Foreign Satellite In Oz
8 replies to this topic
#1 Baboy
Baboy
  • 245 posts
Posted 27 May 2013 - 07:27 PM
If I brought this gear from the Philippines back to Australia would it work?
I can buy the equipment outright and setup a subscription/payment method but is it as simple as having it installed correctly and away u go?
Thanx.
http://www.cignal.tv/Home.aspx
http://www.cignal.tv/Postpaid.aspx
#2 Tazzy2Heads
Tazzy2Heads
  • 270 posts
Posted 27 May 2013 - 08:10 PM
For starters what Satellite and can you receive it where you are in AUSTRALIA and what band C or Ku?
Tazzy
#3 Baboy
Baboy
  • 245 posts
Posted 27 May 2013 - 09:02 PM
Would I be asking the original question if I knew all that?    :poke:
#4 mtv
Posted 27 May 2013 - 10:21 PM
Without knowing what satellite carries the programs, the band used and if the beam covers Australia, we can't give you any idea.
FAQ
Frequently Asked Questions
Where is Cignal available?
Cignal is available nationwide and can reach even remote areas (mountains or beach fronts) and provinces. Because we transmit via satellite, our service is not dependent on cable infrastructure. All that is needed is the installation of our satellite dish and a clear line of sight to our Satellite.
From the link you provided, it doesn't tell us much, so if you obtain that info from the provider, then we can give you a better indication.
On the support page, it gives some info on frequency and they supply a universal Ku Band LNB, but no mention of which satellite they use.
http://www.cignal.tv...icle.aspx?id=15
If you have the equipment and a valid subscription, it will work providing the satellite signal is beamed into your area of Australia..... so you'll need to find out which satellite is used.
#5 Baboy
Baboy
  • 245 posts
Posted 27 May 2013 - 11:08 PM
Thanx ...that gives me a much better idea of whats needed.......I certainly dont know the finer points of satellites, signals etc.
I found this.....
For subscribers to receive Cignal broadcasts, they must acquire upon subscription the satellite dish antenna, remote control, and the set top box (Integrated Receiver-Decoder). Cignal’s prepaid electronic loading system, is powered by the prepaid loading platform of Smart Communications, Inc.[2] Cignal uses VideoGuard encryption system to protect its content from signal piracy. MediaScape is utilizing the NSS-11 satellite of SES to provide optimal coverage directly to the target markets.[3]
Cignal Digital TV uses the DVB-S2 digital television broadcast standard to accommodate both Standard Definition (SD) and High Definition (HD) TV broadcasts, as well as interactive services offered on their satellite TV service.
http://en.wikipedia....gnal_Digital_TV
I tried googling it but not sure which site will give me the correct info
Is this what I need to know?.......looks like a no   :no:
http://www.satbeams....ellites?id=2225
Edited by Baboy, 27 May 2013 - 11:13 PM.
#6 BamBBBam
BamBBBam
  • 1,005 posts
Posted 27 May 2013 - 11:17 PM
The footprint for that Sat doesn't look good for Aus...
http://www.lyngsat-m...com/NSS-11.html
#7 Baboy
Baboy
  • 245 posts
Posted 27 May 2013 - 11:27 PM
Yes sadly looks that way......
The gear was cheap as chips , subscription was only about $25 a month for a load of channels and my wife would have had her Filipino TV.
#8 Tazzy2Heads
Tazzy2Heads
  • 270 posts
Posted 28 May 2013 - 12:10 AM
SAT SES-7 looks like it beams to South Asia in Ku band (small dish) with AIRTEL DIGITAL TV and CIGNAL TV to North Asia
Google  Lyngsat SES-7 and see if airtel has the channels you want on the South Asia transponders.If you poke around the
Lyngsat SES-7 page there should be a footprint for the Ku band transponders for South Asia . I did see a footprint map that covered Australia but i'm not sure whether it was for C band or Ku band signals may have been for NSS-11, can't find it at the moment.
I have not had to look for NSS-11 or SES-7 so can't tell you if they are possible in Australia, they may be too low in the sky for Tasmania , someone on the big island will know or contact say Melbourne Satellites or a satellite supplier in your area or contact the pay tv people in Asia.
Good luck
Tazzy
#9 DansDans
DansDans
  • 2,656 posts
Posted 28 May 2013 - 09:23 AM
Probably doesnt help you but you can get the Cignal signal (lol) in Shanghai! - so their beam certainly is far and wide
I was in a bar in Shanghai and they had a Cignal STU as they had the required sports channels (ie Australia Network for the AFL and Setanta for the soccer)
