Screen Height, Speaker Placment And Seating Loctions
#76
Posted 23 February 2012 - 10:04 AM
Whilst it's the room that houses all the gear, it's the viewer who is watching and listening.
#77
Posted 23 February 2012 - 11:49 AM
Remeber, deviding the room length is for finding the tallest image. You don't have to max out every room. You could something smaller because the numbers provided are between 3.68 (largest) and 5.18 (smallest).
Link to IMAGES
If the obsticale was a bar and you had at least 3x the calculated image height available, you'd probably just go with the larger screen anyway. A different story if that obstical was a partial wall.
Edited by MarkTecher, 23 February 2012 - 12:30 PM.
#78
Posted 23 February 2012 - 12:40 PM
Same for the room length formula. Say your room is 9 metres long. 9 /3.68 = 2.44 metre high image down to 9 /5.18 = 1.73 metre high image.
1.74 metres high is a 140 inch but 2.44 metres high is 181 inch screen. Many use 140's and 150's but very few use anything bigger. That's the problem for bigger rooms and if there's more than one row of seats, only one row is really going to get the ideal image size. The other rows are either going to be too close or further back.
However in a 6 metre room (which is a more common size) using 3.68 to 5.18 gives us anything from 92 inch out to 130 inch.
Using 2-4 times formula seated at 4.5 metres gives us 90 inch out to 170 inch. Both don't seem to work well enough. You could guess and land anywhere in between those sizes.
This is why I had always thought those formulas were rather vague.. If you apply 2.5 to 3.5 times image height formula based on seating position would get the following:
145 inch image down to 100 inch or thereabouts. Although that is closer, it's still vague. Somewhere in the middle being 3x image height is a 120-125 inch screen.
Then if you applied 3x image to a 6 metre seating position you get a 2 metre high image, again, it does not work.
The vast majority of seating positions are between 3 and 6 metres with most being between 3.5 and 5.0 metres, this where the 3x image height seems to work out quite well.
But in the end, it comes down to the person and what they deem watchable. Whether they want lots of immersion and wow factor or ultra image clarity via a smaller size, it's up to the user.
#79
Posted 23 February 2012 - 05:35 PM
oztheatre, on 23 February 2012 - 12:40 PM, said:
You've taken the extremes without mention of the 'preferred' of 3x here.
You would not design a HT with the main seats at 5m for 2.5m high screen unless your room was at least 9.2m deep (9.2 / 3.68 = 2.5) which would place the main seats at about 7.5m (2.5 x 3). Even allowing 1.5m between rows, your front row would not have to be at 2x or 5m here, rather the front row could be at 2.4x the image height or 6m. It is an extremely large case, but just proves the math provided in this thread does indeed work in applied correctly.
A 1.25m high screen would be ideal in a 5m room though (5 / 4 = 1.25).
So how exactly (apart from a guestimate) are you working out the "idea screen height" based on this? Where is your starting point?
Sorry what AR? I'm assuming 16:9 here?
The issue at hand is not the size of the screen size but if a HT projector can actually light it. I've seen a 1.7m tall screen in a 9m room and it was very cool. But the guy also spent some 60K on his projector and processing.
To prevent confusion, one should stick to image heights and not throw in diagonal unless you also provide the image height because image heights change radically with diagonals alone due to Aspect Ratios. EG: A 120" 16:9 screen is the pretty much same height as a 150" Scope screen, yet there is 30" difference.
It doesn't work simply because you didn't start with a room length. Imagine building a kitchen for a house without knowing the room sizes of the house? There is no difference here. Allot of frustration (not to mention money) saved by simply knowing what size the room is that you have to work with first. Unless you live in the Tardis of course or a building an out door cinema, then and only then would room size be irrelevent.
SMPTE stands for the Society of Motion Picture and Television Engineers. These are the guys that pass ALL the statrdards for cinema and TV. I'd say they know their stuff. I've simply taken their figures and placed them together to make a formula that works in every room.
Edited by MarkTecher, 23 February 2012 - 05:44 PM.
#80
Posted 23 February 2012 - 07:58 PM
And that is my point. They all work well enough, albeit having massive extremes, up to a point.
