Hello,
I am thinking of purchasing the above mentioned tv. Could any of you indicate what they have paid for it?
Also, who knows who stock/supplies this tv in Adelaide?
Cheers!
Philips 42pfl9632d
vinvanmil
, Feb 03 2008 12:27 AM
3 replies to this topic
Posted 03 February 2008 - 12:27 AM
Posted 03 February 2008 - 01:21 AM
vinvanmil, on Feb 2 2008, 11:27 PM, said:
Hello,
Cheers!
Cheers!
vinvanmil
According to the hdtv prices listed on pbwiki, seems to be around the $2500. FYI, I paid for the 47" Philips 47PFL9632D for just under $3100 3 weeks ago. Personally, if you can spare the extra $600, you should go for the 47". $600 will be worth the extra 5", and I am sure you won't regret it. I would have loved the 52", but it was going for mid $4k, and I did not think the extra 5" is worth spending extra $1.5k at the time. For those where money is not the matter, I am sure their opinions will differ from mine. After all, when it comes to TV and assuming you have a large-ish HT room, the bigger the better.
Good luck with your choice.
Posted 28 March 2008 - 01:02 PM
im looking at the same set HN are advisertising on special for $3,000 but i think you should be able to pick one up for aroudn 2,000 - 2,500
thats what im hoping
Posted 28 March 2008 - 06:48 PM
paid $2600 + $160 4 year warrenty hn on wednesday
