Where Can I Buy High Resolution Music Online?
Posted Yesterday, 08:38 AM
However, when I have browsed some high resolution music sites, the website says that they cannot allow a download to "your country". An example is the HDTracks website, which appears to have the most of the mainstream content that I am interested in. The Linn site has mostly classic opera type music, which while I might enjoy some of this, what I really want is the ITunes type content but available in 24 bit 96 kHz files.
Does anyone know where I can purchase mainstream type high resolution music from my Australian home residence ?
Posted Yesterday, 09:16 AM
If you are into classical, try also eclassical.com 2L is another with good recordings but obscure artists. However, HDTracks also has 2L and cheaper.
A word of warning. 24 bit is better in theory but a lot depends on the mastering. Be aware of re mastered ones because some are not much better than CDs..
Posted Yesterday, 09:27 AM
96/24 is a typical studio format for capturing, editing, and mixing, and for special effects using Digital Signal Processing. However there is no evidence I am aware of that in blind tests human beings can demonstrate an ability to distinguish between a stereo 96/24 master and a corresponding 44/16 CD, at usual recording and playback levels. [44/16 will have dither noise if you listen to a quiet section with extremely high gain, and the recording source had very low noise.]
So I fear that although you will no doubt lay your hands on high resolution format material you may find it sounds no better than a lower resolution version of the same material.
Posted Yesterday, 10:54 AM
Other sites includes 2L, lessloss (free I think) and B&W. The B&W music site isn't high res I think.
HDTracks - get Nirvirna Nevermind.. I doubt it's real 24bit, and probably mastered loud. But by gawd it's fun when you turn up the volume
Posted Yesterday, 12:21 PM
Had some interesting unexpected results. While I like the 96/24 Eagles Hotel California and luke warm on Fleetwood Mac's Rumours, I was more successful in picking the difference in Rumours than Hotel California!
The end result of this testing is I am more circumspect in acquiring 96/24 material, especially remastered ones. There are certainly good material where I can consistently pick the difference (Diana Krall's albums) and there are lots of so, so material out there. At the end of the day, I continue to enjoy the material I have (lots of 44/16 ripped from CDs, plus some 96/24 material).
Posted Yesterday, 12:27 PM
If looking for some genuine hi-res audio as pointed out 2L and specifically naim audio are excellent. There is even free stuff to down load. Just google their websites
Posted Yesterday, 01:29 PM
Posted Yesterday, 04:04 PM
Also good are recordings by Diana Krall on HDTracks. That is one classy lady (but how did she end up with Elvis Costello??). Partially explains why myrantz has tarred HDTracks
myrantz, on 24 May 2013 - 01:46 PM, said:
Posted Yesterday, 05:19 PM
myrantz, on 24 May 2013 - 10:54 AM, said:
Info about this here: http://www.dr.loudne...album=Nevermind
Posted Yesterday, 05:22 PM
Dr X, on 24 May 2013 - 05:19 PM, said:
Posted Yesterday, 06:59 PM
ccs, on 24 May 2013 - 12:21 PM, said:
The recommended method (on HydrogenAudio) for an ABX in these circumstances is to do your own conversion from 96/24 to 44/16 and then resample the resulting file back up to 96/24. If you use an appropriate noise shaped dither for the conversion from 24 bits to 16 bits, the dither will only be audible at an unrealistically (and uncomfortably) high gain setting. The free software Audacity is probably sufficient to use for the resampling.
You then (at normal listening levels) ABX the original 96/24 against the version downsampled to 44/16 and then upsampled back to 96/24. You should find the twice resampled version indistinguishable from the original version.
If you are prepared to try this method I have described, and you do find a 96/24 version of music that does not sound the same after two stage resampling, please let us know!
[By converting back to 96/24 you sidestep any slight colouration or amplitude difference or other performance difference your sound system DAC might introduce when processing a 44/16 format source compared with processing a 96/24 format source. You also automatically ensure your extracts of music are precisely time-aligned.]
Edited by MLXXX, Yesterday, 07:41 PM.
Posted Yesterday, 07:23 PM
Mr C, on 24 May 2013 - 01:29 PM, said:
by mainstream do you mean pop music. in case forget about it the mass bulk of pop music is pretty ordinary in original mixing, not much if any around in "hi-res" if you are finding much around it will most definitely be upsampled. and probably compressed in dynamics heavily to suit commercial radio.
probably re pop if wanting hi-res vinyl might be a better direction to turn towards
Posted Yesterday, 08:16 PM
Posted Yesterday, 09:51 PM
At the end of day, it is buyer beware. More importantly, if you enjoy the music and and find value in hi-res, then so be it. It is not for the skeptics to rage about it (thank goodness it does not happen here...)
Posted Yesterday, 10:06 PM
ccs, on 24 May 2013 - 09:51 PM, said:
If the ear cannot detect differences when concentrating on short A B comparisons, I suggest there is no difference worth pursuing.
In guitar music, a power chord (also fifth chord) is a chord that consists of the root note and the fifth interval. Power chords are played on amplified guitars, especially on electric guitar with distortion. Power chords are a key element of many styles of rock music.
[From: http://en.wikipedia....iki/Power_chord]
Edited by MLXXX, Yesterday, 10:50 PM.
Posted Today, 11:46 AM
How do any of us end up with the partners we have, or have had. Love really is blind.
Speaking of Diana Krall her latest album "Glad Rag Doll" is one of the best, and I have a full set 14 CD's
This download will get you the MP3 version http://kat.ph/diana-...2-t6696280.html
