Ua46Es6200 Review?
3 replies to this topic
#1 soler37
soler37
Posted 11 June 2012 - 03:21 PM
hello, i cant find any review of this tv anywhere and it is only sold in some countries.
i was wondering has anyone seen this tv in display and have something to say about it, i can buy it over here but its not on display for now.
i would appreciate any review on this tv, thanks.
#2 davep
davep
  • 3,417 posts
Posted 11 June 2012 - 06:27 PM
ill tell you in a few days - just bought a 40" version of the same model for the kitchen/family room area.  Style played a big part in this one - wifes decision, however I cant see myself being unhappy with it.
#3 soler37
soler37
Posted 11 June 2012 - 06:33 PM
ok thanks but ill think im going to go buy it anyway, i saw the 2011 model D6400 and i liked the quality of the HD and 3D i dont think i can go wrong by getting the newer model
Edited by soler37, 11 June 2012 - 06:39 PM.
#4 davep
davep
  • 3,417 posts
Posted 25 June 2012 - 12:20 AM
Dont know if you still care, but after having it running for a week, im reasonably happy with it.  Its in a kitchen/family room area, so its set up in a bright mode, calibrated PQ isnt a priority.  It has inbuilt wireless - havnt tried it, as I run ethernet.  Having said that, once hooked up, it connected to the various Smart stuff easily enough (cable internet helps).  I cant say ill use any of the app's on a regular (or even semi regular) basis, but they seem to work.  The browser is clunky and unworkable, but you can pair a blurtooth keyboard and mouse, which might make it better.  Most people use their phones/tablets/PC's to browse anyway.
In terms of picture settings, theres everything you could ever ask for, including 10-point WB adjustments.  TBH I found myself putting it on "Natural", dropping colour & backlight down a couple of notches and turning down the Motion setting to "Clear" - seems to look nice enough.  The TV doesnt ship with a user manual (or even a CD), it kindly tells you to download your own, so I dont really know what the plethora of motion presets actually mean.  Of course, you can customise a preset, but I found Clear fine.
Turning the TV on is interesting.  It fires up quickly, and loads a channel quickly, but then is reasonably unresponsive for about 20 seconds - not sure why, possibly it could be loading the EPG and booting up the App's.  Which leads to the other interesting thing.  This TV seems to have 2 EPG's, a standard Samsung one, and a Freeview one.  The Freeview one seems to load 99% of the time, but sometimes if you are a bit impatient it'll jump into the Samsung style one - weird.
The 3D side of things.  Well the glass are dirt cheap.  Super flimsy thin frames with basically a couple of lenses attached, powered by a watch battery.  Once you're over that, the quality of the 3D is decent.  I have watched a few trailers off the Smart bit of the TV and have been impressed.  I have also done a few 2D to 3D plays, and it works quite well.  On such a small TV (40" version), I wont bother with 3D much at all though.
The edge-lit LED is reasonably uniform, but its not even close to the LG in the loungeroom for black levels (local dimming backlight), in fact the LG is a better TV in every aspect, including the implentation of streaming media to the TV.  The samsung does stream, however the LG does it in a much prettier way.
Its the perfect TV for my situation.  It looks good.  Its bright.  It has a reasonable enough picture whilst watching the news and playing xbox.  If I were looking for a model as the main lounge-room type TV, i'd look at a different model and/or brand.
