Homecast Ht8000 No Sound
Likeyb
, Jun 01 2012 09:43 PM
10 replies to this topic
Posted 01 June 2012 - 09:43 PM
I have a Homecast HT8000 and overnight the sound stopped playing. The picture is fine. Sound works through all other devices ie amp, DVD, TV, DM Port and Xbox. It also records fine with sound. Any clues???
Posted 02 June 2012 - 12:13 AM
Tried bypassing amp? Tried using analog audio output instead of digital, or vice versa?
Posted 02 June 2012 - 07:51 PM
I plugged the HDMI cable directly from the PVR to the TV bypassing the amp but still no sound then I tried the old RCA cables direct from PVR to TV and still no sound? Very confused!
Posted 02 June 2012 - 08:49 PM
Done a hard reset (ie. power off at the wall)?
Posted 03 June 2012 - 02:43 PM
Never had the sound fail on mine ever, only prob I ever have is once in a blue moon when you change stations really fast, the tuners lock up and the unit says no signal. Hard reset fixes that.
Posted 03 June 2012 - 04:22 PM
Hi guys , had similiar problem with Aunt, and a Sony Blu-Ray Player.
Try Disconnecting HDMI, Turn power off at Both Unit ( if it has it) and wall,
leave about 5 minutes re-connect HDMI and Power, Then turn on.
Hope it helps.
Hope it helps.
Posted 03 June 2012 - 10:37 PM
Had high hopes it would be that easy but no such luck! Does anyone have any more ideas?
Posted 04 June 2012 - 07:13 AM
any more ideas?
Factory reset, then power off reset, (30 seconds should be fine), then retune.
Posted 06 June 2012 - 07:24 PM
Thank you M'bozo. It worked, didn't even need to do the power off reset just came back on immediately it auto scanned the channels.
Thank you so much, much appreciated.
Posted 07 June 2012 - 05:32 PM
My pleasure.
My pleasure.
