Future Of Community Radio On Dab Uncertain
Posted 20 February 2013 - 10:49 PM
Details here http://radiotoday.co...re-at-risk.html
I'd personally argue it's commercial radio not the government who should fund them - the bad choice of DAB+ that forces up the costs of broadcasting (compared to other digital radio technologies) just because the commercial radio stations wanted the scarce spectrum situation to continue on a new platform doesn't mean the Government needs to invest in a flop.
We have enough government funded broadcasting - the community stations should make their own decision as to the importance of DAB to their listener base, not just demand money to cover a new technology. They all stream on the web just fine - so I don't know where these millions in ongoing costs are coming from if it isn't the commercial stations charging carriage costs to profiteer from the government funding in the first place.
Posted 21 February 2013 - 06:45 AM
GoForMoe, on 20 February 2013 - 10:49 PM, said:
I also don't see the point of community radio going to DAB+, unless the community radio station is stuck on a crummy medium wave band frequency. I'd like to see 1RPH get on the DAB+ test here in Canberra, for example, instead of the plethora of tape loops we get. But I have yet to see a DAB+ radio without an FM section (do any even exist?), so why bother going DAB+ if you transmit FM? Internet streaming is probably a better choice.
Posted 21 February 2013 - 10:48 AM
In Canberra alone 91.1 1CMS, 91.9 1WAY, 92.7 1ART, 98.3XXR and 89.5 VFM are all FM community stations. All but VFM are the same power as the commercial FM stations.
All city wide community stations in Sydney, Melbourne, Brisbane, Adelaide and Perth are available on DAB+ and FM. Some community stations have taken the initiative and made their DAB+ programs different to their FM programs most however are simulcasts. Some community stations do not even mention that they are also transmitting on digital radio.
City wide community stations should stay on DAB+ so that the coverage area matches all other broadcasters in that licence area.
For citywide community stations high power FM is quite expensive to run so taking a quite small proportion of the transmission costs of the commercial DAB+ transmission is actually cheaper. It is the simulcasting which is causing the cost blow out. There will come a time when enough of the audience is digital radio equipped that the FM and AM transmitters can be switched off making transmission much cheaper.
What has not been addressed is the smaller low powered community stations particularly those in the country and those serving a small part of a city licence area. These need to be given either a DRM+ or a DRM30 allocation where their transmission power can be reduced by at least a quarter. This however is a way off.
Streaming will not get community radio an audience because the audience has to pay for the privilige directly.
Posted 21 February 2013 - 11:47 AM
Amusingly however, the two stations with non-simulcast programming in Melbourne are Vision Australia Radio - who are on AM and thus should have done an AM simulcast and Light FM who did a funding drive to cover the costs.
Obviously if digital radio reached a critical mass then the community stations could cut across with a short simulcast like community television did - but it certainly isn't viable, nor a justifiable taxpayer expense, to prop the sector up for what would at least be a 10-20 year proposition, if ever.
Edited by GoForMoe, 21 February 2013 - 11:48 AM.
Posted 21 February 2013 - 07:29 PM
The usual load of rubbish
You rave on about quality of sound, the quality of the sound from the community broadcasters in Perth on FM is indistinguishable from that on DAB+. Some broadcasters feed their DAB+ modulators with processed audio which sounds terrible, as I found in Brisbane recently. Program content is much more likely to drive sales of receivers and listening time than technical quality provided it is no worse.
As far as CBAA goes, an election is coming and they want a grant. Transmission costs are not the major cost in running a radio station.
So what proportion of the high powered community stations have their listeners use the internet when they are in the local licence area?
Posted 21 February 2013 - 07:49 PM
Besides, regardless of your views on sound quality, you totally fail to address the wider point - if different content is the driver of digital listening, then you need to be able to fit both that different content and the existing AM/FM content within the spectrum currently allocated to a single service to be able to switch analogue off.
Posted 21 February 2013 - 08:42 PM
Have you listened to these stations in Perth, and not on line?
The city wide community stations, high powered FM transmitters cost a lot more than sharing a small proportion of a DAB+ transmitters.
The major costs are labour, premises costs, training costs, program purchases and studio equipment. Whilst community stations use volunteers, they also have paid staff in the bigger stations
Posted 21 February 2013 - 09:03 PM
Post a sample of it in comparison to FM if you want to disprove my point - you can do it in a single blind way by alternating between audio sources and uploading in a lossless format. You won't of course.
Posted 21 February 2013 - 09:22 PM
Posted 21 February 2013 - 09:36 PM
holdencaulfield2007, on 21 February 2013 - 09:22 PM, said:
Something needs to be a significant improvement to get people to move to it - the extra channels did it for digital TV - but when there's very little compelling new content (I quite like Koool and Aussie, but there's a bunch of overseas stations I prefer) and poor or just equivalent sound, so there's not a quality driver to uptake like HD was for TV. I find AM/FM satisfactory in the car - and everywhere else I'll usually have an internet connection. I don't own a WiFi enabled radio, but if I listened to radio a lot more (I prefer just putting my own music collection on) it would certainly be my preference, something I also occasionally do in the car.
My biggest issue is that there was another option besides DAB+ for digital radio that would have solved many of the bandwidth issues we have with it now - given us both improved sound and more choice. So now we're stuck with something that's already over capacity in some areas and no way to improve things.
