Speaker Advice $4000 Budget
Posted 23 May 2012 - 09:32 AM
Posted 23 May 2012 - 09:36 AM
Posted 23 May 2012 - 09:41 AM
For the $$ you're looking at you will likely get better bang for your buck if you look at some of the good second hand stuff in the for sale section.
Have a look at this thread for a nice set of Focals.
http://www.dtvforum....l=&fromsearch=1
While he's recently pulled the sale I think he would be willing to reconsider. RRP on that lot was ~$8-10K I think......
Agree with Dave, it would also be worthwhile considering an upgrade to the AVR when funds allow.
Posted 23 May 2012 - 10:04 AM
As for shops closer to home, you could try Sturmans in wollongong. About 35-40 minutes easy drive from campbelltown.
Edited by Gutty, 23 May 2012 - 10:41 AM.
Posted 23 May 2012 - 10:20 AM
bolo, on 23 May 2012 - 09:32 AM, said:
Posted 23 May 2012 - 10:39 AM
Gutty, on 23 May 2012 - 10:04 AM, said:
Thanks guys for your help... Might have to check out Eastwood Hifi..
Gutty when are you able to demo them? I'm free at nights... Would those speakers work ok with my Denon?
Posted 23 May 2012 - 10:53 AM
Yes, they will work with your denon, they're a reasonably easy speaker to drive. But as others have said, an amp upgrade would be ideal to get the best out of them.
Posted 23 May 2012 - 03:02 PM
Any suggestions on what amp is should be getting then? Not sure how much I can spend on that though...
Posted 23 May 2012 - 03:18 PM
miata, on 23 May 2012 - 10:20 AM, said:
A few tips when shopping at the above North shore emporium
Ware your best togs, borrow a 5 series Bemma, and find a fashion model to walk in with.
And you might just find someone who will bother to talk to you.
Or roll up in a rusty 1 tonner, in your working gear and Gum boots, and bring the Mother-in-Law.
Talk about " pass go, and go directly to jail"
Go to Eastwood for good value, price and service
You'll not go wrong at Eastwood for price value and service
Posted 23 May 2012 - 03:27 PM
Posted 23 May 2012 - 05:57 PM
Posted 23 May 2012 - 09:40 PM
bassett, on 23 May 2012 - 03:18 PM, said:
Posted 24 May 2012 - 06:41 AM
The "H" version uses a good quality compression driver in the same vein (although not as good) as Procella, Seaton, JTR etc
Go and have a look at most of the high end rooms being build these days, very few (except the small ones) use speakers with dome tweeters.....the world has moved on
Edit: Did you bother to look at the site at all or just looked at it and thought "a mother wouldn't love that?" until you hear it sing:
I see very few "hifi" speakers that can do that.
Why do you think Econowaves have taken the DIY world by storm? thats because they're darn good and cheap - short of DIY'ing one, the QSC's are the next best thing.....if you can get your head around the way it looks (but my recommendation is buy a bigger AT screen and hide them behind)
Edited by Elill, 24 May 2012 - 06:52 AM.
Posted 24 May 2012 - 12:14 PM
As for no one using Dome Tweeters, Tell that to Hi-end speaker manufactures .
I suggest you do a bit of research, before you make outrageous statements.
Then do a bit of a search, on peoples HT set-up's on here. or look here,
http://forum.audiogo....pl?vhome&1
Not a Plastic Box to be found.
Now I'm off for a Bex Powder and a good lie-down in
the sure hope I will recover from your comments.
Apologies to the thread starter, It would seem your thread has been
somewhat high-jacked
Edited by bassett, 24 May 2012 - 12:19 PM.
Posted 24 May 2012 - 09:48 PM
http://www.electroni...e/insane_sounds
http://www.electroni..._garage_theater
Here's another....uses high power capable ribbons...not seeing too many domes
http://www.electroni..._theater_design
Peter M's new room.....Procella/compression drivers again....odd, why would he part with $'000's on those...
Do you actually understand what the above graph is showing you? ffs
OP - just be an informed buyer. Most "hifi" shops in Australia don't understand this stuff yet, we're a cottage industry for HT in this country. Best of luck with your project/purchase
Edit: Seaton is very popular on DTV......uses compression drivers
Edited by Elill, 24 May 2012 - 09:49 PM.
Posted 25 May 2012 - 06:45 PM
TIA
#19
Posted 25 May 2012 - 06:49 PM
bolo, on 25 May 2012 - 06:45 PM, said:
TIA
any brand sub would do bolo. if looking for some good quality sub without spending the earth the legend kurlo at $1500 or kurlette at $1k are beaut options.
re surrounds I'd stick to focals for a consistent sound all around.
these are the matching surrounds,
http://www.focal.com...us-sr-800-v.php
but ay focal standmount can be used and would work in pretty well.
Posted 26 May 2012 - 10:16 AM
TIA
I think that package Gutty was offering included the matching sub and some focal surrounds....
Been to have a listen to them yet?
#21
Posted 29 May 2012 - 06:26 PM
TIA
Well worth checking those focals out, from reading Gutty's original ad sub and possibly surrounds are included. Certainly have a listen before you buy something else.
#23
Posted 03 June 2012 - 10:39 PM
4K or less would get you into any of these systems, which would serve your room size nicely.
Paradigm SE Speaker Package consisting -
1 X pair SE3 Mains
1 X Pair SE1 Surrounds
1 X SE Centre
1 X SE Subwoofer
http://www.paradigm....ies/se-speakers
Cancelled order in Gloss Black. Retail $5696, this package $2999.
Plus Yamaha RX-V1071 A/V Receiver, Retail $1699 now $999
http://au.yamaha.com...1_g/?mode=model
1 X Pair Paradigm Monitor 7 Main Speakers (V7)
http://www.paradigm....ies-7/monitor-7
1 X Pair Paradigm Atom Monitor Surrounds
http://www.paradigm....-7/atom-monitor
1 X Paradigm Centre 1 - Black Ash
http://www.paradigm....ries-7/center-1
1 X Paradigm PDR-80 Subwoofer - Black
http://www.paradigm....r-series/pdr-80
1 X Yamaha RX-V871 A/V Receiver
http://au.yamaha.com...k_l/?mode=model
Retail $4645, Now only $2690
1 X Pair Paradigm Monitor 9 Speakers
http://www.paradigm....ies-7/monitor-9
1 X Paradigm Centre 3 - Black Ash
http://www.paradigm....id=242&Itemid=2
1 X Paradigm PDR-100 Subwoofer
http://www.paradigm....-series/pdr-100
Retail $5745, Now only $3290
Again, this is a pre-packaged system and can't be split.
