This list is selected on the basis of the channels covered only and quotes the appropriate website’s antenna gain.
The higher the number of dB the larger the antenna, the more sensitive and more directional it is. It is also more expensive. The advantage of getting gain from the antenna rather than an amplifier, is that the antenna becomes more focussed thus rejecting delayed signals and interference sources. Amplifiers can become overloaded which antennas cannot. Thus amplifiers can make reception worse.
If the antenna signal is too strong at the receiver, a low cost attenuator can be used. The advantage of this method is that any interference picked up by the cabling is also reduced.
Yagi - Band 4+ Channels 27-49
Horizontally polarised local reception and medium distance
Vertically polarised diffuse reception (either long distance or blocked by terrain
Matchmaster catalog
02MM-DR18B Channels 28 – 50 12 – 14 dB
Hills Antennas
SF91 B4 PLUS Band 4+ (Ch28-50) 14 - 18 dB
TMX20 Band 4+ (Ch28-50) 8.5 - 15 dB
TCX20 B4+ Band 4+ (Ch28-50) 8.5 - 15 dB
TMX14 Band 4+ (Ch28-50) 8 - 13 dB
National Antenna Systems page 6
ANTSXU28-50/19 Band 4+ (ch 28-36) ≤11 dB
Laceys TV - Fracarro
Narrow band Yagis
10/3539/R Channels 36 – 41 11 dB
10/4046/R Channels 41 – 48 11 dB
WISI
Clipsal
Phased Array - Band 4 Channels 28-49
Vertically polarised local reception and medium distance)
Horizontally polarised diffuse reception (either long distance or blocked by terrain)
Note Band 4+ only are not available.
Fracarro PU16H Band 4-5 15-20 dB for horizontally polarised signals
Fracarro PU8H Band 4-5 12-16 dB for horizontally polarised signals
Fracarro PU8V Band 4-5 12-16 dB for vertically polarised signals
Fracarro PU4 Band 4-5 9 – 12 dB Horizontally polarised signals
Fracarro PU4 & PVP Band 4-5 9 – 12 dB Vertically polarised signals
For Horizontal and Vertical polarisation mounting
Super Hunter Band 4-5 11.5 – 15 dB
Mini Hunter CKD Band 4-5 7.6 – 11.1 dB
WISI
EE06 Band 4-5 ≤13.5 dB
Matchmaster
02MM-EE06 Band 4-5 ≤13.5 dB
02-ER08 Band 4-5 ≤11 dB
02-ER04 Band 4-5 ≤9 dB
ANTEE06 Band 4-5 ≤13.5 dB
ANTFAU-L Band 4-5 9 – 12.5 dB
ANTPL10 Phaselink Band 4-5 9-11 dB
Jaycar, search for LT3138
Band 4-5 ≤12 dB
Dick Smith Phased Array L3087
Band 4-5 8-13 dB
[url="http://www.clipsal.com/trade/__data/page/81/D32.pdf"]Clipsal
2AUNPA1 Band 4-5 Gain 8 - 11 dB
2ANUPA2 Band 4-5 Gain 13.5 dB
Please post any errors or omissions here
Edited by alanh, 17 January 2009 - 09:04 PM.
