Lg 52sz8r Dlp Rptv - Owner's Report 12 Months On
Posted 14 August 2006 - 02:24 PM
The TV is used about 4-5 hours a day and fortunately I've only had one issue with it. Sometimes the response to the remote is sluggish. Push the button on the remote and then about two seconds later the TV responds. I have noticed this 4 or 5 times in the last year but it only does it for a minute or two then its back to normal. Rainbow effect was apparent when I first got the TV but I hardly notice it now. No-one else has ever mentioned the rainbow effect.
Outstanding picture when calibrated
Works well as a HTPC monitor (great for gaming)
Picture is great even with all curtains drawn on a sunny day.
No distracting reflections off the screen
DISLIKES:
Choosing inputs (AV1/Component?HDMI etc) is very slow and clumsy.
Picture off in-built analogue tuner is atrocious (NEVER used)
Blacks could be blacker
Overall, I'm still very pleased with the display and would recommend DLP technology to all. Although it's early days yet, reliability seems good. I still think the 5 year warranty I took out at the time of purchase was a good idea.
Posted 14 August 2006 - 05:13 PM
Posted 19 September 2006 - 07:12 AM
Q: Where do you get replacement globes, and how much? Anyone know?
Posted 23 September 2006 - 11:23 AM
Anyone?
Posted 25 September 2006 - 02:26 PM
Posted 26 September 2006 - 06:37 AM
I bought a spare lamp on e-Bay a few months back for $250. I only bought it because it was so cheap. The woman who had them still lists them every now and then. The on-line sites that offer the projector lamps are asking $600+.
I would be very interested in the actual lamp life of these things. I've read that although LG quote 6000 hours, life is more like 4000. At 5 hours a day (typical usage here), that would work out to 2.2 years. Nowhere near as good as 3.3 years!
Posted 26 September 2006 - 06:58 AM
Can you give a link, so I can go investigate? Also, what is the type of bulb, make/part number?
Thanks.
Edit: see below.
Edited by M.L.F. AKA Mike R., 26 September 2006 - 07:20 AM.
Posted 26 September 2006 - 07:12 AM
Thanks.
Your procedure doesn't appear to work with my TV. Have you missed something?
Search e-Bay under electronics for LG DLP lamp and make sure the TV model no is correct.
Posted 26 September 2006 - 07:18 AM
From last page of manual:
1. Press the OK or enter button on the front panel and MUTE button on the remote control simultaneously ( about 5 seconds).
Posted 27 September 2006 - 01:32 AM
so i got an component switch box with a remote works perfect every time and get just as good a picture as hdmi.
globe wars! im upto 2748
can anyone raise me?
Posted 27 September 2006 - 11:31 AM
Are you suggesting that I have a built in game on my TV and I have never realised?
Posted 27 September 2006 - 09:44 PM
I checked mine tonight and its done 2806,consider yourself raised.
Posted 27 September 2006 - 11:03 PM
would be intresting to see if anyone has got over the 4000 hour mark!
Posted 08 October 2006 - 06:34 AM
DISLIKES:
Posted 28 October 2006 - 04:01 PM
BEWARE: I took out the 4 year extended warranty also as was told by the salesman that the globes were covered. WRONG. But when I contacted the company they told me that the globes were not covered. The policy had been changed 2 months prior to my purchase in end of July 2005. No help from the major company I purchased the TV from, but guess what today they still didn't know about the change in the extended warranty info about the lamp not being covered……Who would’ve guessed. They did find a price for a replacement lamp for $250 after looking on the net and Ebay that’s a damn good price, so I ordered one. I picked up the lamp 3 days later…..very good service as direct from LG to Frankston Vic...
Got home and fitted the new lamp and still nothing on the screen except black, and that damn flashing green led. Not happy Jan…#%@$$@&
Is there anything else that I can try before calling in the techs’
Sparkz181
About the globe hours for the LG DLP 52SZ8R, I found that the LG info in Australia when I purchased the TV was 4000 hrs and still is but when I was looking for info about globes I found that the TV in Canada has an 8000 hrs rating …….. yes amazing twice that of OZ.
Posted 28 October 2006 - 05:05 PM
Posted 29 October 2006 - 08:29 AM
sparkz181, on Oct 28 2006, 08:16 PM, said:
If your set is still no-go after the globe replacement, there is obviously still something else wrong with the set. You have an extended warranty, exercise that warranty and get your set seen to. Ring up good guys, and seeing they have sold you the set on behalf of the manufacturer, and sold you a extended warranty on behalf of the finance group who provide that extension, get them to either recieve the TV at their store for repairs, or they get repairs organised for you.
They either fix or replace your set of an equivalent model, or your money back.
Go get'em tiger...Grruff.
#21
Posted 30 October 2006 - 01:51 AM
Thanks for your help and support, I will be chasing it. It is as I suspected.
Sparkz
#22
Posted 30 October 2006 - 06:54 AM
sparkz181, on Oct 30 2006, 02:51 AM, said:
Sparkz
You never know, you may end up with a later generation set, with less probs.
Quite certain your apples as you have VCAT to fall back on, for a nominal fee of $38.50 they will certainly always back the consumer even with it just being over the reg 12 month period of warranty.
M.L.F. AKA Mike R., on Oct 30 2006, 07:54 AM, said:
Simple argument:
Did manufacturer set out to make a TV set to last for only a 12 month period- if yes, then the retail price should have been set in accordance to the duration of product useability and reflect the short term nature of the investment ie: set should have been on sale for realistically around $250 mark (given that at time of purchase the set would have been at a retail of the $2,500 mark, and the consumer typically buys a TV set with expectation of it lasting an acceptable level of time ie: 10yrs), as that would be a generally accepted price based on expected life of the goods. So the answer would of course be no (to 12 month expected life), so the consumer comes out everytime with a ruling to their benefit of a fixed or replaced equivelant product. Because 'just out of warranty period' is always treated as unacceptable to consumer rights, and business is always deemed to bring an acceptable level of product/workmanship to the marketplace that is in the realms of fair and reasonable for a product/service within that industrys norm.
This of course can be applied to a wide range of consumer products and/or services. Its your implied right!
Thank you and happy shopping, Agent Mike. ©2006.
#23
Posted 31 October 2006 - 08:17 PM
i have the lg132cm dlp also and am really happy with it., until the other day, when the lamp indicator light flashed red and the lamp went out.
turn the tv back on and it work for 5 to 15 mins and turns itself off!!
the picture quality is totally fine for the timne that the telly is on but the lamp just flicks out and it makes the clunky noise that they make when you turn them on..
rang lg and they say i need a new lamp. i dont believe them because the lamp indicator is not orange, its flashing red!
tv is only 4 months old.
any ideas? i pulled the lamp out and had a look, nothing visibly hanging off!!
put it back in and all back together and same problem is still there..
hope someone can help me with this problem, cheers
#24
Posted 31 October 2006 - 08:34 PM
1408 here...
#25
Posted 01 November 2006 - 04:54 AM
My manual doesn't have this information. Perhaps its because my TV is one of the first ones sold (16/7/05) . So I tried the lamp check thingy as you described and horror .... shock ..... 3446 hours! It looks like I under-estimated my usage a fair bit.
