I have an ELLIES STD box bought almost a year ago. From the first time I bought it i had problem with the reception of Ch 9. Sometimes it would work fine, sometimes i would get pixelized picture and sometimes no pic or audio. Every other channel has no problem.
I live in Kingsville/footscray area, Melbourne, VIC
Is a problem of reception or the STD decoder?
Thank you
Channel 9 Reception Problem Or Stdbox Problem?
takis
, Nov 15 2006 01:51 PM
4 replies to this topic
Posted 15 November 2006 - 01:51 PM
Posted 15 November 2006 - 02:24 PM
Could be either. Doesn't the box have a signal strength indicator?
You could try plugging in another box and seeing if the problem persists (then its the reception) or take the box elsewhere and try it out.
If its only one station then I'd be inclined to think it was low reception on this channel. I'd suggest getting an aerial guy out. He can tell you what reception your getting on each channel and probably provide a quick fix on the 'bad one'. Shouldn't cost much for a quick check.
Posted 16 November 2006 - 03:48 PM
Thank you
Thank you
The Kingsville area is fairly bad for reception.
My experience was ch #10 s being the worst.
If you were viewing analogue broadcats, you'd see lots of ghosting on most channels, and general RF noise across the screen as well.
I'd suggest get a good aerial man in, if that hasn't been done already.
Posted 17 November 2006 - 01:10 AM
takis,
Read Get the Best Reception, Melbourne and read the links.
Please post any further posts in the Melbourne viewers' forum, which is near the bottom of the main forum home page.
Posted 17 November 2006 - 11:36 AM
i to had this issue not long ago.
