Satellite Signal
Posted 25 June 2012 - 06:33 AM
Posted 25 June 2012 - 06:58 AM
The next challenge would be the LNB LO frequency. I have no idea if VAST receivers let one select the LNB LO or if its fixed. If its fixed and doesn't agree with the existing Austar LNB's LO it won't work.
Posted 25 June 2012 - 10:23 AM
DrP, on 25 June 2012 - 06:58 AM, said:
Hi 'Drp'
Under the "Advance Options" you can Change the LNB LO on the VAST Box. some are still using a 11300 LNB, But one needs to be using a 10700 LNB as the VAST Platform will Swap to the Optus D3 Satellite in mid September.
Cheer's
The Baja
Edited by The Baja, 25 June 2012 - 10:25 AM.
Posted 25 June 2012 - 01:00 PM
Edited by nbound, 25 June 2012 - 05:44 PM.
Posted 25 June 2012 - 04:04 PM
Posted 25 June 2012 - 05:45 PM
Posted 29 June 2012 - 06:59 AM
Also the vast box does something crazy with diseqc. Every time I've hooked up a vast box to my motek based dish, to setup for a customer, It sends my dish off to it's limits when it does a firmware download and reset.
Posted 29 June 2012 - 10:49 AM
For a standard Austar/Foxtel box which requires only one cable from the LNB plus a VAST box with one cable, then a 10700 Dual output LNB is the simplest solution (one cable to each of the two decoders).
If you have Austar Mystar or Foxtel iQ, it requires both cables from a dual LNB, so you then need an additional cable for the VAST box.
You can do this with a Quad LNB (four outputs) or a multiswitch used in conjunction with the dual LNB.
I fimd a multiswitch gives a better result compared to a quad LNB.
Posted 02 July 2012 - 10:56 AM
I am Confident that the VAST Platform will Swap to Optus D3 Sat In September.
Cheer's
The Baja
Posted 07 August 2012 - 06:40 PM
Posted 07 August 2012 - 10:42 PM
The VAST tuning channel now identifies as D3 today on a receiver I had activated yesterday
Cheers Tazzy.
Posted 20 August 2012 - 10:37 AM
I had imported a Vast receiver with card which had been deemed active by a Queensland re-seller......yes we did the email activation....when the receiver arrived it did not work...our local installer said the card had been de-activated.
As an ex pat Oz I'd love to see either/or Vast channels or that Pay TV service......and I'd even pay the subscription. I'vefound out that more than a few Australian's bring in their Vast and/or Foxtel receivers to Bali...but then a local installer has his way with wjhat I consider very high prices......(see email below)
For the local descrambled service we have been using an "Open Box" with internet connection....and a Universal LNB...currently there are just a few fta radio channels, info TV and NITV...so there is a signal from Optus C1 here in Bandung....but I'm a little concerned about the forthcoming Optus D3 TX's.........the following email received from a Bali installer.....
Vast required more bigger antenna as the transmission will be move to
newer satellite D3. We can arrange bigger antenna and VAST decoder.
320 cm antenna and Vast decoder price IDR 42 million, price include
freight to Bandung. Price not include installation.
If you need viewing card for Win Imparja SBS ABC GWN7 it's IDR 2 million,
this is access card no monthly or any subscription.
(42 million Indonesian rupiah ....around 4 thousand 5 hundred aud)
Would appreciate comments from the forum about the above email from a Bali installer...our local Bandung installer's prices for Parabola/Dish and LNB's are fraction of the above quoted price....and would we really need such a large dish to receive Optus D3?
Why are we so keen to receive Oz TV? no HD at all on Indonesian Terrerstrial.......the so called pay TV services are poor technical quality......we do receive FTA from up to 14 satellites...thankl goodness for this.
My direct email is favenchi@yahoo.com
any forum comments will be much appreciated
regards
Favenchi
Bandung
Posted 20 August 2012 - 01:53 PM
Posted 20 August 2012 - 03:13 PM
Posted 23 August 2012 - 10:30 AM
Posted 23 August 2012 - 11:15 AM
Looking at the footprints, if you can receive C1, you should be able to receive D1 with the equipment you have now,
Posted 23 August 2012 - 11:30 AM
The Baja, on 02 July 2012 - 10:56 AM, said:
I am Confident that the VAST Platform will Swap to Optus D3 Sat In September. file:///C:/Users/David/AppData/Local/Temp/msohtmlclip1/01/clip_image001.giffile:///C:/Users/David/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif
Cheer's
The Baja
Hi Guy’s
As I have advised before Changes to the VAST service will take place shortly, SBS will move to D3, More Changes to Come.
VAST CAM Users Please read on.
On the 4th September 2012, changes will be made to the Aurora Digital Satellite Platform
that will impact the Viewer Access Satellite Television (VAST) services.
As a VAST CAM user, these changes may impact you.
SBS and Optus are planning to carry out service rearrangements on the Optus C1 and D3
satellites. This will result in a number of SBS VAST services moving from the C1 satellite
to the D3 satellite.
