Subwoofer Setting Help
sandline
, May 22 2012 11:02 PM
9 replies to this topic
Posted 22 May 2012 - 11:02 PM
I need some guidance in regards to my sub settings please.
I have :
Yamaha RX-V667 receiver
Front speakers are Jamo S606
Centre is Jamo S60
Sub is Jamo S300
Rears are ceiling speakers and can not remember what they are.
Fronts are set to Large
Centre and rears to small.
Could somebody please give me a guideline on what to set my receiver and sub too,on my receiver what should I set my Bass Cross over at and should I have xtra base on or off.
On the sub where should I set my cut off at(the dial is between 40Hz and 150Hz) and where should I set my phase(dial is between 0 and 180.) at.
I have messed about with various settings and just can not seem to get anything sounding right,I mainly watch DVDs,more action type movies and the system just seems to lack that punch during those times in the movs when you would expect those explosions moments to sound as they should.
Thanks for your time.
Andy
I have :
Centre is Jamo S60
Sub is Jamo S300
Andy
Posted 22 May 2012 - 11:34 PM
I'll give it a quick crack. I would set the sub cutoff to maximum (150), phase at 0, and volume to about 50%. Once you've done this, run the YPAO setup, which I dont have any experience with (I've used Denon's with Audyssey, similar sort of things). Once the YPAO is done, set all speakers to small and the crossover (in the amplifier) to 80Hz.
These are general rule-of-thumb settings. The YPAO setup should get all your speaker trims right (if, for example though, the sub trim is maxed out in the negative direction, the sub volume will be too high. Reduce it and recalibrate), then the speaker and crossover tweaks should get things sounding nice.
There should be a guide on AVSforum somewhere for YPAO guidelines,
Posted 22 May 2012 - 11:56 PM
Thanks Dave,
will give that a try tomorrow,appreciate your help again mate.
Posted 23 May 2012 - 11:35 AM
I was faced with a similar situation with my Yamaha A2010 and Paradigm DSP3400's. defeat the sub eq completely (max it out to 150 Hz) and sub gain/vol at 50% or so. Then run YPAO. fiddle with your gain/lvl till you get a YPAO sub level close to zero.
The extra bass function will send LFE to your mains if they are large. Since your mains are large, both mains + sub will dish out LFE (provided extra bass is on). Basically you are bypassing the eq in the sub and letting the receiver manage your eq. I personally tried using the eq function of the sub Vs the receiver and found that the receiver did a better job overall (for movies at least) managing LFE. Once everything has been set up and you still need more LFE, crank up the gain on your sub till you are satisfied with the sound.
P.S - sub placement would be the other main factor in this piece so check the forums on sub placement techniques. Lost of info available
Posted 23 May 2012 - 03:32 PM
Thank you mmu,
I intend to dedicate a day to resetting every thing up again,so that additional info will come in handy.
Posted 25 May 2012 - 01:51 AM
Ok done YPAO and sub was hardly detectable as it set the setting in amp to zero,so basically I used it to get my distances and then I went about setting the volumes manually.
After much messing about I got the sub to come in nicely on granddaughters dvd,Nemo,later that night when I went to watch a movie via an external hard drive through the blu ray player,I could hear the sub working,but it sounded awfull,just this dullish bass noise in the background which became annoying in the end.
I suppose like a lot of people I am not conversant enough with it all and can not seem to find something on the net in the most simplest terms to make me think that is where I am going wrong.So I wll read and read again until I nail this thing.
Thanks again for the input.
Edited by sandline, 25 May 2012 - 01:52 AM.
Posted 25 May 2012 - 11:18 AM
Start with the user manual.
Don;t try and guess at settings if you don;t understand them.
use the manual step by step in doing the YPAO setup.
There will also be options for things such as night mode, range compression, etc that it will explain what they are all about
Posted 25 May 2012 - 01:45 PM
probably due to the quality of the movie on the hard drive. What format was it in? Bet it doesn't have a LFE signal (the .1 in 5.1, 7.1) to make your sub sing. If the sub performs well with proper original DVD/Blueray disk (material with Low Frequency sound), then there is nothing wrong. softcopy movies tend to seem ok visually but generally sound terrible....Unless its a lossless copy.
Posted 25 May 2012 - 04:09 PM
Also remember that YPAO on the entry level models does not EQ the sub.
Posted 25 May 2012 - 06:08 PM
Thank you all,
messed about with it today,done some reading untill 3.00am last night and have worked it out enough,which was a lot better than before,I think my main problem was I had the volume cranked up too much and along with the settings not being close to good it made it sound horrid.
