Blu-ray & Hd Dvd Audio & Video Specifications
16 replies to this topic
#1 :)
  • 30,947 posts
Posted 21 October 2007 - 05:33 PM
hi all noticed this rather excellent post on avs detaillign the audio and video specs of various blu-ray titles.
http://www.avsforum....amp;postcount=1
wonder if this is kept upto date by the OP ?
anyone got a link to similar for hd dvd titles ?
#2 cwt
cwt
  • 5,080 posts
Posted 22 October 2007 - 04:01 AM
Good find Al; Ide say the op has done a good job considering the first date posted and the silver surfer movie mentioned. I had a grin when you notice the large volume of 16/48 pcm discs and on the other hand 20/24 bit discs -which have benefited from dts hd or dd truehd compression. ;)
Something tells me this poster has read bfdtv's comments on why pcm should be shafted. :) Have never found a hd dvd list - this would be good too. High percentage of DD plus methinks -nothing wrong with that but  B)
#3 sstorra
sstorra
  • 38 posts
Posted 22 October 2007 - 07:13 AM
Actually, the equivalent HD-DVD thread is here :
http://www.avsforum....ad.php?t=822245
#4 :)
  • 30,947 posts
Posted 22 October 2007 - 07:44 AM
excellent !
good work torra, thankyou for posting
#5 :)
  • 30,947 posts
Posted 22 October 2007 - 01:30 PM
interesting thing re this post on avs, is it correct chronicles of riddick and aeon flux have dts-hd secondary tracks. dont recall them havign to be honest.
#6 AndrewW
AndrewW
  • 14,237 posts
Posted 23 October 2007 - 10:14 AM
It doesn't (for Riddick anyway)
It has DD+ and DTS.
#7 MeWhoElse
MeWhoElse
  • 826 posts
Posted 25 October 2007 - 10:27 PM
DTS can be called DTS-HD, as it is listed as a subset of DTS-HD... Probably due to its ability to do up to 24bit audio (I believe DD was modified also to do 24bit too... I recall something in the Insiders thread from Dolby on this)
#8 cwt
cwt
  • 5,080 posts
Posted 26 October 2007 - 02:52 AM
It certainly can MWE; Ime still trying to find a 24/96 dts disc- this decoding was introduced at least 3 years ago :rolleyes: If the list poster had said dts hdhr ;he would have been wrong - different bit rates at good old dts.com -
http://www.dtsonline...y-and-hddvd.php
It would have clarified things if he just said dts core <_<
#9 AndrewW
AndrewW
  • 14,237 posts
Posted 26 October 2007 - 08:41 AM
Mate, try this link
Select a region, and select "DTS Digital Surround 96/24" as the Technology :)
#10 cwt
cwt
  • 5,080 posts
Posted 26 October 2007 - 03:28 PM
View PostAndrewW, on Oct 26 2007, 08:41 AM, said:
Mate, try this link
Thanks muchly Andrew ;Turns out I bought the wrong Master and Commander dvd - the english version was the right one :) At least there are 10 available - interesting to compare with the equivalent hd disc :)
Edited by cwt, 26 October 2007 - 03:32 PM.
#11 AndrewW
AndrewW
  • 14,237 posts
Posted 26 October 2007 - 03:46 PM
No problem at all, found that site when I was looking for dvds to test out my new amp/speaker combo :)
#12 :)
  • 30,947 posts
Posted 18 November 2007 - 11:21 AM
blu-ray listing by audio format courtesy of homerj
http://mysite.verizo...luray-audio.htm
couple of other great links also courtesy of homer j
blu ray stats
http://blu-raystats.com/
hd dvd stats
http://www.hddvdstats.com/index.php
a bit of a tier listing of titles based on subjective impressions
http://www.avsforum....ad.php?t=918734
would encourage anyoen to compare formats if get the chance eg as in this thread if come across discs with different audio track formats
http://www.dtvforum....showtopic=59342
#13 zisel
zisel
Posted 29 July 2010 - 04:51 PM
overall, thanks for sharing  :D
#14 kevin1234
kevin1234
Posted 31 December 2011 - 06:47 PM
Hi new to the forum unable to post a new topic so thought someone here may be able to help.Bought a new 106cm sanyo led tv for my mother who has very bad hearing  wears radio shack cordless headphones so she does not deafen us when we are watching the tv with her the old tv had an output to plug into. but on the new tv there is a headphone jack the problem is when you plug into this it cuts the sound out so she is the only one that can hear the tv.I have been to dick smith and JB HI FI to find a solution no one could help.Below is the specs of the TV
