Antenna Survey - Band 3 Only (channels 6-12)
No replies to this topic
#1 alanh
  • 12,296 posts
Posted 14 May 2006 - 10:47 PM
For more detail read Antenna Design Basics + Amplification
This list is selected on the basis of the channels covered only and quotes the appropriate website’s antenna gain.
The higher the number of dB the larger the antenna, the more sensitive and more directional it is. It is also more expensive. The advantage of getting gain from the antenna rather than an amplifier, is that the antenna becomes more focussed thus rejecting delayed signals and interference sources. Amplifiers can become overloaded which antennas cannot. Thus amplifiers can make reception worse.
If the antenna signal is too strong at the receiver, a low cost attenuator can be used. The advantage of this method is that any interference picked up by the cabling is also reduced.
Yagi - Band 3 (VHF) Channels 6 - 12
Horizontally polarised local reception and medium distance)
Vertically polarised diffuse reception (either long distance or blocked by terrain)
Matchmaster catalog
03MM-DR3018 Band 3 ≤14 dB
03MM-DR3010 Band 3 ≤9.5 dB
03MM-DR3006 Band 3 ≤8.1 dB
03MM-DR3004 Band 3 ≤7.0 dB
Hills Antennas
DY14 Band 3 9-14 dB
DY10  Band 3 8-11 dB
DY6  Band 3 6-8 dB
DY4  Band 3 5-7 dB
Laceys TV - Fracarro
14E512 Band 3 10 dB
11E512 Band 3 7 - 10 dB
BLV6F Band 3 7.5 - 11 dB
BLV4F Band 3 6.5 - 8 dB
6E512F Band 3 5 - 7 dB
4E512F Band 3 5 dB
Single channel Yagis
11xxx range one model for each channel between and including channels 6-12 Gain 12 dB
6xxx range one model for each channel between and including channels 6 - 12 Gain 9 dB
WISI
FA49 Ch 6-7, ch8-9A or ch 9A-12 Gain 11.5 dB
FA47 Ch 6-7, ch8-9A or ch 9A-12 Gain 10 dB
FA45 Ch 6-7, ch8-9A or ch 9A-12 Gain 8.5 dB
Nationwide Antenna Systems
ANTSC14-6/12 Band 3 ≤11.5 dB
ANTSD10/6-12 Band 3 ≤9 dB
Academy TV Ausralia
ATVD10 Band 3 11-12 dB
ATVD18 Band 3 14 dB
Clipsal
2ANVY7 Band 3 Gain 8.8 dB
2ANVY10 Band 3 Gain 11 - 12 dB
2ANVY18 Band 3 Gain 14 dB
Phased Array - Band 3 (VHF) Channels 6-12
Vertically polarised local reception and medium distance)
Horizontally polarised diffuse reception (either long distance or blocked by terrain)
Matchmaster catalog
CPA16H Band 3 10.5 - 12.5 dB Mounted for horizontal polarisation
CPA16V Band 3 10.5 - 12.5 dB Mounted for vertical polarisation
CPA8H Band 3 7 - 9.5 dB
CPA8V Band 3 7 - 9.5 dB
Hills Antennas
CA16 Band 3 11 – 19 dB
CA8 Band 3 10.5 - 17 dB
Clipsal
2ANVPA1 Band 3 Gain 7 - 9.5 dB
2ANVPA2 Band 3 Gain 12 dB
Please post any errors or omissions here
Edited by alanh, 19 March 2009 - 11:32 PM.
