Antenna Survey -band 3 & Band 5 (channels 6-12, 36-69)
No replies to this topic
#1 alanh
  • 12,290 posts
Posted 14 May 2006 - 11:19 PM
For more detail read Antenna Design Basics + Amplification
This list is selected on the basis of the channels covered only and quotes the appropriate website’s antenna gain.
The higher the number of dB the larger the antenna, the more sensitive and more directional it is. It is also more expensive. The advantage of getting gain from the antenna rather than an amplifier, is that the antenna becomes more focussed thus rejecting delayed signals and interference sources. Amplifiers can become overloaded which antennas cannot. Thus amplifiers can make reception worse.
If the antenna signal is too strong at the receiver, a low cost attenuator can be used. The advantage of this method is that any interference picked up by the cabling is also reduced.
The antennas below are for prime signal areas. For more sensitive antennas use the band 3 vertical recommendation and the band 5 horizontal recommendations. They can be combined in a U/V diplexer or a masthead amplifier.
Yagi – Band 3 Channels 6-12 and Band 5 Channels 36-69
Horizontally polarised local reception and medium distance)
Vertically polarised diffuse reception (either long distance or blocked by terrain)
Matchmaster catalog
Nil
Hills Antennas
UV13/5069 Band 3 6-7.5 dB Channels 50-69  12-15 dB
Laceys TV - Fracarro
Nil
WISI
Nil
Clipsal
2ANUV13WB Gain Band 3 7 dB Band 5 (Channels 50 - 69) 12 dB
Phased Array - Band 3 Channels 6-12 and Band 5 Channels 36-69
Vertically polarised local reception and medium distance)
Horizontally polarised diffuse reception (either long distance or blocked by terrain)
Nil
Please post errors and omissions here
Edited by alanh, 17 January 2009 - 09:46 PM.
