alot of confusion can be caused with the amount of DVB-T cards on the market atm and so many mixed opinions and features on each. So I decided to do a quick run-down of the basics of each card as a reference point for those struggling to come to grips with it all
Avermedia AverTV:
SDTV: Yes
HDTV Live: Almost non-existant
HDTV Recording: Almost non-existant
Analogue Inputs: Yes
Bundled Software: AVerTV 1.3.26.3
Public SDK: Unknown
3rd Party Software: Unknown
Linux Support: No information, presumed not supported. The card uses the Microtune 7202D frontend.
EDIT: Apparently there is a case of it working and there are a few people working on it here. There is also a HOWTO on this card here.
Approximate Price: $190
Distributors:
Unknown
Resellers:
Northside Antennas
MATS Systems
ComputerMarket
AusPC Market
Storeonline.com.au
CWorld
Chaintech DTT-1000:
SDTV: Yes
HDTV Live: Yes with latest Digitop
HDTV Recording: Yes
Analogue Inputs: No
Bundled Software: digiTOP/Media TV
Public SDK: Technically no, but prehaps possible to use VisionPlus SDK
3rd Party Software: Technically no, but there has been reported success using some VisionPlus software
Linux Support: The manufacturers website claims linux compatibility, but so far this has not been confirmed by anyone. (Apparently it uses the BT878a frontend, and the NxtWave backend. It's possible that the guide for the Nebula DigiTV will gain you support for this card too.)
Approximate Price: $165
Distributors:
Unknown
Resellers:
AusPC Market
Dpanda DigiTV PCI:
SDTV: Yes
HDTV Live: Yes
HDTV Recording: Yes
Analogue Inputs: No
Bundled Software: TechnoTrend's 2.16 software
Public SDK: Yes
Linux Support: Apparently works with the same drivers as the WinTV Nova-T. There has been several confirmations of it working around the place and the manufacturer's website claims it is supported.
Approximate Price: $240
Distributors:
Unknown
Resellers:
DPandA
Hauppauge WinTV Nova-T:
SDTV: Yes
HDTV Live: Yes
HDTV Recording: Yes
Analogue Inputs: No
Public SDK: Yes
Linux Support: Full support. This was the card that the linux DVB-T drivers were initially written for, and as a result it has the most mature support.
Distributors:
Kristal Electronics
New Magic
Resellers:
HyperReality
SmartGadgets
DigitalNow
Northside Antennas
Nebula DigiTV PCI:
SDTV: Yes
HDTV Live: Yes
HDTV Recording: Yes
Bundled Software: DigiTV
Public SDK: No
3rd Party Software: NebulaEPG
Linux Support: Support exists, but takes a degree of fiddling around in CVS to get. There's a guide located here.
This driver appears not to have been added to the 2.6.0-textX kernel tree yet, so presumably won't initially exist when kernel 2.6.0 is released.
Approximate Price: $300
Distributors:
HyperReality
DigitalNow
Resellers:
Unknown
VisionPlus VP-DTV-T:
SDTV: Yes
HDTV Live: Yes
HDTV Recording: Yes
Analogue Inputs: No
Bundled Software: WinDTV
Public SDK: Yes
3rd Party Software: DigiBox, Webscheduler, XMLTV add on, ProgDVB and SDTVR
Linux Support: Yes - click here for info.
Approximate Price: $220
Distributors:
DigitalNow
Resellers:
Home Theatre PC
Elliemount International
NOTE on HDTV:
All DVB-T cards are capable of HDTV. Whether or not it will display/handle it is based soley around the software/drivers for the card. Currently the order of the maturity of HDTV reception for each of these cards is approximately as follows:
1. VisionPlus/Nebula/DTT-1000
2. DPandA
3. Nova-t
4. AverTV
Big thanks to HyperReality whom I "borrowed" the list of distributors for each card from
And also to this whole forum for your constant informative input!
EDIT: Thanks to Quadbox over at OCAU for all the linux info! (and now also Gumby and michal for the AverTV linux stuff).
Thanks also to tvboy about importing the Nebula.
Enjoy and I hope it's helpful,
Adam