Go ahead and use any of these formulas in an 8 metre room. By NOT using seating position and room length only, in an 8 metre room you will get 2.17 metre high image down to 1.54 metre high. (I am using 16:9 as the AR because all projectors have native 16:9 panels, the extra 33% width I have no problem with as this gets one immersion and why scope films are made this way)
2.17 metres high is a native 175 inch image. 1.54 metres is a 125 inch image. A massive difference with large extremes.
Now if you based this on the room length, it means you don't take into account the seating position. What if, the main viewing row is 4 metres from the screen? Not uncommon.
Then if you apply 2.5 to 3.5x image height to 4 metres you get a more realistically sized image which is closer to being correct. 2.5 gets you a 126 inch image and 3.5 gets you a 92 inch image. Can you see how the differences are less extreme? 3x image height at 4 metres works great, gets you a 107 inch image. The larger the screen, the duller the image and the further back one must sit to resolve the image anyway. Further back also takes away some of the immersion and as you said a while back, you re discovered the front row in your room. It's enveloping and immersive.
You agreed a couple of years back when I said room length into 4.5 would work well as it's right in the middle of 3.68 and 5.18.
In a 6 metre room it seems to work well, gets you a 1.33 metre high image. But again it forgets where the viewer is seated. I realise in an 'ideal' to the thx and smpte spec style room it can work as long as the room doesn't get too long, but so so many rooms are not like this today, something I see almost daily.
In a 8 metre room it seems to fail, you get a 1.77 metre high image and if you were seated 4 metres away and used the 3 formula you would get a 1.33 metre high image, a difference of 25% in image size here (in fact the difference here is 106 inch to 146 inch, massive). This is my point, projectors cannot light up such large screens, as you said, unless you have 60 grand to throw at a top of the line high output machine. I realise the room contains all the gear but it's the person watching the movie that counts here and this is why I always use seating position first and foremost.
It's like saying lets make all speed limits zero to 200kph. Cars can't go that fast and if they try to, it's normally a bad result, if they go that slow, it's just annoying for everyone.
There are many other factors involved too. Not only can it come down to personal choice, but it's also what is being viewed. Re runs of MASH are not going to look crash hot on a 2.5 metre high screen unless you're 20 metres away. Some people are gamers, some people watch FTA TV which is nowhere near the quality of blu ray. Some people watch a mix of everything. These are the factors one must take into account and it's why I get it right time after time.
7,8, 9 and 10 metre rooms are not uncommon either.
Remember Albert's room? 8.4 metres long and we put in a 1.47 metre tall scope screen. If we used room length formula 3.68 the image would have been 2.28 metres high, and 5.18 would have been 1.62 metres high, both well outside the 150 scope screen size (In that room it's room length into 5.71 so that formula wasn't even used..........). Yet his seating position was around the 5.5 metre mark which ends up being 3.74x image height. Front row around 4.0 metres giving 2.72x image height. So for both rows he was within the 2 to 4x image height, the back row falls outside that. Great speakers btw, he loves them.
Things change, ideas get revamped and everyone I deal with agrees that seating position to determine screen size is the important factor, and 2.5 to 3.5 is a more fine tuned formula that works well, albeit, like the other formulas, to a point.
Yes I know who SMTPE are too.
#81
Posted 23 February 2012 - 09:56 PM
oztheatre, on 23 February 2012 - 07:58 PM, said:
I did but you said this:
There has to be range because not all rooms are equal. You will have narrower or wider rooms than is "ideal".
Whilst I like a massive image, some do not and why you see people gravitate to the very back row of the cinema or watch a 42” TV from 4m. This part is a personal choice and the idea here is about providing acceptable limits. You would not want a 1.25m screen in the same 8 meter room nor would you want a screen height of 2.5m in the same room. Just because the 2x zoom on their projector allows it does not make it right. The idea of the formula is to allow flexibility within set limits.
Of course it does. I just work this out from the screen height so it becomes the 3rd part, not the 1st. So if we stay in the 8m room with the 2.17m screen height, the closest we can sit is 4.34 and ideally we would be at 3x or 6.51. Now here is one case where you can not sit 4x (seating between 2x and 4x) because 4 x 2.17 = 8.68m which is longer than the room itself. So if you want to sit 4x the image height you then have to reduce the image size getting closer to the 5.18 end of the range. You don't need to go right to that limit, but you will need to divide the RL by a number over 4 to be able to sit 4x the image height. And more so if you want back surrounds for a 7.1 system and not have your seats on the back wall.