The service rearrangement is currently planned to commence at 02:00 am AEST.
The following services will be moving from C1 Transponder 4 (12,447MHz) to D3
Transponder 5 (11,886.5MHz):
TV
SBS ONE NSW 321
SBS ONE VIC 331
SBS ONE TAS 371
SBS HD QLD 340
SBS ONE QLD 341
SBS TWO QLD 342
SBS HD NT 380
SBS ONE NT 381
SBS TWO NT 382
SBS HD SA 350
SBS ONE SA 351
SBS TWO SA 352
SBS HD WA 360
SBS ONE WA 361
Radio
SBS National SE Radio 327
SBS 1 Sydney Radio 328
SBS 2 Sydney Radio 329
SBS National Qld Radio 347
SBS 1 Qld Radio 348
SBS 2 Qld Radio 349
SBS National SA Radio 357
SBS 1 SA Radio 358
SBS 2 SA Radio 359
SBS National WA Radio 367
SBS 1 WA Radio 368
SBS 2 WA Radio 369
SBS 1 Melb Radio 338
SBS 2 Melb Radio 339
SBS National NT Radio 387
SBS 1 NT Radio 388
SBS 2 NT Radio 389
Reception of services on the Optus D3 satellite will require a wideband LNB.
As the Optus C1 and D3 satellites are co-located, the same satellite antenna can be used
to receive services from both satellites.
To assist those without an existing wideband LNB, SBS and Optus will be providing
duplicates of the SBS services moving over to D3 on C1 temporarily.
The following duplicated SBS services will be provided for a period of 3 months on C1 Transponder 4 (12,447MHz):
TV
SBS ONE NSW 423
SBS ONE VIC 431
SBS ONE TAS 471
SBS HD QLD 440
SBS ONE QLD 441
SBS TWO QLD 442
SBS HD NT 480
SBS ONE NT 481
SBS TWO NT 482
SBS HD SA 450
SBS ONE SA 451
SBS TWO SA 452
SBS HD WA 460
SBS ONE WA 461
Radio
SBS National SE Radio 427
SBS 1 Sydney Radio 428
SBS 2 Sydney Radio 429
SBS National Qld Radio 447
SBS 1 Qld Radio 448
SBS 2 Qld Radio 449
SBS National SA Radio 457
SBS 1 SA Radio 458
SBS 2 SA Radio 459
SBS National WA Radio 467
SBS 1 WA Radio 468
SBS 2 WA Radio 469
SBS 1 Melb Radio 438
SBS 2 Melb Radio 439
SBS National NT Radio 487
SBS 1 NT Radio 488
SBS 2 NT Radio 489
These temporary services will be switched off on the 4th December 2012.
Further SBS service grooming will take place after the 4th December on a date to be
advised. Details of these changes will be made available on a future change notification
once the changes have been finalised.
Cheer’s
The Baja
Posted 23 August 2012 - 11:53 AM
#19
Posted 23 August 2012 - 02:48 PM
favenchi, on 23 August 2012 - 11:53 AM, said:
Hi 'Favenchi'
I have no news as to any changes to the D1 Services. but in saying that they could Make Changes anytime they want.
Cheer's
The Baja
Posted 23 August 2012 - 03:28 PM
For what its worth I have a customers VAST box that has just been activated and the 801 tuning channel identifies as D3. They have been doing that on the last recent ones I have installed. Don't know how long that has been the case ,its been a while since
the last lot.
Cheers Tazzy
#21
Posted 23 August 2012 - 04:51 PM
#22
Posted 23 August 2012 - 07:14 PM
the last lot.
Cheers Tazzy
D3 Tuning Channel has been operating for several months.
#23
the last lot.
Cheers Tazzy
I beleive it has always identified as "D3 Tuning Channel" or something to that effect.
#24
Posted 23 August 2012 - 07:22 PM
favenchi, on 23 August 2012 - 04:51 PM, said:
Yes, because a satellite decoder has a signal scale, it's possible to use just that if you know approx where to point the dish.
Lots of DIY setups are done that way.
It's not as accurate as professional signal measuring equipment and it's not as fast, but it can suffice.
The ABC/SBS signals on D1 are used for feeding terrestrial transmitters, mostly in remote areas.
They were never intended for direct to home reception.
These will likely be made redundant at some stage and those transmission sites will take signals from VAST.
Commercial channels were also unencrypted on D1 for a long time, until people started talking about them on forums such as this and the broadcasters encrypted them.
#25
Posted 23 August 2012 - 07:58 PM
this is a much appreciated summation.......with our current receiving equipment it is probably all we can get at the moment...that is if the local installers can "find " Optus D1...to get our 1.8 metre fixed parabola working for Optus C1, three installers were on the roof all day...and this is the tropics! A direct feed of ABC and SBS will be good to have....until something else better comes along. who knows we might have a Vast possibility yet!?
