Cheapest Pvr To Be Able To Record From Satellite Receiver Outputs
RVR satellite receiver
9 replies to this topic
#1 Mikhail Sergeyvich
Mikhail Sergeyvich
  • 6 posts
Posted 23 May 2012 - 08:01 PM
I have pretty basic satellite receiver  with 1 component output , 2 AV ( i.e  RCA ) outputs.  What the simplest and cheapest device may be suggested for recording this satellite receiver output . My browsing Internet shows that  all cheap PVR(s) seem to be able to record from its tuner only. Would be possible for some existing  PVRs  to set time to record from its component input ?l
#2 nbound
nbound
  • 778 posts
Posted 23 May 2012 - 08:45 PM
Most HDD PVRs dont have AV (composite) inputs, but some do.
Most HDD/DVD Combo Recorders and DVD Recorders do have at least one AV input, which can usually be set to timer record.
Most relatively modern VCRs (ie. 90s/00s) can also timer record from AV in.
Im not aware of any device that will record from component in though (except pc capture cards). Though there might be a few specific models of other devices that do.
If you are watching FTA satellite, you could upgrade to a dual tuner satellite receiver. Though this would require extra cabling/new LNB/etc. if its not already cabled for a dual tuner device.
#3 pgdownload
  • 11,057 posts
Posted 23 May 2012 - 08:56 PM
As you've noted almost all PVRs don't record the output of another device. The few that do are expensive. You need to search for DVDR recorders.
The question if you need a harddrive recorder. A DVDR that only records to DVDs is under $100 however its not great for much more than a show or two a week...
One with a harddrive starts costing more. Second hand might be a good option. This looks good for $75 - The DVD bit isn't working but you don't need that.
#4 donhe7
donhe7
  • 176 posts
Posted 23 May 2012 - 09:59 PM
pqdownload quotes: You need to search for DVDR recorders.  A DVDR that only records to DVDs is under $100 however its not great for much more than a show or two a week..
Where would one find ANY DVD recorder without HDD nowadays?  A friend asked me to look for one, which has been a futile exercise up until now
donhe7
#5 prl
prl
  • 2,555 posts
Posted 24 May 2012 - 10:29 AM
Topfield TRF-2460 Masterpiece HD Plus and TRF-2400 Masterpiece HD. But only resolutions up to 576p.
#6 pgdownload
  • 11,057 posts
Posted 24 May 2012 - 10:45 AM
I just googled "buy dvd recorder". Look at the cheaper units for those without a harddrive.
Agree its not a solution I would recommend however if you want a down and dirty cheap solution then its an option.
#7 Mikhail Sergeyvich
Mikhail Sergeyvich
  • 6 posts
Posted 24 May 2012 - 11:24 AM
This one seems to be good enough.
http://crazystu.com....t-p-320666.html
Edited by Mikhail Sergeyvich, 24 May 2012 - 11:42 AM.
#8 pgdownload
  • 11,057 posts
Posted 24 May 2012 - 12:29 PM
Fits the bill. Can't speak to reliability. If you're happy with the $270 then its what you want and quite a bit more.
#9 heyhey
heyhey
  • 43 posts
Posted 03 June 2012 - 07:18 PM
Mikhail, What sat service are you trying to record? You might be better off buying a satelliter receiver with PVR recording option.
#10 DrP
Posted 04 June 2012 - 07:37 AM
Sales must be down eh heyhey?
