Help Recommend New Tv < 50"
HDTV Computer HTPC
No replies to this topic
#1 thorpef1
thorpef1
  • 14 posts
Posted Yesterday, 04:15 PM
Hey guys.
Im looking for a TV to put in my room that will be plugged into my computer to stream 1080 and 720 movies.
It will only be on a few hours a week so i dont want to go spending thousands and thousands of $$. Im thinking under $1000.
50" is the biggest i can go so anything between 40- 50"
I dont have to worry about glare and sunlight as it will be used at night.
I have heard that plasma may be better as they perform better in dark room.
Since it will be plugged into my computer i dont need any fancy features such as Smart TV, or 3D
What do you recommend?
Ill be going to a few shops over the weekend but is there anything that i should keep an eye out for?
Luke
Also tagged with one or more of these keywords: HDTV, Computer, HTPC