1.6m x 3.68 = 5.88m and 1.6m x 5.18 = 8.28 (this does not fit even in the 8m room).
1.42m x 3.68 = 5.23m and 1.42m x 5.18 = 7.34m
Today, throw ratio is the last step I’d be working out. I’d want to know a screen size and seating distance that works in my room first.
1.63 x 2 = 3.26m (closest)
1.63 x 3 = 4.89m (preferred)
I also see allot of floor plans and well as go out to quote homes. Most ‘media rooms’ are less than 6m.
Lumens are the limiting factor to many HT projectors. This is not an issue with say the BenQ W6000 and even the W7000. It is shame many other HT projectors don’t have lumens to spare and a shame these DLPs don’t have the black levels of the other technology.
#82
Posted 23 February 2012 - 10:26 PM
Of course, you know the room size before you sit down in it, you don't sit in your chair and then build walls around yourself. You then know where you want to sit before the screen goes in too. There may need to be a walkway at the back for entry etc. Screens always go in last in most setups. Risers, chairs etc all go in before hand, therefore you end up know your distance from the screen before you decide.
2x image height is awfully close. There may be some that sit 3.2 metres away from a 130 inch screen, but I can see SD at 3 metres on a 110 so 130 seems too large at 3.2 metres. 4K projection no problem, you can sit 1.5 metres from a 130 and you wont see pixels ever.
You don't understand what I meant. If the room is 8 metres long, the customer wants to sit or has to sit 4 metres away, then his image size cannot be that large. It has to come down in size to marry up with the ability to resolve the image. I'm not saying you can't sit 5.31 metres away or you shouldn't. I'm saying you can't tell people where to sit, and there are other limiting factors involved as mentioned above.
Most post calibrated projectors are not even close to 1000 lumens, many are 400-700, so size is limited to the projector, then to the viewing distance, then to the room size.
TR is just a number in the end. Required for lenses for the most part. But look I agree, screen size and seating position are the 2 keys and why I use seating position to work out screen size all the time. The room can be whatever length it is, 12 metres or 5 metres. I just find seating position is paramount. Seems logical, it's the person watching the movie after all.
My point is the extremes given don't really help people to choose the correct size. If you said to someone 125 to 175 inch in size, just go in between there somewhere, they wouldn't really know what to do. And why I suggest shaving some off those extremes to get closer to the ideal size. I have no problem with the formulas, I just think they need tightening up a little. That's all.
#83
Posted 24 February 2012 - 11:13 AM
oztheatre, on 23 February 2012 - 10:26 PM, said:
I have been crunching numbers and think if I was to trim them I'd do so from the smaller end before the largest. Maybe start 3.7 (3.68 rounded) and go to 4.8.
#84
Posted 24 February 2012 - 11:41 AM
MarkTecher, on 24 February 2012 - 11:13 AM, said:
For a 6 metre room, and only an example using 3.8 to 4.8
gives 1.57 metre high image x 3 for seating = 4.71 metres which would be quite ideal I think.
and 4.8 gives 1.25 metre high image x 3 for seating = 3.75 metres.
To sit closer with a 1.57 metre high image, x 2.4 = 3.76, possibly sit a little closer at 2.25 x image height you put you at 3.53 which is 1.2 metres in front of the 3x row.
This is 100 to 125 inch image size which I feel is getting closer to the ideal size. Whereas 3.68 to 5.18 gives 92 inch to 130 inch.
It's all rather relative anyway, the bigger you go the further back you need to sit.
Will try this with bigger rooms when I get some time. So 3.8 to 4.8 room division, then base on 2.25 to say 3.5 to 3.75x image height to get seating positions with enough room between rows where applicable. The average of 2.25 and 3.75 is 3.0 so that might just work out well enough.
#85
Posted 27 February 2012 - 02:00 PM
#86
Posted 28 February 2012 - 03:51 PM
#87
Posted 29 February 2012 - 09:58 AM
Here are some renders on my current room. These are my first attempts at this program, so they may have parts that don't quite look right.
