OK,
I've done the work for you.....--------------------------------------------------------------------------------
Here is the code:
1. Set the Bass to maximum and the treble to minimum
2. Press the "F" button on the television (the volume display must be on while performing step 3)
3. Simultaneously press the Volume down button on the television and the Index button on the remote control.
In mode:
1. To move up through the functions use the remote control GREEN button
2. To move down through the functions press the remote control RED button
3. To INCREASE the value use the remote control BLUE button or the remote control VOLUME UP (+) button
4. To DECREASE the value use the remote control YELLOW button or the remote control VOLUME DOWN (-) button
5. Press the "STR" button on the remote control or TV to store the settings.
6. Turn the set off to exit the service mode.
Courtesy of Mag at
http://www.dba.org.a...p?TOPIC_ID=1698
Use with care - no responsibility taken for you completely stuffing up your TV or voiding the warranty.
