In excellent condition with original box, remote (and allen key)
Missing manual but it is available online at:
http://www.aprilmusi..._Manual_Eng.pdf
Review at:
http://www.stereo.ne...mpdac/?hl=dp200
+ others on the net, google away.
SPECIFICATIONS
Digital to Analog Converter
Selectable 24Bit/192kHz Upsampling (Bypass, 48, 96, 24Bit/192kHz)
4 Digital Inputs AES/EBU, Coax 1,Coax2, Toslink
3 Digital Outputs AES/EBU, Coax, Toslink
AES/EBU: 110 Ohms
COAX 1, 2: 75 Ohms
Preamplifier
Inputs 1 Balanced (XLR), 2 Unbalanced (RCA)
Analog Input Voltage AUX 2: Max 1.4 Vrms
Balanced: Max 1.0 Vrms
Analog Outputs 1 Balanced (XLR), 1 Unbalanced (RCA)
Max Output: 3.5 Vrms
Digital Volume Control (FIXED, VARIABLE Output Mode, selectable)
Full Balanced Class-A Operation
Headphone Amplifier Interface & Socket
Bypass for Surround Processor
Full Function Remote (Standby, Upsample, Record, Display, Input, Volume, Mute, Bypass)
Dimension (WHD) & Weight
435 x 94.5 x 345(mm), 9 Kg
Price
$1200
Pickup preferred but can ship if required.
1 reply to this topic
