2 X Foxtel Iqhd Boxes Simultaneously
okayokay22
, Jun 20 2012 06:02 PM
8 replies to this topic
Posted 20 June 2012 - 06:02 PM
Hi All,
Can you please help me clarify one simple point, as multiple google & thread searches have either turned up results from 2007/8 or nothing at all on my question.
Will using 2 iQ HD boxes (1 from a multiroom connection) at different addresses work at the same time without any issues?
note: both addresses have active cable connections (not satellite)
thanks in advance
thanks in advance
Posted 21 June 2012 - 06:43 AM
You aware that Foxtel has a program in place that when a service call is placed all receivers indicated to be present at the premises are checked for correct operation, right?
Posted 21 June 2012 - 08:54 AM
If you are happy with no service, that's OK by me.
Having made sure that you are aware of the issue, will it work? Yes. If set up properly at the other location it will work.
Posted 21 June 2012 - 10:23 AM
Pretty sure it's against Foxtels terms & conditions though..
Posted 21 June 2012 - 01:19 PM
Why dont you just take a box to your "mates" house and try,then you'll know for yourself.
Posted 05 July 2012 - 09:36 PM
Magnum72, on 21 June 2012 - 07:51 PM, said:
just dont connect phone line to order movies at 2nd address-
thanks Magnum, does the same rule apply to Ethernet port?
If it's not connected on ethernet / telephone port does that mean you can't remotely schedule programs from your iPhone etc for that box?
Posted 06 July 2012 - 09:26 AM
Remote scheduling setup is signalled via the satellite or cable system. It does not require the telephone line nor the ethernet cable to be connected.
