How To Create A Firmware Cd
Posted 01 February 2008 - 08:13 PM
The problem stems from people burning the .iso file directly onto the cd as a data disc.
Here are the foolproof instructions for making a Firmware upgrade CD using nero.
Start Nero
Hit Cancel on the "new compilation" dialogue
Choose Recorder->Burn Image... from the menu
Select the .iso file
Hit "Open"
A new compilation will open.
Check the check box next to "Finalize CD"
Select the slowest burning speed.
Click on "Burn"
Voila, you should have a fully functional Firmware upgrade CD.
Posted 01 February 2008 - 08:21 PM
Start Nero
Hit "Open"
Click on "Burn"
If you dont have Nero - and are running VISTA - here is a free app to do the same thing
http://isorecorder.a...isorecorder.htm
Just right click the desktop ISO and select 'Copy Image to CD'.
This is a great little app as its free of frills and spyware and acilliary crap u dont need. Plus its free.
Edited by JoshH, 01 February 2008 - 08:24 PM.
Posted 08 February 2008 - 10:42 AM
http://kb.roxio.com/...eator/EE7000012
1. Open Creator Classic
-- a. Double click on the "Roxio Easy Media Creator" icon on your desktop
-- b. Click on the "Creator Classic" icon under "Applications".
2. Select and Burn the ISO file
-- a. Put a blank disc into your CD or DVD Recorder
b. Locate and left click "File" in the upper left hand corner of window, then click on "Record Disc From Image..."
-- c. A "Burn from Disc Image File..." window will appear, go to the location on your hard drive where the image file is located. Left click on the image file to highlight it, then click the "Open" button
-- d. When the "Roxio Creator Classic - Burn Progress" window is displayed click on the "Burn" button to start burning the disc.
hope this is correct - as this is what I've done (yet to test !)
Posted 08 February 2008 - 10:49 AM
http://www.burnatonce.net/downloads/
Posted 08 February 2008 - 12:09 PM
Posted 08 February 2008 - 01:39 PM
Posted 11 February 2008 - 11:16 PM
do we burn this to CD or DVD?
I'm burning the iso file to cd but my player says "this disk is not dvd format. Cannot play"
Edited by #Darren, 11 February 2008 - 11:59 PM.
Posted 12 February 2008 - 09:07 AM
Posted 15 February 2008 - 10:12 PM
Posted 21 February 2008 - 03:54 PM
Posted 22 February 2008 - 04:23 PM
Burnt both 2.7 and 2.8 firmware discs using this one, and no issues.............
http://www.ntfs.com/...burner_free.htm
Darren
Posted 06 March 2008 - 08:34 PM
peterjcat, on Feb 12 2008, 09:07 AM, said:
I think there is a problem with the iso file.
On my Mac, Roxio Toast reports that it isn't a valid file.
Disk Utility reports that disk image has missing checksum.
Downloaded the zip file from Toshiba site twice. Extracted twice.
Same problem.
Is there an alternative source for the image file?
An update: I used Parallels to burn the iso file via VISTA on an external USB burner using Active ISO Burner freeware and it worked.
It seems that Macs just don't like the iso
Edited by step_andy, 06 March 2008 - 09:00 PM.
Posted 03 April 2008 - 05:57 PM
http://docs.info.app...ml?artnum=93006
I habe burnt many succesful .iso files on my mac. You need to burn as an image!
Edited by Trigg, 03 April 2008 - 05:58 PM.
Posted 06 April 2008 - 09:13 AM
Failed 6 times using a combination of roxio & poweriso on vista + toast on mac.
I had to go back to xp & nero to get a successful update disc.
Lesson learnt: keep trying, it's not the iso file. Also, use a cd-rw unless you're in need of a few coasters.
Posted 07 April 2008 - 02:34 PM
BurnAware Homesite
From Download.com
Any YAMAHA RX-V1800B owners in Australia installed the latest firmware from CD disc yet?
Posted 23 May 2008 - 09:08 PM
#22
Posted 20 August 2008 - 03:04 AM
#25
Posted 17 February 2009 - 06:37 PM
would pick up the normal Cd only the Cd-RW ??
v59
