so far, all good.
Can I suggest that if you are buying one, make sure you buy the new model as on DGTEC's website.....NOT the old DODGYTEC model as sold at JB's currently. The new model is quite different in all ways to the old one. I got mine from H/N at $395 plus $49 for a full 5 year warranty.
Posted 22 May 2009 - 11:38 PM
Then it will say Warning. There are items with delete flag. Do you want to delete them? and "OK" will be highlighted, however with the color font they use, it looks like its the "Cancel" option that is highlighted...
You just hit "OK" and it deletes the file..
Try it.
I was making the mistake of thinking the "Cancel" option was highlighted when in fact the "Ok" option was.
Posted 22 May 2009 - 11:44 PM
Hi there David,
Please try the following prompts and keep me posted on the outcome.
-Press the MENU button
- Scroll down to PVR SETTINGS and Press OK
-Select RECORDED FILE LIST and press OK
- Select the files you wish to delete by pressing the RED button. A cross will be marked
next to the selected files.
- Press the EXIT button. A message will appear to confirm your request. Simply press the OK button again. Your files will automatically delete.
Give this a go and let me know the outcome.
Tony.E