The Sanyo 42" 1080p LED LCD TV offers a supreme full HD resolution of 1920 x 1080, a contrast ratio of 4000:1 and an Edge LED backlight with an HD digital tuner. This 42" LED LCD TV features USB recording media capabilities, 3 x HDMI terminals and touch key controls. This 1080p TV also comes equipped with a time shift function, 178 degree viewing angle and a response time of 6.5ms. Select an image to enlarge
    Close window Use mouse-wheel or slide-bar to zoom
SpecificationReviewDelivery.Detailed product information
Sku Code
BIGW_8113504
? Boxed Height
78
? Boxed Length
11
? Recording Capabilities
USB: - 1GB:15 mins; 2GB:30 mins;8GB: 2 hours
? Response Time
6.5ms
? Screen Definition
Full High Definition
? Screen Resolution
1920 x 1080
? Screen Size (Inch)
42
? Signal Compatibility
480i/P, 576i/P, 720P, 1080i/P
? Sleep Timer
Yes
? Teletext
Yes
? Terminals
HDMI X 3; RF input (75ohms coaxial); Composite video (RCA); Composite audio (RCA); Component video (RCA); Component audio (RCA); VGA (D-sub); VGA audio;RCA A/V output; RS-232; SPDIF output (coaxial); USB 2.0 interface; Earphone jack
#15 Struggo
Struggo
  • 1,316 posts
Posted 01 January 2012 - 02:06 AM
Run the following from the rear of the TV (RCA A/V Output),
** Judging by the manual, the audio output in next to the HDMI 3 input.
http://www.ebay.com....=item4160bae07b
If you need something quick, head down to DSE
http://dicksmith.com...2-x-rca-sockets
http://dicksmith.com...ug-2-x-rca-plug
Edited by Struggo, 01 January 2012 - 02:11 AM.
#16 kevin1234
kevin1234
Posted 01 January 2012 - 12:04 PM
[quote name='Struggo' date='Jan 1 2012, 03:06 AM' post='1769458']
[url="http://www.ebay.com.au/itm/Crest-3-5mm-Stereo-2-RCA-Audio-Cable-20cm-Pack-5-/280795734139?pt=AU_Electronics_Accessories_Wires_Cables&hash=item4160bae07b"]http://www.ebay.com.au/itm/Crest-3-5mm-Ste...=item4160bae07b[/url]
[url="http://dicksmith.com.au/product/P6573/adpt-3-5mm-st-skt-2-x-rca-skt-stereo-skt-to-2-x-rca-sockets"]http://dicksmith.com.au/product/P6573/adpt...2-x-rca-sockets[/url]
[url="http://dicksmith.com.au/product/C1180/2m-cable-2-x-rca-plug-2-x-rca-plug"]http://dicksmith.com.au/product/C1180/2m-c...ug-2-x-rca-plug[/url]
Hi thanks for the reply I may have quoted the wrong model the model is sanyo LED 42XR11F checked TV again there is no AV output however there is a S/SDIF audio output could i go from here to a Digital Coaxial Audio to Analogue Stereo RCA Converter and plug the headset into this or would this all so cut out the sound to the TV
#17 kevin1234
kevin1234
Posted 03 January 2012 - 08:09 PM
[/quote]
hi specs for this TV are
1. Remote sensor
2. Power indicator
Lights blue when in operating mode.
Lights red when in standby mode.
3. POWER
4. INPUT
To access Input Source menu
5. MENU
Press this button to access the main menu screen.
6. CH
Press these two buttons to directly change the TV channel;
In menu operations, these buttons serve as up/down buttons.
7. VOL+
Press the VOL+ or VOL– button to directly increase or decrease
the sound volume level;
In menu operations, these buttons serve as right/left buttons.
8. Power Switch
Receives signals from the remote control. Do not block.
Press this button to turn the unit ON from STANDBY mode. Press it
again to turn the set back to STANDBY.
Main Unit (back view) 1. S/PDIF digital audio output: Connect a digital sound
system to this jack.
2. USB port: Connect a USB device to this port.
3. HDMI3: Connect an HDMI device to this jack.
4. Headphone: Connect headphones to this jack.
5. AV INPUT: Connect an AV device to these jacks.
6. RS-232: For service only. Do not use.
7. HDMI1 (with ARC): Connect an HDMI device to this jack.
8. HDMI2: Connect an HDMI device to this jack.
9. MUSIC: Connect a MP3 player to this jack.
10. PC IN D-SUB/AUDIO: Connect a computer to these
jacks.
11. COMPONENT IN: Connect a component video device
to these jacks.
12. RF: Connect an antenna to this jack.
any advice would be appreciated
