Using The Viera Usb Hdd Recording Facility
1 reply to this topic
#1 RussellOz
RussellOz
  • 18 posts
Posted 27 June 2012 - 03:07 PM
I have a Viera TH-P50ST30A with a USB hard drive attached.
Is there a direct method of displaying what TV programs have been scheduled?
Currently I use the GUIDE to add any old thing so that I can get to the scheduled panel, then delete that scheule I just added. Then I can navigate through the schedule panel.
Surely there is a direct query facilty!!
Other than this, I am very happy with the recording/playback function
#2 pgdownload
  • 11,124 posts
Posted 27 June 2012 - 03:41 PM
Seems a bit of an oversight. I gave the manual a good look through and it doesn't look like there's a direct way to get to the timer list.
The only thought I had was if you get an option from watching TV, hit the MENU button then select the TIMER option.
Luck
