Sanus Vmpl50Ab - Tilting Wall Mount
TV Wall Mount Bracket
1 reply to this topic
#1 kentwell22
kentwell22
Posted 07 June 2013 - 12:05 AM
VMPL50A - Tilting Wall Mount
For 32" – 70" flat-panel TVs
The SANUS VMPL50A is a tilting wall mount for 32" – 70" flat-panel TVs. SANUS’ Virtual Axis™ tilting system provides easy adjustment of viewing angle with just the touch of a finger. ProSet™ post-installation height and leveling adjustments ensure TVs are always perfectly positioned after hanging. Its solid heavy-gauge steel construction offers a sleek, high-tech look while providing strength and durability. Adjustable TV brackets offer lateral shift ability to allow perfect TV placement, even with off-center wall studs. TV is positioned just 4.57 cm from the wall for a clean, low-profile appearance. Universal mounting pattern fits virtually any LCD or plasma TV up to 68.18 kg. UL certification ( tested to 4 times its rated weight for a minute) and has a 10 year warranty as standard.
Installation was a breeze with this mount. ProSet™ is the best feature I have ever seen on a bracket. After levelling my wall plate, hanging my TV and standing back, it look liked my TV wasn't level. After measuring up, it was my ceiling that wasn't level. With ProSet™ I was able to adjust one of the arms with an Allen key, without taking the TV off the wall.
Overall, I am very happy with the mount and appreciated the quality.
#2 kentwell22
kentwell22
Posted 07 June 2013 - 12:07 AM
www.sanus.com.au
