Problems With The Channel Gem
6 replies to this topic
#1 sharp_1
sharp_1
  • 97 posts
Posted 29 June 2012 - 02:09 PM
This is the HD TV I own  - http://www.hisense.c...led/type/38/209
Anyway, long story short, I have a problem watching the GEM HD channel on this HD TV. At first when you go on the channel, the audio is out of snych with the video. This problem useally corrects itself by giving me 5 seconds of slow frame rate before returng to normal. So that I can deal with.
The actual consistent problem itself however is that while the channel is still obviously HD, I am getting messy pixualiztion and macroblocking particualy when movement is invovled. I do not have this problem with any other HD or SD channel, only GEM. I also must note that I do not get this problem on my other 32" HD TV in my room on GEM or any other channel for that matter.
Can anyone help me out?
#2 mtv
Posted 29 June 2012 - 02:21 PM
See if you can get a firmware update for the TV.
#3 M'bozo
  • 2,673 posts
Posted 29 June 2012 - 02:58 PM
1) Unplug antenna cord from TV.
2) Do an auto tune function on the TV.
3) Put the TV in standby, unplug from power for 30 seconds.
4) Plug back into power, reconenct antenna cord, turn TV on, set tuning type as "DTV", then perform "Auto Tuning"
If that doesn't fix it, try Hisense help line on 1800 447 367.
#4 digital doctor spock
  • 54 posts
Posted 18 July 2012 - 10:35 AM
I would ring and complain to Channel 9
#5 Guest_stump_1100_*
Guest_stump_1100_*
  • Guests
Posted 18 July 2012 - 09:24 PM
And that would achieve nothing, he already stated that another TV receives the same signal with no issues! So not a transmission issue...
#6 andrewlace
andrewlace
  • 200 posts
Posted 19 July 2012 - 12:09 PM
With the Bodensee TV some needed the channel to be manually tuned. Try going into the settings and manually tuning with the correct channel I'm your area for channel 9. This is not a broadcaster issue. The major capital cities run off channel 8 for their main transmitters. Let me know how you go.
#7 andrewlace
andrewlace
  • 200 posts
Posted 19 July 2012 - 12:12 PM
The last post should have read Hisense lol
