My mother in law has a Dell 1409X projector in the living room and she has just had IQ2 installed. Foxtel technician hooked it up with the old composite video as she didnt have any HDMI cables and the projector only has a DVi-D connector.
What do I need to do to get a HD (HDMI) picture (HD channels) from the IQ2 box into the Dell 1409X?
Del 1409X And Foxtel Iq2 Compatibility
Slattery
, Jun 03 2012 09:26 PM
2 replies to this topic
Posted 03 June 2012 - 09:26 PM
Posted 05 June 2012 - 02:43 AM
So long as the Projectors DVI-D input is HDCP compliant you will be able to use the IQ2's HDMI out to get the HD channels,
All you need is A HDMI to DVI cable (HDMI one end DVI-D the other)
http://www.bluejeans...ables/index.htm
Posted 05 June 2012 - 09:56 AM
Don’t forget that DVI will not support audio over HDMI so you will have to run separate audio connections
