Mystar - Issues And Comments
1914 replies to this topic
#1901 gregy21a
gregy21a
  • 44 posts
Posted 15 December 2009 - 07:59 PM
View PostBobD, on Dec 14 2009, 03:15 PM, said:
My Mystar HD has not missed a beat since I got it. I have also stayed away from HD viewing and recording. The pluses of this approach. So much recording space that I have heaps of movies for viewing. Its faster and the remote controls work without drama. I am going to cancel my HD channels after 1 month and I will get them back when they sort out the box. That is, when I see all you guys no longer have troubles. Maybe I better not hold my breath.
I have no problem in recording HD and that is what I mainly record.
#1902 Jason_dinAlt
Jason_dinAlt
  • 668 posts
Posted 16 December 2009 - 04:57 AM
Ive had a couple of issues with recording HD, mainly the sound stuttering on playback
#1903 Jason_dinAlt
Jason_dinAlt
  • 668 posts
Posted 27 May 2010 - 09:50 AM
Never seen this "glitch" before.
Pressed "pause" and it went back 62 minutes!
#1904 Karlston
Karlston
  • 52 posts
Posted 29 May 2010 - 03:35 PM
Any one else having problems with Series linked shows no longer bringing in future episodes?
My disaStar SD hasn't added a single new episode past yesterday (Friday 28/5).
Have to add them manually, disaStar experience has taught me to keep a paper list of every series I want to series link.
Support's "solution" (of course) was to suggest reformatting the hard drive.
On Loader version L93.
#1905 thunderball
thunderball
  • 85 posts
Posted 18 June 2010 - 02:56 AM
yes my series link always forgets shows and dosnt update only works well for 2 weeks at best
#1906 chrissara
chrissara
  • 269 posts
Posted 18 June 2010 - 11:30 AM
I am having a problem with Mystar HD+ 3D channel with the World Cup.
I have a Samsung 63" 3d plasma.  When I went to the 3D channel, the 3D wasn't working properly.
By that with the Samsung 3D turned off, you have the two pictures side by side.  When you enable the 3D on the TV (in the side by side mode), the two pictures merge and you get the "blurry" picture.  I then turn on the 3D glasses however there is a "double image" when you look through the glasses.
By that you see two of the same player close to each other etc.  If you close one eye then you get the single picture i.e. the "doubling up" effect disappears.
The screen resolution is 1920x1080i 50hz.  Is this a Mystar issue or the TV?
#1907 Moonbah Madness
Moonbah Madness
  • 4 posts
Posted 27 February 2011 - 07:02 PM
View Postwhispa1970, on Nov 17 2007, 08:13 AM, said:
So what does everyone think of MYSTAR now you have it.
I think it is great, probably because it's the first PVR I have ever owned, apart from a PC with digital TV tuner.
I have had issues with the EPG not loading,
for some reason the EPG is not loading past 11 AM.
I would like to know but as i live in an owner install area they will not send out a hd box.  So im stuck with a crappy box I cant record on And a blurry picture to go with it.
They try to tell me that My samsung LCD tv is not compatible with their box  AS MY tv tries to re converet the image and this is what is causing the blurry pic.  Does this sound correct.
Pleaase Help with links to Blurry Pics on Austar As I seem to be having trouble finding the correct Posts.
Im new to blog sites so any help would be appreciated.
#1908 DrP
Posted 28 February 2011 - 05:06 AM
Austar standard definition on a large TV is never going to look spectacular.  Some of the channels such as Discovery are quite blurry.
#1909 Moonbah Madness
Moonbah Madness
  • 4 posts
Posted 28 February 2011 - 11:34 AM
Yes,  Thanks for your reply.  Is there anything I can do other than keep pressing them to send me The Mystar box.  I cannot even read the small writing on shows that have captions and all my sport channels are unwatchable.  Will My picture be better if I get A mystar HD box.. Not that I can, As I am in what they call an owner install area and will not send one out to me. I have found My time with austar stressful to say the least.  My foctel was perfect in every way.  I miss it
#1910 DrP
Posted 28 February 2011 - 03:10 PM
Are you connecting the STB to your TV with a composite lead or a s-video lead?  s-video is the better way.
#1911 Moonbah Madness
Moonbah Madness
  • 4 posts
Posted 28 February 2011 - 04:33 PM
Hello  Thanks again.  No im not using s-video leads  Just normal leads (yellow red white)  I am heading for a trip to the nearest town to get some soon,  Although Austar said this would not fix my problem.  I will try them for sure though
Thanks for the help.  Not sure what else I can try
#1912 DR.ZOIDBERG
DR.ZOIDBERG
  • 1,927 posts
Posted 22 March 2011 - 01:39 PM
Hey Guys
My Austar HD Box keeps getting the error message E52-32 (Weather in your area etc) Now the weather is perfect and I know for a fact is has nothing to do with the weather as this message comes up every single time I change to a different input on my TV. Example - Input HDMI 2 Austar, if I keep it on this, there is no issue at all. dont get any issues. But when I swap to Input DVD Player to watch a dvd, every single time I do this and once I have finished watching the DVD, I switch back to Input HDMI 2 Austar I get error message E52-32 EVERY TIME. It will not got away, I turn power off and reboot box, its still there. I finally get it back and working if I turn power off for 5min then back on.
I have no idea why its doing this and rather then call Austar and get someone with no clue I thought I would post here just to see if anyone else has had this issue and what I should do.
Thanks in advance!
#1913 nutmeg1
nutmeg1
  • 209 posts
Posted 23 March 2011 - 05:14 PM
I don't know why it happens but maybe a hdmi switchable connector box may be the answer as then you can have both connected and switch  to either austar or dvd.
#1914 sccs
sccs
  • 7 posts
Posted 04 July 2011 - 02:30 PM
My SD box has been doing this for months. Pause a show and when you press play again it often goes back 62 minutes. Don't know what the significance of 62 is.
Phoned AUSTAR and a bird with an Asian-American accent said, after putting me on hold a few times, it must be the remote control and sent a new one.
Made no difference.
Also series link drops out from time to time. And when a series linked show is repeated in a different time slot, that usually gets recorded as well.
#1915 nutmeg1
nutmeg1
  • 209 posts
Posted 05 July 2011 - 10:40 AM
They do this as they have a buffer for the channel you are on so if you have not changed the channel and pause, when you play again it goes back to the beginning of the buffer.Series link can be a pain some times and its frustrating when a programme is recorded twice .
Hope this helps.
