Dynaudio Confidence 1 And 2 Review
Dynamic devastating bass
No replies to this topic
#1 petetherock
petetherock
  • 2,853 posts
Posted 18 September 2012 - 02:13 AM
I had a chance to audition them in Denmark, and later on in a more domestic setting:
In summary:
Like the B&W 804D, you need to invest in solid equipment, to make the best of the gear. And if you are spending most of your time in HT, then it maybe more prudent to invest in the best sub and other HT related gear.
But if you already have or are planning to invest in a solid two channel system, both of these speakers will impress you very well. The C1 is the better choice for most in small homes, but if you have the space, the C2 rewards you with a massive soundscape and scale that is hard to beat at any price. You just to spend a lot on the partnering components to achieve this.
So if you have the budget to buy a motorcycle you could instead buy a pair of one of these...
http://peteswrite.bl...-2-reviews.html
Edited by petetherock, 18 September 2012 - 02:13 AM.