Baffle Wall
Surrounds
So with a program like this, the idea is that one can create any sized room. Sketch Up always begins with a virtual person to provide a sence of scale. There is no reason that "person" can not be moved to replicate a real person in the room. To simulate the seated heigth, you simply push/drag the person through the floor to get their eye line at the desired seated eye line. You can rotate through 360 degrees on all three axis, so you can gain a real world sense of what is needed. And this takes out the limits of real room modeling because now the room can be made as large or as small as required.
I am currently working on a room with double studded walls to show the detail of construction. It is impressive to be able to see how this looks without actually having to build it. 2D just does not give the same visual information.
#88
Posted 29 February 2012 - 08:03 PM
So with that in mind, these are the figures I got when i modeled a room in 3D.
2x IH = 27.5 degrees
3x IH = 18.7 degrees
3.68x IH = 14.8 degrees
4x IH = 14.2 degrees.
In short (assumig you can light it), don't be scared about putting in a big screen
#89
Posted 29 February 2012 - 08:39 PM
#90
Posted 01 March 2012 - 12:01 AM
The room I mocked up tonight is based on a 3m ceiling height (who actually has such a room?) with the staggered ratio of 1.0:1.6:2.3 and applied everything the formula in the opening post suggests. It is basically maxed out with the RL being divided by 3.68 and I went from there. What I found interesting though was how the surrounds lined up to be precisely 60 degrees separation with this. I didn't think it would be so precise and expected to have to move them slightly.
I've placed the screen vertically centered which means your not looking up at the screen, rather right at it. My own screen is pretty much the same. Probably too low fro some, but because it is AT, you can optimize both eye lines and speaker heights.
#91
Posted 22 April 2012 - 07:49 PM
I am sorry to ask on here but I have read everything I can find and there is so much conflicting information. I am looking at setting up a basic screen and projector until I can afford something better. I think I am pretty much decided on a Benq W1200 and a Grand View screen ( I apologise if this is a substandard setup but t is in my price range). It will be used to watch sporting events on TV, the occasional movie and PS3. I am after some information given my room size. The room is 5440mm long and 3950mm wide and the ceiling is 2830mm high. I would like the projector roof mounted and this can be no closer to the screen than 4000mm as there is raked ceilings. At distances greater than that I have beams that run front to back. Are there any mounts suitable to attach to this? I have trawled the internet and there is various advice and calculators but it is not making sense so am looking for recommendations.
We plan on having two rows of seats if possible. These can be situated anywhere in the room and I will build the back row up around 300mm. the back row is a couch with recliners and the front row is two separate recliners. I would like a fixed screen. Then there is a question of which size and gain.
Do you have any recommendations? Would I be better getting the projector first and then seeing which screen size suits? How do you know how far to have the screen off the ground?
Thanks in advance for any help
Edited by Windoze, 22 April 2012 - 07:50 PM.
#92
Posted 08 May 2012 - 10:52 PM
If you already own the projector, you can test the size of the image this projector by setting the unit up on a small table or stable chair. Because there is no lens shift, the offset is fixed regardless if the projector is table mounted or inverted. Generally this means that the projector will have to be mounted at the height of the bottom of top of the screen.
If mounted inverted, you will have to ensure that the projector is at or slightly above the top of the screen.
#93
Posted 03 September 2012 - 11:36 PM
I am about to plunge into this HT thing. I have all of my speakers and subs and processor gear ... now all that is missing is my projector and screen. This thread has been a very interesting read and i can see that both OzTheatre and MarkTecher have contributed enormously to this thread and for that i thank you both. Even though you both might take a slightly different approach i dare say that one is not more correct than the other .. just depends on the application.
In my situation i am a 2ch guy first and foremost and want to get the best possible setup without compromising my 2ch sound. I see that you guys .. well some of you guys are the other way .. ht first and 2ch setup second.
The length of my room is 8.4m with a standard ceiling height of 2.4m. Although i have my 2ch speakers well away from both the rear and side walls now for 2ch listening i am more than happy to re-adjust the speakers when using for ht and put them back again for 2ch.