Posted 22 February 2013 - 11:22 AM
Firstly there is one DAB+ transmitter carrying 7 commercial stations and the other two channels on the transmitter are spread between the high powered community stations. So in Perth and Adelaide this is all the high powered community stations.
In Sydney, Melbourne and Brisbane half the community stations share a DAB+ transmitter with 7 commercial stations.
The DAB+ transmitter is very similar to a DTV transmitter. Your many millions of dollars shows your ignorance. Even transmitting TV at the same power is well less than a million.
How can you compare the online and DAB+ signals when the compression systems are different. You have to hear them as they are transmitted. FM also alters the signal because of pre-emphasis.
This means that if the FM signal contains high volume high frequencies they are easily distorted but the lower frequencies are not.
Another with "golden" ears. Try double blind comparisons where you do not know the source of the sound. If you are happy with the mono, lack of high frequency sound in AM then I prove my point.
Edited by alanh, 22 February 2013 - 11:23 AM.
Posted 22 February 2013 - 12:36 PM
You've still not commented on the digital to digital comparison - so I'll present it again - can you seriously not tell the difference between a station like 96fm on digital and stations like Capital Digital or InfoRadio?
You're in a position to supply comparative audio - I am not (though would do likewise for the Melbourne stations if you do it for Perth).
In a car situation where I have engine noise and often a fan going, then AM is often sufficient - besides, the station I listen to on AM is NewsRadio, whose Parliamentary broadcasts that I want to listen to are not available on DAB+ because the ABC put alternate programming on NewsRadio on DAB+ but don't offer the replaced programming anywhere. I can occasionally get NewsRadio on FM from Ballarat, which sounds far superior, but I'll take AM over not being able to listen at all.
Posted 09 March 2013 - 08:11 AM
GoForMoe, on 21 February 2013 - 11:47 AM, said:
There won't be an AM/FM switchoff. It would annoy far too many people too much, and would mean that people would have much poorer access to telecommunciations during long blackouts.
This said, much of the currently AM allocated spectrum may end up being used for digital transmission, but if this occured I would wager on a few high powered analog stations remaining, carrying ABC Local Radio.
Posted 09 March 2013 - 08:16 AM
GoForMoe, on 22 February 2013 - 12:36 PM, said:
I too have wondered about this. Given that the ABC has so many online streams, including two that are *always* either a test tone or a simulcast of another feed, it is very strange that they do not offer a dedicated NewsRadio Parliament feed online, if not on DAB+ as well.
Posted 09 March 2013 - 11:00 AM
I note that alanh has fallen silent.
Posted 09 March 2013 - 12:40 PM
matturn, on 09 March 2013 - 08:11 AM, said:
Posted 09 March 2013 - 06:57 PM
GoForMoe, on 09 March 2013 - 12:40 PM, said:
Posted 09 March 2013 - 08:07 PM
holdencaulfield2007, on 09 March 2013 - 06:57 PM, said:
#19
Posted 09 March 2013 - 08:53 PM
GoForMoe, on 09 March 2013 - 08:07 PM, said:
Posted 12 March 2013 - 06:50 PM
#21
Posted 15 May 2013 - 01:10 PM
CBAA President Adrian Basso says the government has "jeopardised" the future of community digital radio: “This is a disappointing outcome for all the communities who rely on community radio to provide the information, opinion and music commercial stations and the national broadcasters can't or don't.”
The community sector will now consult with its members and is seriously contemplating turning off services or networking nationally.
http://www.radioinfo.com.au/news/12500
However, radio services on VAST have gotten funding:
“The VAST service is being deployed across Australia to provide digital television and radio services in remote and regional areas, replacing the Aurora satellite platform, which will cease transmission at the end of 2013,” Senator Conroy said.
#22
Posted 16 May 2013 - 12:04 PM
After reading through this thread, it has come to my attention that we're comparing Pears with Apples
Have a listen to FM here in Melbourne, it has a more wider Stereo sound, than what DAB offers, that's mainly due to bitrates
Also, in alanh's post from February, 89.5 Valley FM is licenced for Tuggeranong, so that is like a sub-metro station elsewhere. You can't put that in the same category as the other community stations in Canberra, but 1RPH can definately be grouped in that list
Also, with digital, some stations seem to be Mono, like ABC Grandstand and News Radio, yet RN and Local ABC stations are Stereo. Which is nice, but they're cramming more stations into tiny spaces, which makes it sound awlful. Try listening to Magic 1278 or The Buckle, the most dreadful sounding stations I've heard, and they STILL haven't fixed it, yet I've alerted them awhile back now. (Filters apparently, according to them)
Community stations, sound pretty good though
#23
Posted 16 May 2013 - 08:57 PM
One thing you should note is that what the ABC does regarding bitrates and stereo/mono does not affect what the commercial stations sound like as they are on different multiplexes (except Canberra/Darwin I believe). However, you have 3AW in Melbourne with 80 Kbps and 3AW+ at 48 Kbps which is just another copy of 3AW so I guess some commercial bandwidth could be used more efficiently.
#24
Posted Yesterday, 02:25 PM
I realise this point, I think Fairfax are filtering theirs a bit too much, when it first started, The Buckle sounded as good as 3MP does. Just can't tell those people at Fairfax to fix it apparently, because everyone thinks it sounds "perfect"
I heard from elsewhere, that 3AW+ was made, at less quality than their original station at 80kbps, because someone rang up (more than one person I presume) to say the quality of it isn't the same as AM radio (which is the whole point of Digital) so they made 3AW+
