I've just recently did a whole revamp of the coax in my house, everything is now RG6 quad shielded coax, matchmaster splitter and masthead amp, and the antenna got installed by a local tradie and is now a Matchmaster 01MM-DC21A.
Signal is great to TV 2 and 3, but TV 1 is horrid..... TV 1 gets turned on and you have to wait around 3-5 mins before the signal kicks in and you have a picture.
TV 1 is the shortest run out of the lot being around 3.5m from the splitter, the other two TV's are 12m+.
When TV 1 is turned on I can check the SNR and i get almost 99% noise and 0 for signal, when the picture finally kicks in its the other way around, almost 0% noise and 99 for signal.
I'm guessing that because it's such a short run the signal strength is too high to that TV and it's crapping itself....???
Even before I had the masthead amp installed it still had the same issue but would kick in slightly quicker..... now it's taking a lot longer to get a picture.
Here's a crude drawing of my setup, any input would be awesome. Thank you for reading.
Daniel