I am just doing the sums now using both methods espoused by oztheatre and MarkTecher to see which suits my circumstances. I haven't yet decided on a type of projector or screen yet so really open to ideas in that space. I was looking at a high end JVC but open to suggestions. Also open to suggestions re Projector Screen makes. Totally newbie here when it comes to HT.
Have everything except the projector & screen - once i have acquired them i will be in business. So expect me to be asking alot of questions until i get this part sorted.
cheers j
#94
Posted 04 September 2012 - 07:46 AM
Do you have complete light control?
You'll only get the benefit of high end JVC's extra contrast if the room blocks all light and is painted a dark colour.
The JVCs have had issues with lamps excessively dimming well before nominal end of life.
How wide is the wall you'll project on?
I'm a fan of Oz Theatre Screens - great performance for a reasonable price.
It would be a PITA to move L&R speakers. How far apart are these normally?
How far is your 2ch seating from the wall you'll project on?
Edited by Quark, 04 September 2012 - 07:47 AM.
#95
Posted 04 September 2012 - 07:07 PM
Quark, on 04 September 2012 - 07:46 AM, said:
The room must be completely dark but does not have to be a dark colour to see the obvious contrast advantage of the JVC's. In dark scenes where high contrast and good blacks are really needed room reflections have little influence on results, there has to be significant bright content on screen to visibly affect black level and contrast.
Even though the JVC have much greater native contrast than any of the competition blacks are a very long way from black, even if contrast was 10 times better blacks would still be visibly gray in a totally dark room with zero reflections.
The X70 is an X30 with a second iris in front of the lamp, greater contrast is only obtained over the X30 at the expense of light output. If you want better contrast you have to go to the X90 as it has hand picked and better components as well as more attention to detail paid to the light path. Contrast is significantly better than the other two but it still leaves a lot to be desired IMHO. Maybe one day digital projectors will rival CRT projectors for blacks, but I dont think it will be any time soon.
Some peolpe have experienced premature dimming while others have not, its not a generic issue. I'm heading for 900 hours on my JVC and the lamp is fine. I dont need to open the iris fully or use high lamp power so the lamps got life in it yet. I would be quite happy to replace the lamp at this stage in the projectors life if necessary, its a small price to pay for the performance offered.
If running cost is a significant concern other projectors may be a better choice, you dont want to put off using the projector because you are apprehensive about lamp life/cost.
#96
Posted 04 September 2012 - 07:18 PM
cheers j
j given you are in the sunny state, why not get mark or oz to pay you a visit for some ideas. dont know if they will....but worth an ask
definitely possible to setup a nice 2ch without compromise and ht in the same system with a pj setup, something have done myself, and as per quark I dont think be moving main speakers around. probably better to get a setup so it does both pretty well. in my case am sitting in what corresponds to around 3 image heights to the screen which also happens to be the sweet spot for main listening position for 2ch. so yeah its possible.
its a very deep room you have, what sort of width is probably the important question though. will give you what sort of room width have to work with.
pre pjs, there are other options as suggested by quark to consider. and yes its worth knowing whether you are going for a dedicated room and bat cave, ie total light control, black walls ceilings etc as these will impact quite a bit on end result.is 3D a necessity.
have you had a look at any pj setups in person ? will also help in deciding what suits your needs. re screen and pj. also worth getting a pj first if still bit unsure on exact screen size going for...that way can project up on a wall see what looks like then decide
#97
Posted 05 September 2012 - 12:21 AM
I wouldn't say i have complete light control. It is a dedicated music/ht room that is to say that is all it will ever be used for. Living is done upstairs and my ... errr ... the families ht room is downstairs. The roof is white .. it is a pretty dark room by default. A few windows do exist in the room but i do have permission to cover the windows with heavy black drapes/curtains etc but i won't get away with being able to paint the ceiling black.
To the rear of the room is a staircase leading upstairs which will also leak some light into the downstairs area. There maybe a way i can block this again with heavy curtains around the stair well.
The width of the wall and hence the wall that the screen can fit on is 5.75m. So the room dimensions are 8.4m length, 5.75m wide, 2.4m high
I have a bit of flexibility with the seat. I can move it back or forward wherever i prefer. For speakers i don't want them too close to the rear or side walls for 2ch music purposes.
Room dimensions answered above - 8.4m length, 5.75m wide, 2.4m high
No i have not seen other PJ setups .. only what i have seen in stores etc.
