They will be using DVB-T2 to cover the homes which do not have cable or satellite.
The transmitters will be installed by Kordia as a single frequency network.
38.9 Mbit/s data bandwidth will be transmitted at the same power at the existing transmission sites.
The UHF TV channels is 8 MHz wide.
The coverage area is expected to be the same as existing DVB-T transmissions.
The video compression will be MPEG-4 is the same as their existing DTV transmissions.
Irdeto Cloaked CA is a fully featured and renewable cardless conditional access solution that will enable IGLOO to deliver this content securely, while avoiding the hassle and cost associated with swapping out or replacing smart cards. As part of the agreement, Irdeto will also provide full implementation and testing of the solution.
The source I used is not generally available.
Edited by alanh, 22 June 2012 - 01:40 PM.
