Bargara Reception
1 reply to this topic
#1 alanh
  • 12,325 posts
Posted 04 June 2012 - 02:37 PM
Jennifer,
In Wide Bay the SBS is the only UHF channel and your antenna needs to be horizontal. All other channels are VHF and need the antenna vertical.
Rotate the antenna so the longest section is at right angles to the horizon.
I suggest you use the "Get the best reception" post in each Geographic forum as you move around.
#2 nbound
nbound
  • 778 posts
Posted 04 June 2012 - 07:53 PM
Those Winegard caravan antennas dont go Vertical alanh. WInegard are an American company (US is Horizontal only), Im yet to see one with Vertical capability. If Jennifer plans on travelling alot her best option is to get a VAST Caravan Kit, and use a travellers authorisation.
Edited by nbound, 04 June 2012 - 07:55 PM.