I am thinking along the lines of a Cinema Scope Screen as it would seem they don't "drop" as low as all the other screens. Yes i am also very happy to consider other projectors ... JVC's are the only ones i have really read up about esp the X90 but very happy to consider others.
Placing curtains in the room not a problem ... painting the roof white will be a problem. Keen to read and learn more about this hobby now.
This has been a hell of a journey getting this far and i can now see light at the end of this very long tunnel .. :-)
Oh i meant to add that i am setup for a 7.2 system. I should look at taking a photo and posting up on here somewhere.
Edited by jrisles, 05 September 2012 - 12:26 AM.
#98
Posted 05 September 2012 - 07:06 PM
Especially for screens that extend close to the ceiling, the image will benefit from a darker ceiling - doesn't have to be black.
One of the considerations with side L&R speakers that aren't against the wall, is how many seats in each row, so as to avoid those on the ends having their view impeded by the speakers (been through this myself). How many people do you need to seat and is a second row (with riser) an option?
Not sure why the interest in a scope screen. I've got one, but that was driven by a few factors, like fitting the screen above HT L&R speakers. If you want a scope screen without the expense of an anamorphic lens, then it's a choice of one of the JVCs or a Panasonic, as they have lens memories. Note there's a new Panasonic AE8000 due out soon with significantly increased brightness and probably worth waiting for rather than the current AE7000, if you start considering a Panasonic. For actual screen size and aspect ratio you may want to project onto a wall for a week or so before you settle.
The JVCs are capable of lighting up the screen sizes mentioned above if the lamps have a normal life, the projector is mounted with the shortest throw and you use a screen with a gain ~1.2, but probably not much in reserve, especially if you like a bright picture. As I mentioned previously, there have been multiple reports of excessive lamp dimming on the JVCs - check the AVS forums (e.g. one individual on their 4th lamp). There are some reports that lamp life is improved by running the fan in high altitude mode - presumably suggesting it's a heat issue, so may not be a problem for those with good aircon.
If you go with a 16:9 screen the projector options become much wider. If you haven't already, make sure you demo some of the different tech out there and see what you like. Personally, I like the "pop" and crispness of a DLP, but there are also issues like rainbow effects for some people and a little more fan noise than DILA and LCD. The JVCs DILA tech definitely has the best blacks.
A 7.2 system sounds mighty nice.
#99
Posted 05 September 2012 - 09:56 PM
One of the reasons i was considering a scope screen because it would appear that these screens are wider with a shorter drop? I have only 165cm to play with as a drop from the ceiling to the top of my centre speaker. My L/R speakers are taller but if i can't keep them where they are I can move them to the side of the screen. So this is why i was considering a scope screen. Are you suggesting that a 16:9 screen is "better" or more versatile? I think aesthetically the scope screens look better. If these are "better" but cost more because you require an anamorphic lens then so be it.
I could potentially paint the ceiling black where it is closest to the screen. But not the whole ceiling.
The seating arrangement is for a family of four first and foremost. One 3 seater sofa for the adults and 2x bean bags for the kids. We may look at alternative seating later down the track.
Yes the more i have been reading of late the more i am beginning to think that perhaps the JVC X90 is not the projector of choice. Those Epsons and Pana's get great reviews. I suspect with the imminent release of the Pana 8000 another release of the Epsons are just around the corner too. So i dare say that by the time i have worked out the config of my room there would have been a few reviews released to assist with my decision.
Great idea regarding projecting on the wall prior to settling on an aspect ratio.
With respect to my components they are listed in my signature.
BD = Oppo BDP-95
L/R Speakers = Adam Tensor Gamma
Center = Adam Tensor C9
Rear = Adam Tensor Epsilon
Sides = Adam ARTist 5
Processor = Anthem Statement D2v
Subwoofers = 2x JL Audio Fathom F113
Projector = ???
Screen = ???
#100
Posted 05 September 2012 - 10:20 PM
If going with scope without the expense of an anamorphic lens, then you really need the convenience of lens memory that's presently available on only the JVCs and Panasonic.
While projecting on a wall is a good option, I see that Rich at OZ Theatre Screens has a 20% off screens sale at present...
Doh!
